Big head man
Direct Lift 4 post lift
I'm just about to make this purchase. If anyone has anything to say about the product, vendor or alternatives I'd appreciate it.
Thanks, Ronnie EDIT: Sorry, the vendor is http://www.bestbuyautoequipment.com/default.asp
My car both sucks and blows. Now with added all natural smoky goodness!
Derriere Extraordinaire
i totally need one of those.
2006 KG-Sport Pack, LSD, TC, SS, RAC Monolites, Sector CF Roof, Carbon 3 Element Diffuser, V3 Panel eliminator (p-coated), Odyssey PC680, Boomerang , HIDs, CF Console, Multivex, Lotus Stage II, CF Zoom Rear View, Sector LidBone, Darth Holder (thanks Kestrel!), Sector 4Tress Harness Bar/CRD Mount, couple exige trim pieces- KGB Authenticated 2009 VeeDub Jetta (new kid on the block) 1978 Chevrolet Caprice Classic -(relegated to 'project car' status) |
Maybe check these places out. I need one bad. Laying on the floor doesn't suit my bones anymore.
http://www.completehydraulic.com/4post.html http://www.gregsmithequipment.com/Ve..._Lift_s/36.htm |
#5 (permalink) | |
Big head man
#8 (permalink) |
The write-up on it looks impressive. Built in an ISO9001 certified factory. And it appears you get a lot for your money. Hmmm...I could see using this set-up. Group buy sounds like a good idea. Thanks for the link!
Tom |
#9 (permalink) |
Big head man
I called the site. They only have the newer version which has a new, safer locking mechanism. That lift is called the Direct Lift Pro Park LL. This package is $2595. Shipping from California to Boise is $450 but they have other distribution sites.
They said with this package there is no group buy price.
#10 (permalink) |
Big head man
Here is a comparable package at the other site listed above for $2545.
http://www.gregsmithequipment.com/Di...rojack3500.htm
#13 (permalink) |
Fly N Lowr
I have had this same lift (older version) for a number of years and it has been great. bought it from here:
http://www.derekweaver.com/ I was told he is the main dealer for the U.S. (don't know if that is true but the price was good at the time) Any other questions let me know.
If you're not living on the edge you're taking up too much space!www.GoodBodyHealth.com |
#15 (permalink) | |
Big head man
#20 (permalink) | |
Big head man
Pro Park 7 Specifications Capacity 7,000 LB Lifting Height 72" (6') Overall Width 102" (8'6") Overall Length with Approach Ramps 208" (17' 4") Overall Length without Approach Ramps 176" (14' 8") Approach Ramps 37" (3' 1") Runway Width 19" (1' 7") Runway Length 166" (13' 10") Runway Thickness 4" Width Between Runways 37 1/2" Width Between Runway Rails 32" Outside Runway to Outside Runway 75" (6' 3") Clearance Under Runways 68" (5'8") Size of Column 6" x 4-1/2" Clearance Between Columns 93" (7' 8") Base of Column 10-1/8" x 12" Height of Columns 83" (6' 11") Drive Thru (Outside of tire to outside of tire) 81" Cable Diameter .375" / 3/8"/ 10mm Gauge Of Steel 6 Gauge (.1875"/ 3/16" / 4.75mm) Motor 110 Volt, 1HP Shipping Weight 1,620 LB. Locking Positions Under Runway (+/ - 2") Locking Positions Top Of Runway (+/ - 2") 16 3/4" 21" 34" 38 1/4" 38 1/4" 42 1/2" 42 1/2" 46 3/4" 46 3/4" 51" 51" 55 1/4" 55 1/4" 59 1/2" 59 1/2" 63 3/4" 63 3/4" 68" 68" 72 1/4" Direct Lift Pro-Jack 3500 Specifications Capacity 3,500 LB. Minimum Width 29 1/2" Minimum Width with Arms In 39 1/2" Maximum Width with Arms Out 64 3/4" Minimum Height with Lift Pad 3 1/2" Lifting Pad 1 3/8" Short Adapter 1 1/4" Tall Adapter 5" Raised Height without Adapter 11" Raised Height with Small Adapter 12 1/4" Raised Height with Large Adapter 16" Raised Height with Small and Large Adapter 17 1/4" Shipping Weight 350 LB.
