Old 10-04-2009, 10:28 AM   #1 (permalink)
HELP Coolant temp
I am at my parents and my temp reading is super high at ike 230+. It ran fine yesterday. Also, there is absolutely no heat coming from the vents just cold air. Any ideas?
~Andrew
OTOmatic is offline   Reply With Quote
Old 10-04-2009, 10:32 AM   #2 (permalink)
lotusforsale's Avatar
Images: 8
~Andrew
Have you checked your coolant level?
lotusforsale is offline   Reply With Quote
Old 10-04-2009, 10:48 AM   #3 (permalink)
No, it was raining. I plan to do that when it stops first and lunch had started already
Old 10-04-2009, 11:03 AM   #4 (permalink)
lt0302's Avatar
thermostat stuck
you could have a stuck thermostat............and in your case it is stuck closed.......mine has been stuck open for a year now no issues except it runs pretty cool which is ok here in AZ.....so check your thermostat
05 Lotus Elise R/K Supercharger, Stage II, Moroso Oil Pan, RTD Brace, High Volume All Aluminum Radiator, Stainless Steel Break Lines, Oil Catch Can, ACT Clutch, HID, Carbon Fiber Spliter, Reverie Side Scoops, CF side skirts, FF gauge pod, BWR gauge pod, Cup Air Box, S111 front & rear tow hooks, upgraded tail lights-LED, Driving lights, LETSLA, ...
lt0302 is offline   Reply With Quote
Old 10-04-2009, 11:16 AM   #5 (permalink)
Can I 'unstick' it somehow easily? I'm sneaking from the fam to do this otherwise I'd take time and look this stuff up myself.
Old 10-04-2009, 11:58 AM   #6 (permalink)
Chris Mackey's Avatar
First things first.
1. Check the coolant reservoir
2. Bleed the coolant system (several threads about this)
3. Worry about the thermostat
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
Chris Mackey is offline   Reply With Quote
Old 10-04-2009, 12:01 PM   #7 (permalink)
Originally Posted by Chris Mackey View Post
First things first.
The resevoir is low for sure. I don't have my manual on me but what type of fluid does it take?
Old 10-04-2009, 12:09 PM   #8 (permalink)
(Formerly PESTODUDE)
Illumiloti's Avatar
just put in water to bring it up to level (engine running during fill)
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune.
Illumiloti is offline   Reply With Quote
Old 10-04-2009, 02:48 PM   #9 (permalink)
Live from the Bubble Room
407Driver's Avatar
The thermostat could be stuck but if the tank was dry then the system likely ingested air at some point and will need bleeding (the thermostat will not open in the presents of air). There is a bleed point on the tank itself and two on the coolant hoses, one at the rear of the engine (easy) and one at the radiator on the passenger side (not so easy) I would start looking for leaks as well.
"Never leave well enough alone" Raymond Loewy
407Driver is offline   Reply With Quote
Old 10-05-2009, 07:53 AM   #10 (permalink)
There is a definite leak now somewhere up front on the passenger side. The tank has depleted several times afer just being on for a couple minutes.
Old 10-05-2009, 08:02 AM   #11 (permalink)
Images: 8
This is going to require some time, and some tools. And probably some help.
Old 10-05-2009, 08:09 AM   #12 (permalink)
Tool of choice is a tow truck and warranty now
Old 10-05-2009, 08:18 AM   #13 (permalink)
It's a Lotus
LARRY's Avatar
Get a flatbed tow truck for the ride to your lotus mechanic.
Sounds like you have a very common leak near the radiator, probably the hose leading in or out - the hose clamp likes to loosen in that area.
Have it looked at, it's a warranty fix.
2005 Saffron Yellow Elise. Stage II Exhaust. 2007 ProBax seats.
LARRY is offline   Reply With Quote
Old 10-05-2009, 10:31 AM   #14 (permalink)
Not yours, too... my clutch interlock is buggered. I didn't think we pushed the cars that much on Saturday! We even compared the temp and both cars were idling at 205.
2006 Aspen White Elise
2007 39' Beneteau Cyclades
biffster10 is offline   Reply With Quote
Old 10-05-2009, 11:14 AM   #15 (permalink)
I know. It happened first thing the next day as I was heading to my parents house. I didn't push the car at all. And like mentioned above, it sounds like a warranty fix so I'm just goin to flat bed it over to Gentry Lane. Good that it happened before my warranty expired but ****ty since i am leaving to Alberta tomorrow
