Old 04-14-2005, 10:32 AM   #1 (permalink)
San Antonio Rider
Jacking the Elise and Placing on Jackstands
I am getting ready to send my wheels off for some powdercoating and therefore I need to remove them from the vehicle. My dealer wouldn't let me house the vehicle on his lift for the 4 days that it will take to get back from the shop.
They recommended me to just jack the car up and place them on jackstands.
Couple of questions:
1) Any recommendations on quality jackstands and a jack?
2) What are some good points on the vehicle to jack the car up? I was looking to jack the front and then the rear. I want to avoid having jacking the car up on one jackstand at a time.
Thanks
blakazian is offline   Reply With Quote
Old 04-14-2005, 11:33 AM   #2 (permalink)
TimMullen's Avatar
Images: 19
You can't do that. There are specific points to place the jackstands, and this info is listed in the owner's manual. You can lift one side of the car from the balance point on each side of the car (one side at a time). There are front spots marked to place jackstands, but the rear spots are under the "under tray" which must be removed first.
DO NOT place jackstands anywhere but the "official" jacking points, unless of course you want to punch holes in the chassis or bend it...
Check this thread.
And this thread.
Here's the lifting points from a service manual:
<img src="http://www.elisetalk.com/gallery/displayimage.php?imageid=1000&original=1" alt="Jacking Points" />
94 Miata R Package - Black
Old 04-14-2005, 06:13 PM   #3 (permalink)
I've been meaning to ask about this. Couldn't you jack up a side at point A, put jackstands under B and D, and then go around and do the other side? Seems like this would work to get all 4 corners off the ground.
Raindem is offline   Reply With Quote
Old 04-14-2005, 06:39 PM   #4 (permalink)
JediMindGamez's Avatar
i dont have any recommendations on jackstands but if you already have some jackstand that don't have rubber padding i find that ice hockey pucks work quiet well...
You can't rationalize cars like these, they're not something you buy with your head, you buy them with your heart because you love them and who can explain love. All I know is I love my lil elise more then I like any other car...
JediMindGamez is offline   Reply With Quote
Old 04-14-2005, 06:54 PM   #5 (permalink)
Elise Fanatic
sleepless's Avatar
Be very careful how you place the jack at point A; I accidentally caught a bit fo the body and ended upwith a 9 inch crack in the rocker panel
Pete
05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo
sleepless is offline   Reply With Quote
Old 04-15-2005, 12:41 PM   #6 (permalink)
San Antonio Rider
Stickers
ok...I just happened to look under the car today for the Jackpoints described in the manual...I found it but is on the metal underpanel...
Do I need to take that off to actually connect with the chassis for the jack or do you just put the jack right on top of that sticker?
Old 04-15-2005, 12:52 PM   #7 (permalink)
Finally Elise Driver!
Miguel's Avatar
Read the instructions for C and D it says:
C; The engine undertray/diffuser panel must first be removed ....
D: The engine undertray/diffuser panel must first be removed ....
It's only one page to read
Edit: and just in case, for a 4 point lift they recommend B and C
05 Elise Racing Green/Red, Touring, Hardtop, StarShield
Miguel is offline   Reply With Quote
Old 04-15-2005, 12:59 PM   #8 (permalink)
San Antonio Rider
Ok Mr. Smarty
I saw those instructions...but I am talking about Point A.
This is the point where you place your jack lift...
This is the point that I am talking about...C and D are possible jackstand placement areas and that I do understand requires the removal of the Diffuser.
In the book it doesn't say anything about Point A and the underpanel...that is why I was curious...
Has anyone jacked their car up on their own yet?
Old 04-15-2005, 01:15 PM   #9 (permalink)
Miguel's Avatar
I did, and didn't have to remove the difuser for the side ones (A) just make sure you are carefull because of the body is very close to the jacking point.
After lifting it my friend and I put the jackstands before removing the front panel when I changed my horn. http://www.elisetalk.com/forums/show...?t=5799&page=3
Sorry no pictures of the car being jacked up. But I don't remember if the rear diffuser got in the way since we didn't have to work on that, but I don't think it will interfere
Old 04-15-2005, 01:17 PM   #10 (permalink)
TimMullen's Avatar
Images: 19
Point A is the "balance point". If you were to jack up the car and use jackstands under Points A and B, the car might rest there, but any bit of extra weight on the rear (like a hand or a full tank of gas) and the car will flip backward off the jack stands at Point A.
To lift the car completely off the ground, you have to place jackstands under both sides at Point B and either Point C or Point D.
Point A is only to lift up one side of the car lifting both wheels on that side off the ground, while both wheels on the other side remain on the ground.
I suspect that the best way to lift the car at home is to drive the back up on ramps, remove the under tray and diffuser, then put the car on the ground. Then lift at point A, place jackstands at B and C, and repeat for the other side.
Old 04-16-2005, 01:28 PM   #11 (permalink)
San Antonio Rider
Success!!!
Well I have successfully jacked up the vehicle without destroying anything so that is good.
Off to the powder coat shop...I will have to post pics once I'm done...should be about a week.
Thanks everyone for your insights
Old 04-05-2007, 10:59 AM   #12 (permalink)
masheen's Avatar
i am thinking of raising the entire car off the ground and onto stands by myself, and getting all the wheels off to take them to a shop to get new tires installed, because i don't want to run the risk of insulting the mechanics when telling them how to change the tires on this car, or have them ignore those instructions, or have those instructions as an excuse to charge me a lot more.
so, some questions,
blakazian, or anyone else who i expect followed TimMullen instructions,
did your car feel unstable at any point during this? i am trying to imagine all this and in my mind it looks potentially unstable at times.
all,
i can't look at my car now - i am wondering if using point C really requires taking the diffuser off - seems forward enough that only taking off that panel that is taken off during the oil change (the undertray i guess) is enough and that the diffuser (which is further back) can stay in place. so is this maybe the case? also, the manual uses "/" which could mean one "or" the other.
masheen is offline   Reply With Quote
Old 04-05-2007, 11:05 AM   #13 (permalink)
Ian
Certified Fun Stopper
Ian's Avatar
I did this when I got new tires as well. I just lifted at point A and brought in 2 at a time. (I realize I probably should have used jackstands, but I'm rather lazy and did not want to remove the rear undertray.
'06 Exige; Polar Blue; Track/Touring/Stage II/LSD-TC
Old 04-05-2007, 11:09 AM   #14 (permalink)
Randy Chase's Avatar
Images: 761
I have raised the car off the ground (all four wheels) many times. You only need to remove the panel under the engine to access points C. Jack up one side under point A. Place a jackstand under Point B. Place another jackstand under point C on the same side. Lower the jack onto the stands. Repeat for other side.
What you will notice is that the stiffness of the Elise's frame means that the car can be supported on three points easily, or even two (not recommending this!), so that means it can be difficult to get it to sit down on all four points evently. I don't worry about that too much.
And don't use crappy jack stands...or get lazy and not use any stands. Read this-
http://www.914world.com/bbs2/index.p...pic=70117&st=0
Please do not PM me. My box is full. Thanks.
Old 04-05-2007, 11:29 AM   #15 (permalink)
masheen's Avatar
two at a time - i didn't even think of that. thanks. i may do that next time.
Old 04-05-2007, 11:30 AM   #16 (permalink)
masheen's Avatar
Originally Posted by Randy Chase
I have raised the car off the ground (all four wheels) many times...
thanks. i feel more confident now.
And don't use crappy jack stands...Read this-
all jack stands appear to be the same. what is the thing to look for?
Old 04-05-2007, 11:31 AM   #17 (permalink)
GR8 SCAPE
waydui's Avatar
FWIW, I only used Points A & B to get all 4 wheels off the ground.
I lifted one side first at Point A. Put bricks/blocks under Point B. Left original jack at Point A.
Used another jack to raise other side of car at Point A. And then put same brick/block supports under Point B.
Car was rock solid, no wobbles, etc...
Pics show it better. Same set-up for each side of the car.
Regards,
Wayne
_______________________
Old 04-05-2007, 11:33 AM   #18 (permalink)
Images: 761
You want something with a secure pin in it.
http://www.elisetalk.com/forums/show...ht=jack+stands
Old 04-05-2007, 11:35 AM   #19 (permalink)
Meow!!
darkSol's Avatar
Wayne,
That's the scariest thing I've ever seen - well maybe you could add a rabbit or something to play underneath.
The wind up jack looks like the trigger on a mousetrap.... SNAP!
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is online now   Reply With Quote
Old 04-05-2007, 11:42 AM   #20 (permalink)
GR8 SCAPE
waydui's Avatar
Hi David,
Yeah, it looks pretty deadly I'll admit.
I spent hours on my back under the car like this doing the brake caliper paint job. And I'm still here to tell the tale!
Definitely won't do it that way again.
Wayne
