Old 04-01-2009, 03:34 PM   #1 (permalink)
Can anyone help me diagnose a blower problem
Hi Guys,
After two and a half painful weeks of my Elise being out for a radiator swap at the dealer, I get the car back and I noticed that there's no air coming out of the air vents. I can hear the blower spinning, and there's a whole lot of air going somewhere, but not into the cabin. The dash/windshield/footwell air knob doesn't have any effect.
I can't go back to the dealer for a few days, so I was wondering if any of you can think of something obvious that they could have messed up. I'm guessing the ducting is disconnected from the fan somewhere, but I'm not familiar with the layout of ducting in the car's nose.
Thanks.
marcinr is offline   Reply With Quote
Old 04-01-2009, 03:50 PM   #2 (permalink)
Hello Kitty's Avatar
I have the same problem. I feel cold air drooling out of the vents, but there is no real airflow. I hope its covered by the warranty.
Hello Kitty is offline   Reply With Quote
Old 04-01-2009, 03:55 PM   #3 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
Dang I thought this was going to be like the Dr.Drew hour. Blower problem brings something else to mind.
Old 04-01-2009, 09:31 PM   #4 (permalink)
I did some exploring and I found and fixed the problem. When you take off the front panels that cover the fuses and brake fluid reservoirs, feel around under that center divider that the panel pegs slide into. Right down the middle of the car, directly under that divider, is a rubber tube that's a smaller version of the flexible tubes found on clothes dryers. In my car, that tube slipped off a plastic base, which is where the blower output is. Once I slid the tube over the blower base, my climate control works fine.
Old 04-01-2009, 10:13 PM   #5 (permalink)
Form and Function
plastique999's Avatar
I thought this was about a supercharger...
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
