Old 04-30-2007, 10:40 AM   #1 (permalink)
They’ve gone to plaid!
Stroker Ace's Avatar
Help air bag light
I replaced my factory seat belts to racing harnesses the other day and I completly removed my setbelts and motors. Now my airbag light is on I know why but am woundering if there is a way to fix it with out putting in the motors and the buckle. if anyone knows a way please let me know.
SOLD: 05 Elise Starlight Black w/ Black: Touring - LSS W/Black Wheels - Hard top - Starsheild - Lotus ECU Upgrade - Arqray Double Tip Exhuast w/ Sport Cat - Alpine Stereo - JBL Speakers - K40 Radar/Laser System - Braille Battery - 4Tress Hatness Bar - Schroth 4 Point Harness' - RTD Brace - Challenger Rear Grill - CF Rear Diffuser - CF Front Spoiler/Splitter - CF Side Scoops - Sector111 Trunk Bootie
www.AdcockBros.com
Stroker Ace is offline   Reply With Quote
Old 04-30-2007, 10:50 AM   #2 (permalink)
madberries's Avatar
Check here...
http://www.elisetalk.com/forums/show...2+ohm+resistor
I completely removed stock belts when i got my harnesses put in and put a 2.2 ohm resister in place of it and everything works fine... No airbag light or anything.
'05 Lotus Elise (Magnetic Blue) - FF275, Braille Battery, 4Tress Harness bar, Schroth 4-point Harnesses, CF Console, FF gauge pod, Moroso oil pan, ACT HD clutch, Toda Flywheel, SSRs... Ohlins coilovers and adjustable sway bar on the way.
madberries is offline   Reply With Quote
Old 04-30-2007, 07:59 PM   #3 (permalink)
were did you get it and were did u install it?
www.AdcockBros.com
Old 04-30-2007, 08:31 PM   #4 (permalink)
lancer360's Avatar
You can buy the resistor at Radio Shack. It is in a variety pack of 500 resistors for around $12. It should have qty. 5 - 2.2 ohm resistors. You need one for each seat belt. A little bit of soldering and some heat shrink and you should be set. I spliced mine in rather than cutting off the connector just in case I want to go back.
'05 Lotus Elise Saffron Yellow, Touring, Sport, Stainless Brake Lines, Moroso Oil Pan, RTD Brace
NovaKBS Forumla 600 Powered by Suzuki GSXR
lancer360 is online now   Reply With Quote
