Old 10-01-2009, 12:21 AM   #1 (permalink)
Need help. Car won't start
2005 Elise. Was sitting in my garage for around 5+ weeks without being driven. I plugged in a Battery Tender (BT) to the car's power outlet a few days ago and let it charge. It appeared to be working as the LED on the BT illuminated. Went to start the car this evening, but none of the electrics appear to work. The immobilizer light on the tach no longer flashes either. I checked some of the fuses and they appear okay.
Is there some sort of reset procedure or switch I need to activate? Could the battery be completely dead? The interior cabin light does not illuminate either.
Also, when I re-plugged the BT into the car's power outlet the LED on the BT did not illuminate. It appears it is no longer charging the car.
Craig
SoCal Craig is offline   Reply With Quote
Old 10-01-2009, 12:25 AM   #2 (permalink)
Frogot to mention, car still has OEM battery.
Craig
Old 10-01-2009, 12:59 AM   #3 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
tender wouldn't likely be enough to recharge it....but it might be smoked.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is online now   Reply With Quote
Old 10-01-2009, 04:29 AM   #4 (permalink)
Alarmed & Dangerous
TheViper's Avatar
The Battery Tender is a very low amperage trickle charger that does not have sufficient output to charge a depleted battery. Either jump start it and run it for an hour or so (preferred), or buy a true battery charger. Even "smart" chargers will not charge a very low battery, as they interpret the low voltage as a defective cell, therefore an old fashion "dumb" charger may be needed. As it is the original battery, it might be a great opportunity to replace it with an AGM which can't leak or give off flammable gas. Battery Choices & Information
Old 10-01-2009, 01:43 PM   #5 (permalink)
tesprit's Avatar
+1 for everything TheViper said, but seeing as this is the original batter from '05, I think it would be better to just buy a new battery instead of playing around trying to charge that old one. That old battery appears to be completely depleted and the chances of it coming back to life are probably poor at best. There is no use trying to jump a battery that will not accept a charge. If you manage get the car started with a jump, it will just put a heavy load on the alternator and who needs to replace an alternator because it was trying to charge a bad battery and that battery ends up damaging the alternator in the end? Batteries are cheap and easy to replace, just go buy a new one.
Old 10-01-2009, 05:37 PM   #6 (permalink)
Thanks everyone! I ordered the Braille battery and Xtender from S111
The OEM unit was probably bad as I had let it discharge a couple of times prior during it's life.
Craig
Old 10-01-2009, 05:45 PM   #7 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Just be aware that disconnecting the battery will mean you can't use the alarm, the radio presets loose memory.
Old 10-01-2009, 08:00 PM   #8 (permalink)
Thanks. Car sits im my warehouse unlocked most of the time, so the alarm is probably not an issue.
Craig
