Old 10-23-2009, 09:32 AM   #1 (permalink)
LotuShii's Avatar
Help: Engine light still on after re-install stock cat converter
Per previous owner and Dealer information, the aftermarket cat converter has too much air flow throught oxygen sensors causing engine light on. However, the engine light did not go away after re-installing the stock cat converter. I have disconnected the battery for at least two hours, but it did not help. Per Dealer's feedback, it has to be reset with computer, and it costs $140. I think it is a little bit too much. Any advise will be greatly appreciated.
LotuShii is offline   Reply With Quote
Old 10-23-2009, 09:36 AM   #2 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
You can reset the engine light with a good OBD-II code reader. You can buy one for less than $140 (and if you're making changes to the engine, the intake or exhaust, it's not a bad idea to own one). Some auto parts store lend them out if you don't want to buy.
Old 10-23-2009, 09:37 AM   #3 (permalink)
Back to Basics
E_Swift's Avatar
Reset it with an OBD2 scan tool. Best bet - borrow one from a friend.
PS you can buy a scan tool for less than $50 now, and it will work for all 96-up cars you own.
Current:{2006 Volvo V50}{2005 Lotus Elise}{2005 Subaru Impreza 2.5RS}{2004 Subaru Impreza WRX STi}{1988 Lancia Delta Integrale}
Past: {1997 Honda Civic EX}{1994 Infiniti J30}{1992 Volkswagen Passat GL}{1988 BMW M3}{1988 Nissan 300ZX}{1988 Ford Taurus LX}{1971 BMW 2002}
E_Swift is offline   Reply With Quote
Old 10-23-2009, 09:43 AM   #4 (permalink)
LotuShii's Avatar
Thanks for your quick response! I am located in Austin, Texas. Is there anyone can help to reset it? I hope this is not too much to ask.
Old 10-23-2009, 01:06 PM   #5 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Most autoparts stores will do it for free.
Old 10-23-2009, 01:29 PM   #6 (permalink)
LotuShii's Avatar
Many many thanks...!
Old 10-23-2009, 01:47 PM   #7 (permalink)
luxige
luxige's Avatar
Yes, try calling the larger chain stores such as Auto Zone, NAPA.
Keep in mind that erasing a code will also reset the readiness monitors to a 'not ready' state, so if you are getting an inspection, you'll need to run through a drive cycle or two to put the monitors in 'ready' state before your inspection.
luxige is offline   Reply With Quote
Old 10-23-2009, 03:44 PM   #8 (permalink)
Back to Basics
E_Swift's Avatar
PS - most stores typically have policies where they can read you the code, but can't reset it unless they sell you an 02 sensor, or whatever the suggested next step is.
Not that you can't make a friend and change their mind...
