Oil Cooler/Line Failure at speed
Was traveling North on I95 between Washington and Baltimore yesterday when at about 75MPH noticed a change in engine note. Let off throttle, noise went away, back on throttle, definitely something not right. As I worked my way over to the right lane, the oil pressure light came on. Clutch-in, and started coasting. Light flickered a few times, then solid on. Once it was on full, I turned off engine and coasted off the Rt175 ramp all the way to a gas station at the end of the ramp. The time the engine was on and first noticed issue until I shut down was approx 1 minute (probably less).
As I got out of the car, I was greeted to the whole left side of the car covered in oil, with more flowing from the oil cooler location. Took four hours to get a tow truck that would tow it to Criswell, most wanted nothing to do with towing the Lotus. One guy came by and said he would never trust the tow ring to pull it onto flat bed. Waiting to hear back from Criswell today... |
not good. sorry to hear. best of luck...
[Ovarian Odorist] 11:12 pm: why did you ever get into your business rob...you have such great potential in the adult porn industry.. |
User Restricted By ΑDMIΝ
Wow, that's unfortunate, to say the least. I hope it's nothing major and you're back on the road soon. Keep us informed as to the cause/fix!
2007 AW Lotus Exige S. Factory Opts: Track Pack, Touring Pack, LSD Latest Mods: Sector111 RTDBrace, V3 eliminator, V2 Steering Arms & UltraDiscs, ChaseCam/Traqmate, Innovative 60A Engine Mounts, Moroso pan, NitronDA & Eibach 525/650, Gotham265, ReVerie CF front splitter, "banana" rear wing, and 5 element diffuser, TWRD CF side scoops, custom intercooler ductwork, Saikou Michi catch cans, TRD/Lotus Cup Air Box, Hawk HT-10 brake pads, LPL muffler My videos: http://www.youtube.com/user/apk919 |
The car crossed 20K the day before. I have had no issues with the car until this incident. It has run like a champ. No tell-tale oil leaks before hand, the hose/cooler just let go with no warning.
Obviously I am worried the engine was harmed, but will still appear fine after they fix the cooler/hose and refill. Not looking forward to a prolonged warranty fight. Given the number of Elise's that have had similiar incidents, it is worrisome. I usually just worry about my tie-rods falling off while driving, I did not think I had to also worry about the oil cooler exploding! Yesterday was the first real warm day here also, so a bad time to not have the car running. Oh well... |
Head LOONY
This does not sound good to me. First thing I would have them check are the rod bearings. Those are the first to go when you lose oil pressure.
Been there and done that on other Lotus cars. Not the Elise..but an Elan. I doubt you toasted the engine, but you may have run the bearings down to the copper....
Tony Vaccaro 2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter, www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances |
#7 (permalink) |
-30-
GJS, i wish you "good luck" (inclusive of all its possible meanings) with your service adventure.
2007 Exige S, Storm Ti. Sport, Track and TC.Plus: Multivex Mirrors, S111 Deltabrace, Sparco 6Pt harnesses (w/Ti Dave's Antisub belt mount), I/O Port video mount, Snorkel delete, Shims out, Rearview Mirror delete, 2Bular 7X18, Pagid RS42's, Saiku Michi catch can and, of course, blingy carpet buttons. 08 M-B ML320 cdi, 08 Toyota Tundra SR5 5.7, 06 M-B E320 cdi, 02 Lexus LX470, 97 Bobcat 751C The Red Pill Ignore Me *Be sure too save your IL before browsing away
#11 (permalink) |
Hydrocarbons Rule
I would talk to them about giving you an extra year or so warranty on the engine due to possible damage/wear that may not rear it's ugly head for some time.
#12 (permalink) |
Just heard from Criswell. As Jordan guessed, hose pulled out of crimp. Had it shipped back to Lotus, supposedly this has been happening more often and it sounds like they are starting to get concerned about it.
Criswell says engine is fine, started up and no noises. Wow, what a detailed analysis. I will go get it tomorrow and see if I agree. If running well, I will perform routine oil analysis on it. Interestingly, Lotus warranty wants me to provide detailed records of my oil changes... I would assume so that they can try and build a case against me in case the engine takes a crap. Luckly I have changed oil and filters every 3K miles. |
#13 (permalink) | ||
-30-
![]() Quote:
like i said earlier "good luck" ![]()
#17 (permalink) | |
V Not my picture V
#18 (permalink) |
The same thing happened to me at 13K however I developed a slight ticking and Lotus replaced the engine. I have 7k on the new one. So far so good!
Make sure you listen to the engine carefully any change in "sound" take it in and have it documented.
05 Lotus Elise R/K Supercharger, Moroso Oil Pan, RTD Brace, High Volume All Aluminum Radiator, Stainless Steel Break Lines, Oil Catch Can, ACT Clutch, HID, Carbon Fiber Spliter, Reverie Side Scoops, CF side skirts, FF gauge pod, BWR gauge pod, Cup Air Box, S111 front & rear tow hooks, upgraded tail lights-LED, Driving lights, LETSLA, ...
#20 (permalink) |
Ex and future Lotus owner
Is there a way to check the crimps on the oil coolers to make sure the lines are tight enough? It sounds like this may be something that preventable with a check now and then. Hope your car turns out OK.
the1sen: why move forward with design when you can recreate a monstrosity from the past? |
