Old 07-11-2006, 03:43 PM   #21 (permalink)
MikeC's Avatar
Well.. today my speedo got worse.. I was going slow.. about 30 and I watched it creep up to 60. And now, it rests at 1o mph when the car is stopped. To me, the speedo is important for a road car. They need to fix it. I sure hope its fixable. I can't believe they expect everyone to put up with a broken speedometer.
Keep the shiny side up
MikeC
05 CO Elise
02 Audi S6
72 MB 280SE 4.5
MikeC is offline   Reply With Quote
Old 07-11-2006, 04:06 PM   #22 (permalink)
Meow talk lotus one day?
andykeck's Avatar
Images: 1
The needle reset procedure is in the manual. Otherwise, if the gauge is truly broken, then obviously that'll get swapped out under warranty. But the new one will read 7 to 8 percent high too.
andykeck is offline   Reply With Quote
Old 07-11-2006, 04:47 PM   #23 (permalink)
MikeC's Avatar
Thanks! that worked. Now the needle is at zero. Does anyone know why it gets out of sync? I"ll check its accuracy tomorrow with my GPS
MikeC
05 CO Elise
02 Audi S6
72 MB 280SE 4.5
Old 07-11-2006, 05:15 PM   #24 (permalink)
Baysailor's Avatar
Does yours rest exactly at zero or is it above it? Mine rests right around 2~3 MPH, but other than that is within the norm (7% or so off).
2006 Lotus Elise - Solar Yellow, HT, LSS, LSD/TC, Touring, StarShield, S111 RTDbrace, S111 microMirror, S111 Carpet Buttons, Painted A/C Surround, CF Center Console, Nitron S/A, Tempest BAB26-12 AGM Battery, Fujita Intake, Top Speed Pro 1 Exhaust, 4Tress Harness Bar, 6000k 35w HID kit, Moroso Oil Pan, Plinthless front clam, Team Dynamics Pro Race 1.2 Wheels w/ RE01-R's for street use, Heater Core By-Pass, Shifter Reinforcement, LETSLA v2 Shift Kit
Baysailor is offline   Reply With Quote
Old 07-11-2006, 05:24 PM   #25 (permalink)
MikeC's Avatar
Mine reset actually a hair below zero.
So, you think that if I complain about it, it cannot be fixed?
MikeC
05 CO Elise
02 Audi S6
72 MB 280SE 4.5
Old 07-11-2006, 05:27 PM   #26 (permalink)
OSX Black hat
charliex's Avatar
I think the more you complain about it, the less likely it is they'll fix it.
As i said earlier my 1991 elan has the same thing, Lotus never fixed that either.
It'd need a stateside cluster, seems unlikely they'd do it as the clusters most likely come like that when they buy them in, its not really a lotus defect.
Old 07-24-2006, 11:05 PM   #27 (permalink)
i used to have an mr2 with wheels larger than stock, that caused my speedo to be innaccurate. i was actually going ~6-7% faster than the speedo was reading. although it's the opposite problem (the lotus speedo is reading faster than actual speed). basically, you guys need to swap to larger rims to get accurate readings but it wont be reflected by the GPS.
ct20b drifter is offline   Reply With Quote
Old 07-25-2006, 06:34 AM   #28 (permalink)
Jack's Avatar
Originally Posted by charliex
jack says the 06 is fine, i haven't comapared mine yet.
My Exige Speedo was pretty close to accurate as compared to my '05 Elise. The '05 was fast by about 7-8% -- not my '06.
Jack
'07 Exige Cup 255
'08 2-Eleven
Old 07-25-2006, 07:40 AM   #29 (permalink)
onecall1's Avatar
How can the speedo be off (which mine is) but the odometer be on? Are these two not tied together? Stumped.
Former Elise and Esprit owner. Currently enjoying my M3 purchased from HRM.
onecall1 is offline   Reply With Quote
Old 07-25-2006, 07:46 AM   #30 (permalink)
TimMullen's Avatar
Images: 19
Except that will be detrimental to the acceleration, braking, and handling of the car. Additionally, it may make the speedometer more accurate, but the odometer will not longer be accurate...
94 Miata R Package - Black
Old 07-25-2006, 10:01 AM   #31 (permalink)
Tintin's Avatar
My understanding is that the ECU sends the correct info to the instrument cluster. Somebody here on Elisetalk had attached a scanner to the bus (canbus?) and figured out that it matched their GPS reported speed. Its the instrument cluster that decides to move the speedo needle 7-8% too much. Thats how the odometer can be accurate but not the speedo.
Tintin is offline   Reply With Quote
Old 07-25-2006, 10:07 AM   #32 (permalink)
OSX Black hat
charliex's Avatar
The odometer uses a seperate source for its information, not just the CAN bus, that would be catastrophic.
There is another microcontroller in the cluster that has the error introduced.
Old 07-25-2006, 10:17 AM   #33 (permalink)
... _ . ..._ .
nvrblu's Avatar
Is the speedometer needle driven by a galvanometer or a servo motor? If it's a galvanometer, it could probably be adjusted by adding or adjusting a shunt resistor. The speed sensor is digital... the guage is analog.
I checked mine against a gps and found 80 mph on the speedo was really 76. Not much to worry about but nice to know.
nvrblu is offline   Reply With Quote
Old 07-25-2006, 10:56 AM   #34 (permalink)
MikeC's Avatar
Yes.. I agree. 76 vs an indicated 80 would be quite acceptable to me.
But in my car an indicated 80 is actually 61. thats pretty far off.
The other issue I have is that my needle does not reset to zero. It is now resting at 15 MPH. It zeros when I do the RESET procedure, but in a few days it's back at 15-20 MPH again.
Is RESET something you need to do often? like every other day?
MikeC
05 CO Elise
02 Audi S6
72 MB 280SE 4.5
Old 07-25-2006, 10:59 AM   #35 (permalink)
andykeck's Avatar
Images: 1
Over 13,000 miles and I've never had to do the reset procedure. I think yours is just plain broken.
Old 08-29-2006, 05:03 PM   #36 (permalink)
JimG's Avatar
My speedo ('06 Exige) seems accurate when I start out, then after a while on the highway it slowly decays to reading slower and slower. The worst I've seen is probably 20 mph below actual, judging by the tach. When I come to a complete stop it seems to be ok again for a while.
It's going in for service this week and the dealer said they will repalce the gauge set if the reset procedure doesn't solve the issue. There must be some Lucas electronics somewhere in there.
JimG is offline   Reply With Quote
Old 04-21-2007, 12:37 AM   #37 (permalink)
Track Addict
gameson's Avatar
my speedometer is off by ~+8 mph across all speed (so if it's 70 mph on the tach, GPS reads about 62 mph). I compared it with my GPS speed
gameson is offline   Reply With Quote
Old 04-21-2007, 06:46 AM   #38 (permalink)
Zerofail's Avatar
+8 on mine as well. I am not sure it is a big enough deal for me to have fixed.
05 ST Elise (Current)
07 Toyota FJ Cruiser (current)
65 Mustang (current)
02 MINI Cooper S (sold)
71 Land Rover Series II 109 Wagon (sold)
67 Camaro RS/SS (sold)
60 Austin Healy Bugeye (Full on "John P Lucas Prince of Darkness wirring (sold)
Zerofail is offline   Reply With Quote
Old 04-21-2007, 09:00 AM   #39 (permalink)
my S read 151 @148mph on the GPS above 95 its dead on, 3-4mph high below 90. carl
carl is offline   Reply With Quote
Old 04-21-2007, 05:18 PM   #40 (permalink)
Jack's Avatar
My experience as well with all my cars that were '06 or later. The 2005 Elise speedos were fast by ~ 7-8%. 120 MPH was actually ~111 MPH
Jack
'07 Exige Cup 255
'08 2-Eleven
