Old 10-05-2009, 05:19 PM   #1 (permalink)
Meow!!
darkSol's Avatar
How to reattach dead pedal? (pics)
Ok... at the track 3 years ago my dead pedal fell off when I pressed on it hard while braking.
Well I thought it would be ok... but I can't take it anymore and NEED to brace my left foot/leg against it while driving at the track...
So do I rivet it? Use some more adhesive?
Suggestions?
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is offline   Reply With Quote
Old 10-05-2009, 05:38 PM   #2 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
The dealer put mine back on a couple times The second seemed to do the trick.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is offline   Reply With Quote
Old 10-05-2009, 06:13 PM   #3 (permalink)
Meow!!
darkSol's Avatar
Unfortunately my dealer's 500 miles away
d.a..v...i....d
Old 10-08-2009, 04:29 PM   #4 (permalink)
Bane's Avatar
Images: 4
$599 PPE header (INFO)
2007 BMW 335i - Mostly stock
un-Official LotusTalk Stealth Bulb provider *6* sets in stock!
Old 10-08-2009, 05:44 PM   #5 (permalink)
Regurgitated User
fitfan's Avatar
you certainly don't want to drill and rivet into the chassis main monoque. glue it!
Driving it around!
fitfan is online now   Reply With Quote
Old 10-08-2009, 08:50 PM   #6 (permalink)
Meow!!
darkSol's Avatar
I just used a wire wheel in a drill to scrape all the remaining betaseal off the dead pedal... then I drilled two 1/4 holes in the rear mounting flange (front's too difficult to reach)
I then applied a liberal amount of JB Weld on it and smooshed it into position.
I'm going to let it set overnight and tomorrow drill through the holes into the chassis and put two pop rivets in there to ensure it's not going anywhere.
Thanks for all the help guys!
Done!
d.a..v...i....d
Old 10-09-2009, 04:33 AM   #7 (permalink)
A pound at a time.
I would not recommend drilling into the chassis.
07 Exige S - PhB., TP, TP, LSD, S111 Rear Panel Delete, 2Bular De-Cat, 2Bular 8x24 Burnt GT3, Custom AEM Intake, 6k HID's, Schroth 4pt ASM Harnesses, Milled Steering Arms, Bronze Volk TE37 w/ RE-01R's, Carbon Craftsquare Mirrors, Carbon Front Lip, Benetec Dry Carbon Undertray/Diffuser
Sh4rkattk is offline   Reply With Quote
Old 10-09-2009, 04:45 AM   #8 (permalink)
06 elise
MNlotus's Avatar
+1
2006 Lotus Elise-way too many mods to list (k24 swap planned. 300+whp)
http://www.youtube.com/watch?v=tjIcCsvhWvY
2003 Caterham Super Seven DeDion
http://www.youtube.com/watch?v=Z1ysO...e=channel_page
MNlotus is offline   Reply With Quote
Old 10-09-2009, 04:55 AM   #9 (permalink)
Parts scattered about...
MaineLotus's Avatar
Why not? Remove the interior trim pieces and carpet and you'll find a lot of holes drilled in the chassis. Drilling a 3/16" hole for a rivet is not going compromise the integrity. Glue and rivets is the proper way to attach the foot rest. A chunk of loose aluminum behind the pedals is a potentially bad situation.
My car is modified.
MaineLotus is offline   Reply With Quote
Old 10-09-2009, 09:12 AM   #10 (permalink)
TimMullen's Avatar
Images: 19
The aluminum of the chassis is actually very thin, and not really a good candidate for attaching pop rivets. The shapes of the various extrusions bonded together is what gives strength to the chassis. Any holes drilled in, and things attached that will stress the rivets/holes is probably not a good idea. Almost all of the rivets in the chassis are not there for structural strength, but were used to "jig up" the chassis - to hold it in position - so that it could be placed in the ovens to cure the "glue".
The proper way to attach that foot rest is to use the proper type of "glue" to hold it in position. If the glue won't hold it, the pop rivets aren't going to either, and when they pull out, you will have caused damage to the chassis.
94 Miata R Package - Black
Old 10-09-2009, 09:41 AM   #11 (permalink)
Meow!!
darkSol's Avatar
Well the JB Weld will hold the pedal on for sure... the two small pop rivets are only going to assist in any possible lateral shear. I'll plop a small blob of silicone in the hole and over the rivets afterwards so there's no possibility of moisture infiltration...
The factory BetaSeal didn't hold the pedal on - so that's not an option... in fact it failed in less than 11 months after it was applied at the factory - and there was a LOT of it on there.
More than anything I don't want that pedal to come off again... there's nothing scarier when you're braking HARD downhill from 120mph to 70mph and your left bracing foot suddenly pushes all the way down... and the dead pedal lodges itself underneath the clutch and brake pedals. The driver seat dry cleaning bill was substantial. Never again!
d.a..v...i....d
Old 10-09-2009, 09:57 AM   #12 (permalink)
MaineLotus's Avatar
Lotus uses rivets to attach many things to the chassis, and not always with glue. I know because I have drilled many rivet heads off to remove pieces from the chassis. Adhesive usually fails instantly - I'd much rather have the rivets exhibit a loose feeling in this situation. A loose foot rest under the brake pedal is a bad situation.
My car is modified.
Old 10-09-2009, 10:04 AM   #13 (permalink)
TimMullen's Avatar
Images: 19
Old 10-09-2009, 06:58 PM   #14 (permalink)
Meow!!
darkSol's Avatar
All done. It's not going freakin' ANYWHERE...
d.a..v...i....d
