#81 (permalink) | |
Jif or Skippy?soulman |
#82 (permalink) |
Being near clueless in the area of auto-detailing, I thought I'd post a link to the single most useful document I've found to educate me on how to take care of my spyder (I only get to drool over the thought of owning an Elise for now)
It was written up by Dev on spyderchat, and is perfectly named 'Exterior Detailing 101'. http://www.spyderchat.com/phpBB/viewtopic.php?t=20887 |
#83 (permalink) |
Yah mon, it's irie !!!
OK... here's one for all you detailing experts. I got a gouge in the starshield on my front end from a flying rock. The hole has got some pretty noticable nasty looking edges. Any way of filling it in or smoothing it out without replacing the entire section of starshield?
#84 (permalink) |
anyone want something like this:
http://www.spyderchat.com/phpBB/viewtopic.php?t=22742 seems like someone should make these for the elise.
2005 Ardent Touring Elise, 2007 Hummer H3, 2007 Infiniti Fx35, 2006 Infiniti M35x (sold), 2002 Audi TT quattro convertible (sold), 1999 Corvette (sold but not forgotten), |
#86 (permalink) |
Patiently awaiting my car
Ok reviving an old thread.
So I looked at autopia.org and the whole place recommends SONUS. Is this THE detailers products? or are they just selling their own stuff? I would like an all in one something that I can just order everything and then use them. Or can someone recommend what i should buy from beginning to end for my car. I will primarily use this WHEN i get the elise, but i have a new 05 Acura TL that I will be using this stuff on. Any help would be much appreciated. I was thinking the Meguir's stuff, but then I see Zaino's is pretty good too.. where do I start? Ryan |
#87 (permalink) |
Weekend Warrior
Hi Ryan,
DavidB, the owner of Autopia.org, has rights to the Sonus brand here and sells products under the label. I believe it's otherwise a German brand. Autopia does hype a lot of products, but it's not all unwarranted. It's less the product, but the technique you use. I have not tried his entire line, but things that I have tried are very good. His SFX-3 polish (finest of the three) is a great finishing polish and is easy to use with a Porter Cable. I also have his green SFX Ultrafine clay, which is probably the least abrasive clay I have tried. It's great for mid year clean ups where you don't need much bite. I wouldn't hesistate to try all of his products, but there are more than adequate substitues on the market too. There are so many good products on the market that you have to find what you like to use best. The other thing to keep in mind is that no one brand has a complete line of products. Sonus doesn't have a wax or sealant. Zaino is missing some misc. items like a wheel cleaner (though you can just use car wash shampoo). Not a huge fan of Meguiar's, but you still get great results with their products. You could always try Detailer's Paradise's Starter bundle. It has microfiber towels, wash mitt, shampoo, and a lot of little items that are helpful. It doesn't have a real swirl mark remover or pure polish, so you may have to buy that on the side. A lot of this also depends on how much effort you are willing to put into this. How often to rewax, how much polishing you want to do, etc. - J |
#88 (permalink) |
I'm glad this thread was revived, I wanted to add a couple of things:
1. I know it's been pointed out, but it hasn't been emphasized enough for me - the dust on your dirty car combined with a high-pressure sprayer (even a normal hose with a good nozzle) become 'sandwater' (like sand paper). It will scratch your paint. A fine mist spray to completely soak the car left for a couple of minutes is a perfect start, to be followed by soapy water and a soft mitt or scrubber is perfect. 2. For those who don't want to take the time to tape all the open seams (like where the door meets the side panel), or who have a car that someone in the past left a wax buildup in those seams, I found a tool that makes removal quick and easy: First, get one of these: It is a surfboard wax comb, most designs will work, but the one pictured here seems to work best, it's called Wahoos wax comb, available from www.9star.com for $1.99, or most surf shops for around the same. It is made out of ABS or similar plastic, a fairly soft compound, which will not scratch paint. Then, starting from the bottom left corner as pictured, cut the comb in half diagonally ending the cut at the upper right corner. Be sure to start in the curved, half-moon shaped section at the left, not in the teeth on the bottom. All the teeth should remain together. A hack saw will go through the thing like butter, and if you put a little oil on the blade first, you won't clog the teeth. Now the corner where you started should have a couple of points of different sizes and angles. I have yet to come across the body panel I couldn't get one of those corners tucked into. You just run it back and forth a bit in the groove, and all the wax will flake right off. Once you get used to it, you can do a whole car in a couple of minutes. The leftover piece makes a great soft scraper, good for getting bird turds and tree sap off the car without scratching the paint.
Matt Jared Holstein (SCC) once wrote of a turbocharged Elise, "A bingo hopper doesn't have enough balls to slide it on the street." Well that may be true, but given the right street at the right time, I do. |
#89 (permalink) |
Weekend Warrior
Interesting idea for the seams.
Note that for the surface of the paint, it's usually not that towel or item you are using, but the grit or dirt you're trying to wipe away that scratches. I may give that a try for one specific area where scratches will not be visible. |
#90 (permalink) |
BRG '06 :)
Griot's is the brand I like. For car detailing and just keeping it pretty, there hasn't been a better soap, wax, sealer... you name it griot's probably has it. Plus, their products aren't ridiculously expensive. Just so you guys know what wax, or other car care product brand I recommend.
Ahh, can't wait to get my Lotus ![]() 2000 Honda S2000-Black/Red 1991 Acura NSX Coupe-Black/Black 1998 M-B ML320-White/Gray |
#91 (permalink) | |
AttAkker |
#92 (permalink) |
It's a Lotus
California Car Cover. In Los Angeles. Evolution car cover in blue. Keeps car clean. Fights dings. Keeps prying eyes and fingers away. What they can't see they don't touch. I swear by 'em - they'll make it custom for the Elise. Put it over the starshield.
2005 Saffron Yellow Elise. Stage II Exhaust. 2007 ProBax seats. "We know they're magical and worth every minute we spend on them. The whole Lotus owners' world is like a secret handshake among people who understand that." (R&T) |
#93 (permalink) | |
Dan D
I had a Jeep Wrangler that I also "almost" never washed with soap. I kept it out of the sun/rain when not driven, and just used mineral-free or distilled water, sprayed it down (lightly and often) at a coin wash, drove off so the wind could blow most of the water off, then would lightly dry the remainder with a clean cotton towel. I only off-roaded it about a dozen times, and only used soap when there was caked-on mud. The finish was always like new. I had the truck for 8 years before I finally waxed it, and there wasn't much of a difference after it was waxed. The only thing that REALLY helped to make it shine, was to dress up all the plastic, rubber, and metal. (It also helps to live in a very temperate climate.) I don't buy the arguments that you have to wax every ____ months, or ____ wax is much better than ____ wax. Bottom line is how you treat the finish from the start. I think the key to maintaining a good finish is, keep these things away: Detergents; Scrubbing; Sun, and use the cleanest, most mineral-free water possible. The Elise has been waxed once, but I have only washed it with soap 3 times. BTW.. a great little trick to make the undercarriage, wheel wells, etc. of a truck look new again: Armor All (or similar product). It works WAY better, and lasts longer, on metal than it does on plastic!
07 Exige S 265: GG, Track Pack, V1, RV Camera, S111 CF roof and splitter, 4.5-lb Voltphreaks battery, 10-lb Von Hep Exhaust, Green filter, 265 crank hp +/-, Volk TE 37 Wheels, RTDbrace, Scroth 6-point ASM harnesses, Innovative Motor Mounts, Saiku Michi Catch Cans. To come: IC fans, headers, and sport cat. 1955 lbs total weight (est w/tank half full) 05 Elise: Storm Titanium, Sport, Touring, Stage II (SOLD) (May '05 - Sept '06) |
#94 (permalink) |
CO Touring, April '05
Mine looks great
So -- I keep it pretty simple and am happy with my results. Wanted to give those that know better than I do a chance to share thoughts.
I use a cheap car-wash fluid. Had been using Zip-Wax Car Wash for about 15 years. Switched to Meguiars Car Wash fluid recently and am equally happy with the results. This leaves a thin layer of protection on the car and water does bead. Of course, I first rince the car with clean water at a low-medium pressure (not high!) and only then use a sheepskin-style sponge. I try to not let any part of the car dry with soap on. Then use a leather chammois to dry. Every so often, I immediately follow the wash with a Meguiars #26. I will never wax unless I washed first, otherwise (even invisible) dust will cause scratches. Very simple to do, doesn't require a lot of elbow grease. This clearly makes water bead up. If I'm really feeling work-happy, before I put the #26 on, I'll put a Meguiars #7 (show car glaze). This really does give an amazing deep shine, but needs a #26 afterwards to protect. For the wax and glaze I use a CLEAN terry cloth to apply, and a CLEAN lint-free diaper-type cloth to remove. I find it important to keep changing the cloth when removing glaze or wax, even if the cloth looks clean, it seems to get clogged up reguarly. Also the applicator cloth gets caked on if not changed frequently enough. I do one section of the body at a time, so as not to let it dry too long. I believe it's very important to, as all the instructions say, not do this in direct sunlight nor very hot climate. This cases the product to dry out and become very difficult to work with. That's about it. I use either Armor All Tire stuff or the tire dressing du jour. I do not spray, as the instructions would have you do, because overspray gets onto the paint. This results in an amazing looking car and a shine that lasts for some time. Would appreciate any feedback on this, and hope it helps someone. cheers, Albert. |
#95 (permalink) |
Super 7 Owner In Training
Thanks for your write-up. I have been satisfied with Meguiars wax, but have never tried a glaze. Next time I'll try it.
One thing I do different is the tires. I prefer the natural (not shiney) look, so I do not use dressing. Instead I begin my detailing by spraying the rims with Meguiars wheel cleaner. Even after 5000 miles my wheels are always dirty with brake dust. |
#96 (permalink) |
Nothing more to say but read this and this thread is done!
http://www.polishedbliss.co.uk/acatalog/guides.html |
#98 (permalink) |
I've just bought my first Elise, and am new to the forum. I've been reading all the great advice presented in this thread on detailing. But since I'm new to all of this, allow me to ask a somewhat ignorant newbie-style question...
How do I wash this thing? OK OK, let me explain. All my life I've washed cars in the usual manner. I spray the car off from top to bottom with a garden hose, apply the proper soap and water solution, and then rinse the car off with the same garden hose. But if I do this to my Elise, water and soap will flow into the radiator as well as the engine compartment. Is this normal and OK, or should I attempt to give the car a "sponge bath?" I imagine rain won't hurt the car, so spraying the car down shouldn't either. The owner's manual isn't clear about spraying. Any suggestions? Thanks in advance! BTW, my Elise has a hardtop. |
#99 (permalink) | |
You might also want to lift the engine cover and give it a rinse afterward to make sure the soap is cleared off. |
#100 (permalink) |
Here's an great car detailing guide put together by someone over at the S2KI.com forum for the S2000 - a lot of it applies to any car including a Lotus ...
http://home.comcast.net/~michael.coh..._Hand_Book.pdf
w00t w00t!! 2007 Exige S Aspen White (Delivery Unknown!) ..
