#21 (permalink) |
burning bright!
Yes, exactly. If you tape over the intakes, there won't be any air coming from outside the cabin, only "recirculated" air from the footwells (IF you put on the fan). But when the AC is off, the air in the footwells is very often hotter than the outside air, as I'm sure you've discovered
#22 (permalink) | |
2) I understand the Radiators/Condenser/Cooling System cause the hot air, but where is the gap for the hot air coming into the vent? Can we do anything to the gap? |
#23 (permalink) | |
Alarmed & Dangerous
However, even if the outside air is cooler than the footwell with the AC off, that air still has to travel though the system where it is heated further.
The only way to prove if the vent temperatures are cooler with the AC off and air drawn from either the nose or footwell intakes is to take readings. It is not an issue to me because when the fan is on, so is the AC. Michael Quote:
#24 (permalink) |
burning bright!
The whole heater/AC unit evidently has to come out to get at the recirc flapper and actuator. However, since the recirc light isn't coming on, I'm guessing the first thing to check would be the fuse to the actuator. It's not obvious (to me) which fuse that would be. Any ideas?
#25 (permalink) | |
Alarmed & Dangerous
That would be fuse F15, however if that, & the switch checks out OK, then I would conclude that the fault is probably in the SPM. BTW, just because there is no indicator light, does not mean that the switch is not working.
Michael Quote:
Cobra OEM - Alarm, Immobilizer, CDL Emergency Override with warranty Additional Emergency Touch Keys - see link above Brand New Cobra Alarm Remote with warranty Cobra Remote Key Fob Strap Cobra Window Closing Module - Add to your existing Cobra alarm 3 Piece Front Clam Protection Kit with Center Bumper Undertray Removal Tool INFORMATION Improved AC & Heating System Battery Choices & Information Remote Key Fob, Alarm & Immobilizer Programming Light Bulb Conversions 2005 Last edited by TheViper : 07-03-2009 at 11:25 AM. |
#26 (permalink) | |
