Old 06-22-2005, 05:26 AM   #1 (permalink)
Prez: The K.G.B.
MickOpalak's Avatar
Help! Hardtop bolt stripped, sort of
Right now I can't remove my hardtop because one of the four bolts holding it on (the one behind the drivers head) is stripped. It's not the threads of the bolt that are stripped, but the bolt head where the six-sided socket goes in. This has been rounded off so that the socket no longer bites. I've tried other options like using a Phillips screwdriver, a flat head screw driver and even a set of pliers around the bolt head itself. None of these will get it to budge. I figure once I have the hard top off I can just replace this bolt.
Any ideas on how to get this bolt loose? I may just end up taking it to the dealer.
2007 Exige S265 - Krypton Green - Gotham 265 ECU - Volk TE37s - Toyo R888s - B&M Shifter - QuickSilver exhaust - stripes - harnesses - Pagid pads - Green air filter
2002 Jaguar XKR convertible
2000 BMW 528i
President - Lotus Limited Southeast
http://autos.groups.yahoo.com/group/LLSE/
MickOpalak is offline   Reply With Quote
Old 06-22-2005, 05:38 AM   #2 (permalink)
lotuscar's Avatar
Sears has a tool that "bites" into the head of rounded screws.
lotuscar is offline   Reply With Quote
Old 06-22-2005, 06:34 AM   #3 (permalink)
burning bright!
Tyger's Avatar
[quote=MickOpalak]Right now I can't remove my hardtop because one of the four bolts holding it on (the one behind the drivers head) is stripped. It's not the threads of the bolt that are stripped, but the bolt head where the six-sided socket goes in. This has been rounded off so that the socket no longer bites. I've tried other options like using a Phillips screwdriver, a flat head screw driver and even a set of pliers around the bolt head itself. None of these will get it to budge. I figure once I have the hard top off I can just replace this bolt.
[/QUOTE
Did you try Vise-Grips? Usually you can get them to grip something round pretty tightly without the hand pressure that might cause it to slip.
If the bolt is completely stripped, there was probably a problem with the threaded part too. Why would it be on so tight as to cause the head to become stripped?
In any case, you will probably need to get to the dealer to replace the bolt because it is a special "captive" Torx bolt.
Old 06-22-2005, 06:37 AM   #4 (permalink)
Bucket of Cold Water
Goose's Avatar
I'm just thinking aloud, to add ideas to the pile:
If you've got a Dremel tool, you could cut a slot into the head of the bolt. Then just take a big 'ole flathead screwdriver to it...
(I'd probably get one of those nifty "screw outs", as mentioned before. Wouldn't want to risk barking the paint with the Dremel.)
Trying to help...
Kevin
Magnetic Blue/Hardtop/Starshield - sold 5/17/05
Goose is offline   Reply With Quote
Old 06-22-2005, 06:58 AM   #5 (permalink)
Prez: The K.G.B.
MickOpalak's Avatar
Thanks for all of the ideas.
I"m heading to Lowes after work to pick up a 'screw-out' type device.
2000 BMW 528i
Old 06-22-2005, 08:09 AM   #6 (permalink)
AS # 0232
LOTUS 5's Avatar
Mike, here is link to another who had same problem. Unfortunately just how he got the screw loose is unclear. I have put my top back on once and adjusted all the fittings to align better. Just doing this I can see some rounding on the screws. I am looking into getting a flexible shaft drive to get a better angle with the bits as they are used to tighten and loosen the screws. Good luck with your problem. Regards, Bob.
http://www.elisetalk.com/forums/showthread.php?t=11608
Cuando Omni Flunkus Moritati
LOTUS 5 is offline   Reply With Quote
Old 06-22-2005, 12:45 PM   #7 (permalink)
Get an appropriate sized "easy-out" and drill into the bolt. Then apply the easy-out with a wrench to remove the bolt.
2005 Lotus Elise, Magnetic Blue with blue leather, Touring, Hard Top, Starshield, SS brake lines, #635 (sold 9/8/05)
Cisitalia is offline   Reply With Quote
Old 06-22-2005, 01:19 PM   #8 (permalink)
TimMullen's Avatar
Images: 19
Before you start drilling and "easy-outing", try some of the available (from Sears) stripped screw removal tools. Easy-outs can often break and make things even more difficult. I'd first try the Sears stripped screw removal tool, and if that didn't work, I'd get out my Dremel and cut a slot in the head for a screw driver. Easy-outs should be the last (and usually the worst) resort.
94 Miata R Package - Black
Old 06-23-2005, 05:35 AM   #9 (permalink)
Prez: The K.G.B.
MickOpalak's Avatar
The fine gentlemen at Lotus of Atlanta got the bolt out in a matter of moments this morning with a solution so simple and straight forward that I never would have thought of it.
Obviously the metal of the hardtop bolt is a little soft to start with since I was able to round it off so easily. They took the appropriately sized six point socket that would normally be used to remove the bolt and put it up to the bolt and applied a couple of raps with a hammer. The socket was now sunk into the bolt. They added a socket wrench and the bolt rotated right out. Once loose, they removed it and replaced it with a brand new one. It took a total of five minutes.
Kudos once again to LOA.
2000 BMW 528i
Old 06-23-2005, 07:55 PM   #10 (permalink)
burning bright!
Tyger's Avatar
Hmm. It's supposed to be a Torx socket. You weren't using a regular hex wrench on it, were you?? That would explain how it started to get stripped in the first place!
Old 06-24-2005, 05:49 AM   #11 (permalink)
Prez: The K.G.B.
MickOpalak's Avatar
Yes, I was talking about the Torx socket. The six-sided, star-shaped type. I didn't know what they were called.
2000 BMW 528i
Old 06-24-2005, 03:12 PM   #12 (permalink)
LotusLust's Avatar
nice racket you are running there, mick
Storm Titanium, LSS, touring, hard top. my other car is a ...oh yeah i remember the other car...a spyder
club111 member. i tried to buy a lower spot and become member #13 but was spurned!
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety" -benjamin franklin
LotusLust is offline   Reply With Quote
Old 03-08-2009, 07:33 PM   #13 (permalink)
AdamT's Avatar
Sorry to revive such an old post, but after a couple of seasons of taking the hardtop off and then putting it back on, this same problem has developed for me. One of the Torx bolts is almost completely stripped. After a lot of work, I finally got it out, but I am going to need to come up with a solution before I try to put the hardtop back on again next season since that bolt has had it.
I'm thinking of the Dremel tool trick mentioned above as one solution. But I'd rather just cut the old Torx bolt one out of there and put a new one in. Has anyone else done that? If so, does it really make a difference if the new Torx bolt isn't tethered to the roof permanently like the old ones? And why does it need to be a Torx bolt at all? I can't see why either of those things would make a difference, but I just figured I would ask before I gave it a shot.
2005 Lotus Elise (ardent red on black / touring & sport packs) ... for the twisties
2004 Mercedes Benz E55 AMG (silver on black/red) ... for the torque
[DC-area owners... help me map the great roads of the area]
AdamT is offline   Reply With Quote
Old 04-30-2009, 08:52 AM   #14 (permalink)
AZLotus's Avatar
I'm right there with you. It's the same bolt that was mentioned in the original post. The drivers side rear bolt. I'm thinking a new CF top is the best solution
- 2006 ST Exige Daily Driver -
CF Panels, CF Lip, CF Binnacle, CF Scoops, CF Shiftknob, Fidanza Flywheel, Fidanza 3.2 Clutch, Eliminator v3, RTDbrace, Folding Front Tow Hook, discNOIR w/ Hawk Streets, Girodisc SS Brakelines, re-ENFORCER, microMIRROR, V-FORCE Harness bar, Janspeed SII + Larini de-cat, Braille B2015 + Xtender.
AZLotus is offline   Reply With Quote
