Old 07-02-2009, 07:52 PM   #1 (permalink)
txdude's Avatar
CE Light after 4 days of ownership
So I picked up an '05 Elise from an LT member on Monday then drove about 1400 miles home without any problems. But now the check engine light comes on shortly after leaving the grocery store today...
I drove Lola (her name ) home with no problems & have an appointment next week at our base auto shop to connect it to the computer. Other than driving in the rain today, my driving habits didn't differ from when I picked it up. I know rain shouldn't be able to get into the engine itself, but is there a flaw in the design of the "lid" that allows water to seep into the motor area?
Should I be worried? Thanks in advance for y'alls assistance!
*Note: I know it shouldn't matter as this appears to be common, but I have experienced that "gas" smell inside the cabin when driving, usually only when putting the windows down briefly.
txdude is offline   Reply With Quote
Old 07-02-2009, 07:55 PM   #2 (permalink)
V Not my picture V
RacyTracy's Avatar
Check this for your leaky trunk-
Trunk hatch drain kits for sale.
And I assume the obvious, you've checked your gas cap?
Tracy
1996 Porsche 993TT
2008 Toyota FJ Cruiser
LOG 29 photos
RacyTracy is online now   Reply With Quote
Old 07-02-2009, 08:04 PM   #3 (permalink)
anglophile in exile
Aedo's Avatar
Images: 88
err - no. This car was designed and is widely used in England (a country not well known for its sunny days )
As Tracy says - check your gas cap. If it leaks you will get a CE light.
If the CE light is on constantly it is not an immediate threat. If it is flashing - don't drive!
Aedo is offline   Reply With Quote
Old 07-03-2009, 05:16 AM   #4 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Another water related issue is the blower motor for the interior fan. Affixed to the underside of the motor is a resistor pack that can sit it water that flows though the top hood vents. If this resistor pack fails, the blower fan will not operated and it is "very" expensive to repair, entailing removal of the front clam. Lotus had a TSB for this and it involved drilling 4 drain holes in the chassis member in precise locations.
Cheers,
Old 07-03-2009, 10:08 AM   #5 (permalink)
My '05 CE light comes on once in a while, but it is typically right after I get caught in a heavy rain. The reason my mechanic suspects is due to my cold air intake sitting directly behind the engine vents on the side, unprotected, where it gets blasted by air and rain water...eventually the water makes it's way to an o2 sensor and it trips it.
Does your car have a cold air intake? I have also heard of the air filter being over oiled, which again eventually compromises the 02 sensor by coating it in oil.
How does the car run otherwise?
Take it to Auto Zone and they can reset it for you and tell you what the code is.
Just a couple thoughts.
Andy
Krug1 is offline   Reply With Quote
Old 07-03-2009, 10:28 AM   #6 (permalink)
txdude's Avatar
Wow, thanks for all the quick replies. I can see I'm going to enjoy being a member of LT. Every single response was helpful. No problem with the gas cap & I'll cross my fingers about the resistor pack issue. Since the CE light isn't blinking I'll take Krug's suggestion & head to AutoZone in a bit.
Thanks RacyTracy for the link, I'll start this project soon.
Old 07-03-2009, 11:15 AM   #7 (permalink)
Chris Mackey's Avatar
Buy or borrow an OBDII reader. Then the computer can tell you why the CEL is lit.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
Chris Mackey is offline   Reply With Quote
Old 07-03-2009, 11:38 AM   #8 (permalink)
sleepe's Avatar
Is there a TSB repository somewhere in Lotustalk or elsewhere?
Elise'06ST:[size="1"]RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi-Nitron sportpro-RTVbrace-widened undertrays-VF2-manly's inserts-engine damper
sleepe is offline   Reply With Quote
Old 07-03-2009, 12:10 PM   #9 (permalink)
txdude's Avatar
"Major Exhaust Leak"
According to AutoZone, the OBDII reader determined the problem to be a "Major Exhaust Leak".
After visiting with my local Toyota dealership, their auto tech told me it could be three things: 1) Gas Cap--checked, 2) Fuel line from gas cap to tank, or 3) charcoal canister
I'm a novice when it comes to repairs. My experience goes as far as changing the head gasket & thermostat in my old Jeep. But I am looking forward to learning more so I'll start searching LT for directions to fix the problem after the holiday weekend. I have access to a lift on base so at least I won't have to pay a shop
Question: Can I safely drive her in the meantime, or is it best to simply park it? Note, it drove fine to AutoZone & back but I suppose this explains the "gas-like" smell whenever I crack the windows with the top on.
Old 07-03-2009, 12:16 PM   #10 (permalink)
jmiesse's Avatar
As for this
Please post the specific code that came up.
05 AS Elise. Tour and Sport Pack. Hard Top.Stage II
Exhaust, Sport ecu, Pagid RS 4-2s,Toyo R888's, Shifter Matrix brace, Micro Mirror
jmiesse is offline   Reply With Quote
Old 07-03-2009, 12:28 PM   #11 (permalink)
Me!
GR82DRV's Son
Me!'s Avatar
Try taking off the gas cap and putting it back on making sure it clicks like 3 times so it gets a good seal. This is very common in all sorts of cars. The gas cap may also appear to be on tight, but this is the only way to ensure it really is. Also, if that is the problem, it might take a couple of restarts to turn the light off. Hope it helps!
Me! is offline   Reply With Quote
Old 07-03-2009, 12:36 PM   #12 (permalink)
perfututum futūtor
RoadDad's Avatar
On Charlie's workbench, the Lotus service manual download site and moremonkey.com • View topic - Service Bulletins
Me... I don't need to.
Bite me." -Randy
Old 07-03-2009, 12:38 PM   #13 (permalink)
perfututum futūtor
RoadDad's Avatar
Originally Posted by jmiesse View Post
As for this
Mine doesn't smell like gas at all.
Bite me." -Randy
Old 07-03-2009, 07:25 PM   #14 (permalink)
txdude's Avatar
Pending tomorrow's weather, I'll take it back to AutoZone for the actual code. Thanks again everyone!
Old 07-03-2009, 08:47 PM   #15 (permalink)
i'm fast
cokey's Avatar
i haven't looked for this but is there a way to find the code with out a scaner? like in my car, turning the key to ON position 3 times quickly, it will display most codes..
BMW steel grey 04' neon srt4 ???hp ???ft lbs pulled the motor myself n rebuilt it.. got my baby back and its running strong. here for the love of the Elise, Exige and gaining the knowledge before I can get my own...
my car.. http://www.lotustalk.com/forums/f152...ny-pics-62883/
cokey is offline   Reply With Quote
Old 07-03-2009, 09:03 PM   #16 (permalink)
perfututum futūtor
RoadDad's Avatar
No.
Bite me." -Randy
Old 07-03-2009, 09:11 PM   #17 (permalink)
NOT ßANNED!
Demonized's Avatar
Originally Posted by RoadDad View Post
No.
The digitally displayed letters would weigh too much.
Old 07-03-2009, 10:20 PM   #18 (permalink)
txdude's Avatar
P0455
P0455-Evaporative Emission Control System Leak Detected.
I double-checked the gas cap & reset the CEL. Hopefully it doesn't return but we'll see.
Old 07-05-2009, 10:50 PM   #19 (permalink)
txdude's Avatar
So far so good...
Well, 2 days later & CEL hasn't returned
I figure it's 1 of 2 things... 1) Someone in the parking lot F'ed with my gas tank & didn't close it all the way, or 2) CEL will show up anytime now.
Assuming it wasn't the gas cap, anyone know how long I can expect the CEL to return? Or am I in the clear since I've driven it many times over the weekend without the CEL coming on?
Thanks for all y'alls help!!
