Really Light Stuff
![]() Join Date: Jul 2003
Hard Top Rubber Bumper / Bump Stop
My Exige has only 7,000 miles, but I have noticed that the little rubber bump stops that mate with the hard top have both worn. One is worn so bad that it fell out.
I noticed because the hard top was beginning to chatter over big bumps in the road. The top was actually contacting the part that the rubber bumper fits into. 5 questions: 1) are these available on the open market? 2) will Lotus warranty this? 3) why is this happening? (The top is carefully fitted per the manual) 4) is there a better replacement part? 5) has this happened to you? ![]() Thanks a bunch, Thomas
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel .. To Order .. RLS Product Links .. |
insert clever title here
Lotus has generally been good about warranting odd bits and pieces like this, though you can expect to have to wait a month or so for them to be shipped over. Of course, in your case they might reject your warranty claim as your photo shows you've removed the roof from your Exige.
Really Light Stuff
> "in your case they might reject your warranty claim as your photo shows you've removed the roof from your Exige."
__________________ I assume that you are joking, but maybe not? Before I even purchased the Exige, I asked if the top was removable. "Yes, just like the Elise." It is structurally identical to the Elise hard top which is of course removable. Thomas
It's a Lotus
Yes, warranty. Lotus are the good guys.
Lotus body work and experienced mechanic at Lotus Talk sponsor Specialty Car Craft. http://www.specialtycarcraft.com/ See more of Larry's Photoblog at http://www.larrysphotoblog.net/ |
#5 (permalink) | ||
I'm under the impression that the roof on the Exige is advertised as being fixed and not removable, and that there's text somewhere saying your warranty will be void if it's removed. Sticker, manual, I'm not sure where. However, I did some more searching around here and it seems like it's not such a big deal - there MIGHT be warranty issues, but it's not likely. Here's the best quote I found, from a Lotus employee in the UK (source):Quote:
http://www.elisetalk.com/forums/showthread.php?t=18776 http://www.elisetalk.com/forums/showthread.php?t=21176 http://www.elisetalk.com/forums/showthread.php?t=22013 In your case, it's best to just show up to the dealer with the top on, show them where you think it's chattering, and avoid any questions about whether you've taken the top off. They could possibly claim that repeated removal of the top caused those pads to wear, and if top removal is not something they endorse, then...
Really Light Stuff
I appreciate the input.
Back to the original question(s), has anyone else had this problem (Elise or Exige)? Thomas
#8 (permalink) |
McLareghini Bugatterrari
My Exige owner's manual illustrates the process for removing and reinstalling the top. They would be hard pressed to defend the "no top removal" claim when it's right in the manual that came with the car.
#9 (permalink) |
Henry
My elise doesn't have the bump stops. Is it rubber, felt or something else?
I may experiment with the Idea that it may help with some rattle problems??
Henry http://www.abendanio.com/ 2005 Elise, AR, Touring, Sport, HT (RIP 10-6-08) 2005 Elise,Touring & Sports,Bordeaux Red Pearl 1986 Pontiac Fiero Gt, 1986 Toyota Pickup |
