Old 07-10-2006, 08:19 PM   #1 (permalink)
MikeC's Avatar
How accurate is the speedo?
Mine reads high by 7 MPH. I'm measuring it with a Garmin GPS that measures speed. My two other cars are dead on so I think the GPS is accurate. I hope it is adjustable.
I'll ask the dealer to fix it at my 1,000 mile service.
Keep the shiny side up
MikeC
05 CO Elise
02 Audi S6
72 MB 280SE 4.5
MikeC is offline   Reply With Quote
Old 07-10-2006, 08:29 PM   #2 (permalink)
The error you have is typical. My speedo was accurate at some speeds and 5 mph off at others. Get a passenger to read the gps and write it down if you want data for high speeds. The speedo doesn't coincide with what the ecu has if you read a scan tool. Too bad we can't display it instead and toss the speedo out. It's dead weight.
MikeW is offline   Reply With Quote
Old 07-10-2006, 08:38 PM   #3 (permalink)
... _ . ..._ .
nvrblu's Avatar
When I checked mine against a GPS receiver:
80 mph -> 76 mph by GPS
50 mph -> 47 mph by GPS
nvrblu is offline   Reply With Quote
Old 07-10-2006, 08:42 PM   #4 (permalink)
OSX Black hat
charliex's Avatar
mine tested at about 7-8% your dealer can't fix it.
Old 07-10-2006, 09:01 PM   #5 (permalink)
What's behind the face? It seems you couldn't make it much worse by fixing it yourself? Is the oddometer ok or are we running out of warranty prematurely?
Old 07-10-2006, 09:06 PM   #6 (permalink)
OSX Black hat
charliex's Avatar
odometer is fine.
you could redo the face plate with new numbers as an easy fix, the cluster chip is probably reprogrammale but requires some special hardware.
i made a fix in the ecu code itself, but theres no way to give it to other people who have ordinary ecus.
Old 07-10-2006, 09:56 PM   #7 (permalink)
rnr
daily driver
rnr's Avatar
Mine is 8% as well
http://www.rahulnair.net/blog
rnr is offline   Reply With Quote
Old 07-11-2006, 07:31 AM   #8 (permalink)
Slow Thinkers Keep Right
Are the speedo inaccuracies similar for both 2005's and 2006's?
nas213 is offline   Reply With Quote
Old 07-11-2006, 07:40 AM   #9 (permalink)
Meow talk lotus one day?
andykeck's Avatar
Images: 1
Originally Posted by rnr
Mine is 8% as well
Yeah, I calculated mine to be in the high 7.x% range as well.
andykeck is offline   Reply With Quote
Old 07-11-2006, 08:04 AM   #10 (permalink)
My speedo was way off when I first got my Elise last year.
Elise said= 60mph Actual= 40mph
Elise said= 80mph Actual= 60mph
And when I was sitting idle at a stop light/sign the speedo registered 10mph
I took it in and they replaced the whole head unit. Seems to be working fine ever since.
Skip is offline   Reply With Quote
Old 07-11-2006, 08:09 AM   #11 (permalink)
OSX Black hat
charliex's Avatar
jack says the 06 is fine, i haven't comapared mine yet.
Old 07-11-2006, 08:14 AM   #12 (permalink)
According to the stationary speed detector things on the side of the highway, my 06 appears to be accurate over the range of 25-60 mph.
Old 07-11-2006, 10:51 AM   #13 (permalink)
My '06 isn't fine at all.
Old 07-11-2006, 10:52 AM   #14 (permalink)
Baysailor's Avatar
My '06 is about 7-8% off across what appears to be the whole range (verified by GPS). At a stand still, the speedometer needle doesn't go all the way to 0 either, it sits up around the 2-3 MPH area.
2006 Lotus Elise - Solar Yellow, HT, LSS, LSD/TC, Touring, StarShield, S111 RTDbrace, S111 microMirror, S111 Carpet Buttons, Painted A/C Surround, CF Center Console, Nitron S/A, Tempest BAB26-12 AGM Battery, Fujita Intake, Top Speed Pro 1 Exhaust, 4Tress Harness Bar, 6000k 35w HID kit, Moroso Oil Pan, Plinthless front clam, Team Dynamics Pro Race 1.2 Wheels w/ RE01-R's for street use, Heater Core By-Pass, Shifter Reinforcement, LETSLA v2 Shift Kit
Baysailor is offline   Reply With Quote
Old 07-11-2006, 10:54 AM   #15 (permalink)
OSX Black hat
charliex's Avatar
the cluster reset procedure should fix that if you haven't tried it already,
drivers door open, press the trip resest and turn on the ignition, if memory serves.
it doesn't suprise me the 06s are off too, my 1991 lotus is off by the same amount too
Old 07-11-2006, 11:29 AM   #16 (permalink)
Before I'm through owning this car I'm going to have so many redundant/additional instruments that I may as well make my own dash.
Spa digital tach/shift light (something that will work and is quickly readable)
Spa oil press/oil temp (something they forgot )
wideband O2 (my obsession)
lap timer (my necessity)
water temp (can't see it readily but it's hiding there)
volt meter
Speedo? (would be nice to know how fast you're ACTUALLY going, isn't that the purpose?)
With the availability of modern day electronics, I find it odd that the instrumentation hasn't exceeded the capabilities of those in my 70 Camaro
thank God the fuel gauge works!
Old 07-11-2006, 11:33 AM   #17 (permalink)
OSX Black hat
charliex's Avatar
the speedo thing is deliberate due to european laws.
driving around in LA i've noticed no one seems to pay attention to their speed.
lotus hinted at a new track style cluster, my best guess would be that'd be the AIM unit they use on the GT3, theres supposed to be some announcement on stuff in the next week or so.
Old 07-11-2006, 11:41 AM   #18 (permalink)
Charlie, you should tell me that stuff ahead of time! Next time you hear of anything from Area 51 at Lotusland, give a holler.
Old 07-11-2006, 12:21 PM   #19 (permalink)
Not Dead Yet
wallabyguy's Avatar
The Elise's speedometer is about as acurate as a shotgun from 100 yards.
former Lotus Sales
Robert (aka Sith Lord of LBL)
74 Elite 502
05 Elise (Snuffalupagous..RIP : Laser Blue, Black Leather, Touring Pack, Hardtop )
The Wallaby Will Ride Again
wallabyguy is offline   Reply With Quote
Old 07-11-2006, 12:24 PM   #20 (permalink)
Baysailor's Avatar
the cluster reset procedure should fix that if you haven't tried it already, drivers door open, press the trip resest and turn on the ignition, if memory serves.
Yeah, I tried this, but no joy. It isn't nearly as bad as some of the others I have heard (stuck up around 15 to 20 MPH), so I don't worry about it.
