Help Oil leak
Hi all, Well just went to move the car from one side of the garage to the other and found an oil leak from the front of the car under on passenger side front . I beleave its from the oil cooler, Oh let me give you some insight it's a 2005 Elise early built 2004 so it has the twin oil coolers. Has anyone ever had a leak from them? Thanks for your insight....
#2 (permalink) | |
Ex and future Lotus owner
the1sen: why move forward with design when you can recreate a monstrosity from the past? |
#234 is a pretty early build, May/June 2004?. Usually the crimping problem was more common on the later builds. With the oil leaking from the area you mentioned, I'd have to bet it's a cooler/line problem of some sort. Luckily, these things are fairly easy to diagnose once you get a good look at it. Good luck.
#5 (permalink) | |
There also was a small number of cars with badly crimped fittings to the hose, but they were the exception. And they were on later cars. Since this is on a very early car, I would suspect that there is a fracture in the oil cooler fitting. However, maybe if you are lucky, it's just a loose fitting - remember to use two wrenches to tighten it if that is the case.
#6 (permalink) | |
#7 (permalink) |
NOT ßANNED!
Jack the car up, take off passenger front wheel, take out the mudguard shield thingie (it has a name.... but.. yeah), if you can't locate the leak, take off the front aluminum underpanel, inspect from there.
It will help if you know what exactly is leaking.
#8 (permalink) |
Yep. The tube that leads into the cooler that has the fitting on it that the hose's fitting screws onto. The twisting (from not using the second wrench) causes a fatigue crack to form in the tube.
#9 (permalink) | |
#10 (permalink) |
Found the leak
Its an original one..... I ate a bird into the oil cooler and he cause the leak in the fins of the oil cooler hahaha what away to go.... I now need a oil cooler son of a gun.... Do you recommend a factory oil cooler or is their an aftermarket solution that works..??? Thanks guys for you help....
#11 (permalink) | |
