I <3 chicken, I <3 liver
Perceived problem with exhaust system
something happened to my exhaust while driving yesterday. It was much louder (and more drone) than usual so I pulled over and couldn't see any obvious cracks or anything on the can, decat, flex pipe or the header. The clamp was on there tight, I'm thinking maybe the flex pipe is damaged? The car probably would stall a lot if there was an exhaust leak, but it behaved pretty much the same as before. I really haven't heard about any failures on the 2bular systems. I'll smoke test it by week's end to find out. Could the muffler's packing be damaged and cause it to sound loud?
Just wondering if anyone else had experienced something like this. I know the stock cat's welds will fail and that would make it loud, for example.
Learning Self-Control
Your car sounds loud?
![]() Your car IS loud!! ![]() And are you saying that it's now some sort of problem? ![]()
07 Lotus Elise – Krypton Green – Sport Pack, Touring Pack, Cilajet, Stage 1 Exhaust, Pagid Blue brake pads, Other Sector 111 / BWR Accessories 02 Mazda Miata MX-5 SE – Blazing Yellow Mica – Hard Top, Boss Frog Clearview Roll bar 05 Mazda3 – Laser Blue, 2.3L 84 Mazda B2000 SE Pickup – White – 296,000 miles |
my stage 2 exhaust broke and started rattling inside
05' US Elise.190hp,HRM edition,Sport pack,Touring pack,starshield,custom painted engine covers,S111 boomerang rear hook,k&n air filter,Stage II exhaust(actually just customised),Lotus driving lights,Infinity speakers,Lid Bone,V1 radar with remote audio/display,JVC stereo-subwoofer-rear cam,TRmotorsports wheels,lightweight Braille battery,alotaluv.... |
NOT ßANNED!
I had one of the "downpipe" spring loaded bolts come loose, which made it extremely loud.
#7 (permalink) | |
ΒÄŅNED
Definitely inspect all the joints and bends for cracks, fittings for tightness, and muffler packing...
#8 (permalink) | |||
But for it to be this much more drony and loud would be a big crack or the muff being f*cked up.
#9 (permalink) |
Project Nirvana Elise
![]() Join Date: Mar 2003
Ara, all exhaust are getting brutalized by SC. I've seen and heard about all makes failing so don't be surprised. Truth is, an exhaust is a somewhat consumable item in these cars. We have been testing TurboPhil's new race exhausts (both Fatty & Skinny) on our Elise. They are pretty cool but do need to be repacked as the internal material will get consumed. Smart solution for a common problem.
#11 (permalink) | |
update: I smoked the exhaust system and no leaks that would cause the loudness and drone. Tripoint agreed it was the packing that had been damaged. Hopefully I can get a new one soon because I'm wearing my earplugs again.
![]() Quote:
#12 (permalink) |
British by extrapolation
My Janspeed Stage III produced some smoke after I first installed it. That normal? It sounds ok now, especially around town, but on the freeway at 3.5k RPMs its horribly loud when I need even a small acceleration (but steady speed is fine). Not sure if that's just a resonance thing or not. I'm not sure what they are supposed to sound like so I don't know how to gauge it.
#13 (permalink) |
I have had several exhausts "blow out" after about 4000 miles of driving. It's the high rmp's that do it. You just burn out the packing. It's pretty normal if you track the car. By the way, i have used the factory CAT and two different sport cats, didn't make a difference.
'07 Exige S,LSD,2bular Header,SportCat & GT3 Exhaust,Gotham Tune ECU, V2 Fuel Cell,BOE Surge Tank,MWR Fuel Rail,RLS Intercooler&Pipes,CircuitWorx Oil Pump Gears,Moroso oil pan, Accusump,Fidanza 3.2 Kevlar Clutch & Alum Flywheel,Nitron GT3,V2arms,AP Racing Brakes(315mm),SS Brake Lines,Prototype Composites CF Roof,ReVerie CF Front Splitter,diffuser & 1650MM Wing,RTD Brace, SSC Shift Cable, Lotus Racing M Mounts/High Perf.Air Box,Defi Gauges,RAC Monolite Wheels,Safecraft 5 Point Harness,Traqmate. |
#14 (permalink) | |
06 S280
#15 (permalink) |
ah damn, i didn't know all that otherwise I would have said something. I have the header & decat ceramic coated also, so that's keeping the heat in along with 270whp pushing through.
#16 (permalink) | |
06 S280
No wait on shipping! |
#17 (permalink) | |
you said
05 Lotus Elise R/K Supercharger, Stage II, Moroso Oil Pan, RTD Brace, High Volume All Aluminum Radiator, Stainless Steel Break Lines, Oil Catch Can, ACT Clutch, HID, Carbon Fiber Spliter, Reverie Side Scoops, CF side skirts, FF gauge pod, BWR gauge pod, Cup Air Box, S111 front & rear tow hooks, upgraded tail lights-LED, Driving lights, LETSLA, ...
#18 (permalink) |
06 S280
You would have to ask Jim... He is an exhaust god, so I trust him and his building skills. He was concerned about the heat and power that I put out at my levels (292hp) and said he would pack it himself.
He said the 8" would be fine though since it is much larger and won't get as hot. |
#19 (permalink) |
Wizard of Pugz!
My first 2bular sport cat cracked on the welds. There is a post about it here somewhere.
Car ran rough and would stall. Was VERY obvious when I checked it. I suspect the packing came loose inside, or there is a crack "somewhere"... but if you "smoked" it, then I suspect the packing. Let us know if you discover anything else I'm going to switch my 7x24 2bular to the new BOE Race Exhaust. The drone on my 7x24 has increased at highway speeds over the past year. I'm a big fan of the Coast Fabrication exhaust units... will report next weekend. Q |
#20 (permalink) |
Does no one offer a baffle-style design utilizing something like a Flowmaster? Anyone try something similar? I assume it would be quieter, but I don't know if you can plumb a large enough unit into the space confines of the Lotus?
From Corky Bell's Supercharged! pg. 185... "The choice of muffler styles is limited to straight-through glass-pack types or the relatively popular 'turbo' mufflers. Generally, straight-through units offer better flow capability, while baffle-style turbo mufflers provide superior silencing. Glass or steel-pack units have the reputation of burning the silencing material out an an early age. Fear of excessive noise with straight-through mufflers is usually valid. Two types of cores are popular in the glass-pack units; drilled and louvered. Drilled cores have a much cleaner, thus less restrictive, flow path. If drilled-core units prove scarce, louvered-core mufflers work better when flowed backward."
Frank Amoroso Whatever Press Vehicle(s) I'm driving this week www.twitter.com/famoroso Ever take a risk? A real risk? The kind of risk that makes you feel alive? It's... spectacular, isn't it? |
