#1 (permalink) | ||
Future 2ZZ-GZE member...
How To Test Your Compression
Compliments of Smaay:
http://www.newcelica.org/forums/showthread.php?t=227280 Quote:
![]() Im betting those coils have something to do with his CEL/misfire codes! Looks like they have been sitting in some water... if you have a lab scope or graphing multimeter and an amp probe/clamp you can do an overall compression check in a few minutes without removing any parts. just graph the current ramp for the starter during cranking (pull fuse for fuel pump to prevent starting) with the clamp around the battery cable at the starter and sync the trigger off of number one cylinder .it wont tell you specific psi but all ramps will be even on a sound motor and if you have one ramp thats alot lower than the others, you can count in the firing order off of your sync to find which cylinder it is and do a real test on that one cyl. If your engine isnt running bad or other mechanical problems then this prob wont be much use to you, but it has saved me a ton of time on engines that are fairly hard to reach the plugs on and show signs of compression issues, since i didnt have to go looking at 11 other cylinders first (murphy's law will ensure the low cylinder is the last one checked, always!). This current ramp graphing method is also good if you have a low amp probe and need to check injectors when chasing rough running issues with no codes, since the electrical properties of coil windings and thier signature when open/closing/sticking are the same no matter who makes the injector. |
#3 (permalink) | |
short angry bloke
torque (tôrk) n. - an excuse for the lack of momentum. - let's bring back CanAm & Group B! - have you hugged your Exige today? I'm currently working on my performance driving merit badge. There's always somebody faster, sometimes it's me. |
of course jtj is the man!!
06 Arctic Silver Elise | Touring, Traction Control, Super Charger, 2bular 6" Exhaust, Nitron Sport Pros, RTD Brace, FoCal Speakers All Around, Pioneer Premier Unit, V-Force Bar, Schroth Harness, Defi Boost Gauge, Innovate A/F Gauge, Optima Red Top (yeah its heavy, but I don't need a jump anymore.). 08 Black Sierra Denali |
One thing that was skipped in the instructions.
When you are cranking the engine, open the throttle fully. It does make a difference in the pressure readings that you will get, and it will come up to full pressure much quicker (with less drain on the battery). As noted above, I'd pull the fuse for the injectors rather than disconnecting the wring for them. Also, check the engine manual for the car that you are going to do a compression test on. On some of them (for instance the "wasted spark system used on early Miatas), cranking the engine with the spark plugs disconnected will often burn out the coils requiring them to be replaced. That shouldn't be a problem in this case since the individual coils are removed (and on the Miata the proper way to do the test is to disconnect the separate coils).
#6 (permalink) | |
Elise #76
"12. Hold down gas and clutch at the same time, crank engine over about 6 times, until needle stops jumping on compression tester"
Owner of '05 Elise S/T- touring- LSS-Stage 2 '07 Audi RS4 4.2L V-8 420 HP - 6 Sp..(sold) '07 Toyota Prius |
#7 (permalink) | |
Doh...I saw the hold down the clutch - missed the hold down the gas part. Sorry. Nevermind...
#9 (permalink) | |
Another quick test you can do with many cars (although I have never tried it with a Lotus) is a cylinder balance test with a graphing multimeter, scope or a scan tool that will show a pid graph for a component and freeze frame it.. I use this on jags to verify injector faults/repairs, but its prtetty generalized for any car that can be forced into open loop with a wide band o2. put the car into open loop, usually pulling the number 1 injector plug while it is running will do this on nippondenso based systems. while the dtc is set, the ecu will ignore 02 input for fuel map/injection and use a preset base line. the 02 will still read the ratio however because it doesnt know its being ignored. dfepending on the tool used you can get an actual reading or a voltage in the case of a scope backprobed into the sensors harness . then, while running the o2 voltage graph over enough time to see all cylinders on that bank in one screen shot, pull one injector plug at a time long enough to see a viewable waveform then plug it back in long enough to return to the engine baseline ratio before unplugging the next one. then you can compare exactly how much fuel each injector is dumping in relation to the others on that bank (especially easy when a "picture" of them all is laid side by side to compare.) wide bands are extremely accurate and this will show something like a dirty injector nozzle that otherwise might not show in other tests and without dissasembling the injector rail etc. it can also verify faulty 02 sensors if you have one thats possibly stuck/dead/lazy and want to see an actual value change at the sensor, although a scope is better for that due to refresh rates etc. Last edited by jtj : 10-09-2007 at 02:55 PM. |
#11 (permalink) |
Maybe I missed it, but I didn't see battery voltage and engine temp mentioned. Both can alter your readings slightly.
Leak down tests will also help diagnose issues that compression tests may miss.
Everything I post is my opinion, and tends to be notoriously WRONG. Anything that is correct, can only be attributed to my being dropped on my head as a small child - repeatedly. Most of what I know is a result of breaking something first. |
#12 (permalink) |
ZAMMY
RASTA: WELL DONE!
JTJ: GOOD TIPS ON DIAGNOSIS! auto techs are no longer 'greasemonkeys'. many are highly trained and capable. when it gets down and dirty on a subtle problem there's no substitute for training. sam |
#13 (permalink) | |
#14 (permalink) | |
Grrrrrr Baby
2005 Lotus Elise LSS 2003 Corvette 50th Anniversary Convertible |
#15 (permalink) |
Meow!!
TurboPhil and I just did a compression test on my engine...
140, 140, 140, 140 - like clockwork. Funny thing is that it pulls like a freight train, doesn't burn any oil and the plugs looked fine (well a bit of detonation but no blown off tips or anything like that). WTF!
#16 (permalink) | |
Mods are good for you
2008 Solar S240 Exige 2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt |
#17 (permalink) |
Plug Whisperer
I thought maybe the gauge was off too, so I hooked the gauge to my air compressor. The compression tester agreed within a psi of the pressure I had in the air compressor leading us to believe the tester is accurate... Perhaps we're over-looking something here, or perhaps Dark's compression rings are a bit toasty from running so lean for so long
If the latter is the case, it's fortunate forced induction tends to mask low compression As long as there' no oil blowing, we just need to up the boost--- once we can tune for it![]() Best, Phil
#18 (permalink) |
Did you hold the throttle wide open while you cranked the engine? If you don't, the engine can't pull in enough air, and the compression readings will be low.
Is your car a "Throttle By Wire?" If so, does the ECU keep the throttle closed under the cranking conditions? The fact that all the cylinders are reading consistent usually indicates that things are well, and the readings are low for some reason.
#19 (permalink) | |
Plug Whisperer
Best, phil
#20 (permalink) |
My Milton has a value screwed into the end of the hose. It has to be a special valve. A normal tire valve will give you low readings.
could be, no way it's 140
2005 Elise Storm Titanium |
