Need Help with Shear Panel Re-torque
I've read from many previous post that a lot of the rattle noise is a result from the sheer panel and a simple retorque of the fasteners would fix the problem. I'm planning to give this a try. Does anyone know what lb-ft to retorque the fasterners to? Also any other tips from someone who have already done this would be very much appreciated. Thanks.
'08 Honda S2000 CR (Rio Yellow Pearl) '07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '04 BMW 330 ci (White) |
insert clever title here
While down there, you might want to stick some small pieces of foam between the shear panel and the gas tank.
Maybe I'll use some type of rubber that won't absorb water.
Does anyone know what lb-ft to retorque the fasterners to? Thanks.
#7 (permalink) | |
The fix should be to loosen all the bolts, and starting with two bolts in the middle on the "long" side (one on each side), tighten them down. Then tighten two in the middle on the short side. Then work your way out to the corners. The idea is to stretch the panel out so that it remains flat. If you start with the corners, you will most likely end up with it bowed in the middle. It's probably art as much as science...
#8 (permalink) | |
Since the Shear panel is structural, I want to make sure I torque the bolts correctly. Does the service manual list what lb-ft to torque them to? I don't have the service manual and I don't think the site that has the download is working yet.
#9 (permalink) | |
From an earlier post: The only thing even close that I found was the spec that the fuel tank cradle should be tightened to 24 Nm - these are tightened into "nut-zert" type of fittings in the chassis. The under tray screws are held on by "threaded clips", and are probably to be tightened to the highly technical of "tight enough", but not too tight. Which is better than the less technical value of "tighten it till it breaks and then back it off a half a turn". At least the clips are replaceable if you tighten them too tight and strip them. I'd be very concerned about the fittings that are bonded into the aluminum - but then the 24 Nm might apply to those - but I assume no responsibility if you use that value... ![]() Bottom line is that no one knows (or at least has posted that information) Try to get a feel for how tight they are when you remove the bolts???<!-- / message --><!-- sig -->
#10 (permalink) |
926
I hate to admit that I don't know, but where/what exactly is the "shear panel," that you're refering to?
'06 Elise, SoY/Red, Touring, Sport, LSD/TC, Hardtop, Stage 2, 4tress/Schroth, Micro/Multivex, Alpine/Focals/JLsub, CF console & A/C surround, Ultradiscs/R4s/stl lines, Extinguisher, Tow Hooks, Blackwatch key, RTD Brace, Ohlins, Traqmate, Katana Supercharger, Shifter reinforced. |
#11 (permalink) | |
#12 (permalink) | |
#13 (permalink) | |
2006 Cup240 #10 |
#14 (permalink) |
Thanks. Didn't expect to get an answer after over a year.
#15 (permalink) | |
2006 Cup240 #10 |
#16 (permalink) |
really light stuff
![]() Join Date: Jul 2003
The shear panel was very noisy on my car... when I tapped it with my hand it rang out quite a bit. I just spent a good deal of time removing and replacing the panel, with some strategically placed sound deadening material (Dynomat).
Now the shear panel is behaving.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel To Order RLS Product Links |
#17 (permalink) |
Resident Drunk
24Nm converts to 17.7 ft lbs, but my torque wrench only goes down to 20 ft lbs, is the 2.3 ft lbs going to make a big difference?
2005 BADA55 Lotus Elise ![]() 1993 Black BMW 325i 2000 Solar Yellow MR-S - SOLD 1987 White on White Porsche 944 Turbo - SOLD 1993 Maroon Lexus SC400 - SOLD |
#19 (permalink) |
Resident Drunk
nm... im an idiot
![]() after researching this problem and assuming it was my shear panel rattling, i ended up renting a crappy torque wrench from advance auto parts to torque the shear panel bolts down, then i get home and realize that one of my carpet buttons had come undone and was underneath my seat making the rattling noise ![]() at least it was an easy fix ![]()
#20 (permalink) |
Holy Guacamole!
^^^ LOL
I've also found that the "Y" in the e-brake cabling can rattle against both the shear panel above, and the undertray below... a bit of well placed Velcro loop material makes the sound just about disappear
My videos: http://www.youtube.com/user/apk919 2007 Aspen White Lotus Exige S (street ride) ![]() 2010 Isotope Green Lotus 2-Eleven (track ride) Lotus Challenge Series
