Old 08-25-2008, 06:51 PM   #1 (permalink)
buzzy's Avatar
Images: 10
Fans blowing hot air with temp set to cold
or is there something wrong. When the fans are on, hot air comes out of my vents with the temperature dialed all the way to cold.
Anyone have this with their one?
buzzy is offline   Reply With Quote
Old 08-25-2008, 07:04 PM   #2 (permalink)
Will There Be Cake?
ItsThaMonsta's Avatar
Make sure the recirculation (something like that) button is pressed. Yeahhhh also the other button two. Yeaaahhh so pretty much just make sure both those little small circular buttons are lit. Mine did the same. Afterward it blows really cold. I dont know whats wrong with everyone elses Elise but my AC works well.
ItsThaMonsta is offline   Reply With Quote
Old 08-25-2008, 07:11 PM   #3 (permalink)
POWR2W8
The_Bishop's Avatar
Images: 1
Is your question specific to when the A/C is on?? If so, I have not idea...
If you are talking about when the A/C is turned off, then I have a thought as I experience this as well....This is only my own personal, unauthorized response, but I think it has something to do with the location of the fresh air inlets and proximity of the radiator. Possibly there's a positive pressure build-up in the front of the car that allows the air to be warmed a bit by the bottom portion of the radiator and that air makes it's way in through the vents even though your temp dial is turn fully blue.. While this reasoning may not entirely be accurate, I'm pretty sure its a
In this photo, you can see the two vertically oriented mesh-coverd vents in the lower portion of the photograph:
Cheers!
- Allen.
S/N:34090 Mag. Blue/Biscuit, Touring, HT, 5000K HIDs, PPE/Larini SE.
The_Bishop is offline   Reply With Quote
Old 09-12-2008, 08:19 AM   #4 (permalink)
buzzy's Avatar
Images: 10
So from looking at the service manual, there isn't a heater per-se as the hot air comes from the radiator. There is a flap in the system which controls the mix of cold and hot air so it's possible that isn't not closed fully in the "cold" position.
Can anyone else confirm whether hot air should come from the vents when the temperature adjustment knob is in the fully cold position?
Old 09-12-2008, 08:37 AM   #5 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Some Possibilities;
1) Low refrigerant
2) Inoperative compressor
3) Boken or slipping drive belt
4) Defective thermostat
Old 09-12-2008, 08:40 AM   #6 (permalink)
tesprit's Avatar
You shouldn't get hot air from the vents with the temperature control knob on cold. That being said, there always seems to be some warm air coming from the vents if you are not using the A/C and just have the temp. set to cold. You may have a stuck flap that is allowing the outside air to pass through the heater core instead of diverting it around as you mentioned. How hot is the air coming from your vents? Can you put a thermometer in the vent and get an actual reading?
Old 09-12-2008, 09:25 AM   #7 (permalink)
shadowhusky's Avatar
From what I was told from my dealer you pretty much have the worse case scenario. If i remember correctly it means that the heater box needs to be replaced because some gears either stripped or broke and the flapper inside of it is not working. He told me this when I brought mine in for the resistor repair. to replace the entire heater box the dealer quote me a few buncks under $2000.00
I really hope it is something else, but it doesn't sound like it. Keep us informed.
2005 Elise, Aubergine, Touring Pack, Sport Pack, Hardtop, Quicksilver Exhaust, Cup Air Box, Tilting Clam, Mesh Grills all around - ( fabricated, not purchased ) 55w 6000k HID's, Painted Engine Covers, Center Console, A/C Surround, Polished Shifter Arm, Ball,and E-Brake Handle, Multivex Mirrors.
2008 Jeep Liberty, Jeep Green Metallic
2002 VW Jetta TDI, Metallic Blue, Daily Driver, 155,000 miles and going strong
shadowhusky is offline   Reply With Quote
Old 09-12-2008, 09:39 AM   #8 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Remove the left front access panel.
Pull off large flexble duct from top of HVAC box
You should be able to see the two flapper valves and determine if they are operating correctly.
Old 09-12-2008, 10:26 AM   #9 (permalink)
buzzy's Avatar
Images: 10
Thanks -I'll take a look at those flapper valves.
So would this also be related to my AC not blowing cold?
Sounds like I need a new heater box. Luckily I've a year left on the warranty.
Luke
Old 09-12-2008, 01:12 PM   #10 (permalink)
Alarmed & Dangerous
TheViper's Avatar
There could be many reasons that you don't have cold air blow out of the vents.
As was stated before, if those valves are stuck open then the air is flowing over the heater matrix which is always hot. If they are operating correctly then you must look at other possibilities.
Luke
Old 10-05-2008, 11:38 AM   #11 (permalink)
GG #668
biscoradio's Avatar
Images: 2
If I have the A/C turned off, and no recirculation, mine blows hot IF I'm in traffic or not moving fast. At speed it blows outside temperature. I guess I should check the flaps, but I'm inclined to think the ambient air is being heated by the radiator when there isn't enough airflow. Did you check your flaps? If so, what'd you find out?
biscoradio is offline   Reply With Quote
Old 10-05-2008, 12:06 PM   #12 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Interestingly enough, the recirculation from the footwell intake(s) can not be turned off. When the recirc. is off, air is drawn from both the footwell and nose intakes. When the recirc. button is pressed "on" the action is to close a flapper valve to shut off the flow from the nose intakes.
Old 03-24-2009, 04:22 PM   #13 (permalink)
BANNED
SweetDaddyD's Avatar
Images: 2
Hmm, noticed on the way home from a track day on Thurs that I only had heat. Including when I turned the knob to cold, it blew heat. Not just slighter warmer than ambient air- like the heat was on. It certainly seemed different than the last 4 years I've had the car. I did a search, found this thread, and pulled the access panel, pulled the heater hose...
And it looks like the flapper is working.
Any ideas why the flapper would appear to be working and it feels like it is blowing the heat the same as when the heat is set to high? It's always been maybe a touch warmer than the outside air but not too much different. Now just using the vent is like using the heater.
SweetDaddyD is offline   Reply With Quote
Old 03-24-2009, 04:25 PM   #14 (permalink)
The Azteks are coming!
the1sen's Avatar
Mine does it too... but using the A/C fixes that...
the A/C works REALLY well here in Phoenix with the "Viper Mods"
Cools off the car lickity split, no sh1t. The Viper RULES!
The difference between ordinary and extraordinary is that little extra.
F The System - ChuforiaGraffix.com SweetDaddyDelicious(at)hotmail(dot)com
the1sen is offline   Reply With Quote
Old 03-27-2009, 06:40 PM   #15 (permalink)
Alarmed & Dangerous
TheViper's Avatar
There are two possible reasons;
a) One or both of the flapper valves are leaking
b) The A/C is inoperative
Old 03-27-2009, 10:52 PM   #16 (permalink)
Regurgitated User
fitfan's Avatar
yes, the basic mods - drill out the block off panel in the pedal box, insulate the air duct tube, and tape off the intake vents (behind the grill i nthe crash structure) in the hotter seasons. make a night and day difference
Driving it around!
Old 03-28-2009, 12:38 AM   #17 (permalink)
choi0706's Avatar
didnt read the other replies, but check the flap valve for the heater box.. I had the same problem after using the heater once at night!.. It was miserable the next day in Houston heat..
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 03-28-2009, 07:05 AM   #18 (permalink)
"I'M OLD GREG"
CHRISN's Avatar
I had this problem on my car under warranty. They replaced the box on my car.
Chris
Ardent Red, stripes, LSS, Hard top, Touring, Star shield.
Mods:re-located Braile battery,2bular exhaust,larini decat,FF splitter,SS brake lines, motor mount bushings, ACT clutch, Toda flywheel, Quaife LSD, Stereo delete, Tilting rear clam, Aero catch engine cover, Alcantara dash, Turboxs intake, Ported stock header and throttle body,2 piece rotors,Pagid pads,
Delivered 12/04/04 #742 Auto Europe
CHRISN is offline   Reply With Quote
Old 03-28-2009, 07:17 AM   #19 (permalink)
Alarmed & Dangerous
TheViper's Avatar
The only thing is, that he is saying the "flap valves" seem to be operating.
Old 03-30-2009, 09:45 AM   #20 (permalink)
BANNED
Images: 2
Yes, I visually confirmed the flap valve in the heater core/condenser box moves back and forth with the knob. Yesterday with it being cooler out it didn't seem bad, but if it's 70 or so out it feels like the air blowing out is 100 or so. To hold your hand with fingers in the vent, it is definately well heated air. It is not uncomfortable to hold my hand out the window, it is uncomfortable to hold my hand directly to the vent. It certainly isn't just ambient air. Maybe my problem is somewhat intermittent but I don't understand mechanically how that is possible. I think the flapper even though it is moving is probably just "leaking". That is the only place I can identify that would be the source of my issue.
Pehaps this is a stupid question. If I drill out the block off plate in the car (did it on a friends car but not my own) does air always now blow through there? (guess I can just velcro it back on) Also if I tape off the vents at the front, now where does it take in air to get into the cabin? doesn't the air go from there into the heater box were the flapper valve is and then either across the heater core or AC condenser?
I will try to remember to pick up some insulation for the small streach of flexible hose as well. That actually makes a difference eh? Anybody have a small section to send me, or do I have to buy like 20 feet at the hardware store?
