Piston Slap - New Pistons Break-In Advice.
My 05 Elise N/A engine (53K mi) was knocking recently. I took it to my regular mechanic shop in San Diego and was told that piston #1 was slapping - checked everything else still look good: the valves, connecting rods, cams, rockers...etc.
First heard of Piston Slap as I'm not mechanical savvy - researched online and learned a lot. Anyway, I got some new Mahle Pistons, stiffer MWR valve springs and titanium retainers from Monkey Wrench Racing. It is normal for have piston slap on engine at only 53K miles. I maybe redlined it only once or twice for a second or so! Only a few track days and regularly maintained the engine by a qualified shop/mechanic. The engine is getting a valve job, cleaned and bored and the above new parts will be installed - new again, yeah! Question: the Mahle pistons is 12.3:1, not same as the stock 11.5:1 - will there be any issue? Mahle Piston Set - Toyota 2zz - 12.3:1 compression 82mm - MAH-21123820 van Mahle - Monkeywrench The website advised that the pistons are a direct drop-in to an unmodified 2zz engine. Is it safe and should be ok? Also as in term of break-in, my mechanic advised that he will put in non-synthetic oil (less slippery) for break-in period of about 1000 miles, and take it easy - basically same as new engine. Anything else (different) I should or should not do during the break-in period for our high compression N/A 2zz engine? I've researched online about breaking it new pistons and engine. Thank you very much in advance for any advice/suggestions, folks. I'm actually excited bout getting the "re-new" engine! |
I would not bump compression on pump gas, esp. since Cali fuel is 91, right?
Piston slap is an odd diagnosis and I'd like to know how it is diagnosed and cylinder 1. It is very hard to figure out what cylinder it is in and I am surprised to hear of it at 53K miles. Also, PS is not usuallyharmful to perfromance or longevity of engine unless it is severe - I have seen lots of engineering mules with over 300K miles and piston slap (sound is more like a tick, actually) If you are tearing into the engine, I'd go ahead and look at the bearigns and valvetrain to be sure they are not the culprit. |
+1--You will likely need to use race gas if compression is increased that much--not a good idea!
It could even be a really bad idea if the knock sensor cuts way back on timing, which translates into less power .
Joel '67 S3 Elan dhc (owned since 1970) '06 Audi A3 3.2 '04 Noble M12 (380 rwhp) |
#5 (permalink) | |
Parts scattered about...
If you currently have Mahle pistons, you can have some slap before the engine is warmed up because the pistons are forged instead of cast (OEM).
My car is modified.
<3 QR25DE
I have broken in a few motors like this: Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
The engine in my car was broken in with this method and I now have 35k on it. Standard factory compression for my car is 181psi, and that's where I'm at still. If you were going to build the motor, why not just get a lower compression ratio setup, and just buy the turbo kit that someone is selling on here? You could make a **** load of power. |
#7 (permalink) |
Appreciate all the comments, advices, and suggestions - keep them coming. I'm learning here.
It's surprising to me also that a 2zz engine had a piston slap at only 53K miles. The ticking noises made me really nervous and uncomfortable. Thus, I might have jumped the gun too quickly and had them replaced. The mechanic took out the pistons, physically/visually checked it and measured the cylinder/pistons/parts and clearance and discovered that it was piston #1. I thought about the low compression 9:1 pistons but I didn't want to take the turbo or supercharger route. However, I'm a little concern about the 12.3:1 Mahle piston's higher compression. If things don't work out - I'll get the 11.5:1 wiseco pistons which come with sleeve. Tomorrow, I'll be picking up the car in SD - I'll try to take some photos and post my initial driving impressions on the reworked engine. It's point of no return now, so wish me luck. I'll also get some correct verbage from my mechanic - I'm not mechanically inclined and don't want to misword/misquote the problem and solution. Am I the only person here getting piston slap with the 2zz engine? Thanks for the break-in tip. I also researched online and found debates on hard break-in vs. easy break-in. Last edited by good2go : 10-30-2009 at 10:39 PM. |
#9 (permalink) |
Hydrocarbons Rule
You can probably pick up a thicker head gasket to also drop the compression some.
#11 (permalink) | |
#13 (permalink) |
i am in the same kind of situation, my block will be sleeved with darton sleeves, but now i dont know if i should stay with the stock ratio (with Mahle or wiseco) or go with just a bit more compression (Mahle has 12.3 wiseco has 12.0) also should i go with a bigger bore size ?? will it need an ecu modification ?`???
#14 (permalink) | |
My car is modified.
#15 (permalink) |
<3 QR25DE
Don't reply with a freakin' smiley face.
Look, with a built bottom end, and a good tune, that car will make insane power. If you already have the motor apart then why the hell not? There is some incredibly bad advice here though. DO NOT shave the pistons. I think you'll be fine with the compression ratio you chose. If you're worried, just hook up a knock sensor to a light so you can monitor it. Light blinks = get out of the throttle. Honestly if I was going to build my bottom end, I would just go 9:1 or 8.5:1 and turbo it. That's if you have the funds. |
#16 (permalink) |
Hydrocarbons Rule
Is there some specific issue with the 2zz that won't allow this or do they not sell them? I've used HKS 2.2mm head gaskets etc to drop compression on Honda engines for turbo charging with no issues and these head gaskets are considerably stronger than stock. It does however change cam timing a tiny bit.
#17 (permalink) |
Update: I was all excited planning to pick up my ride yesterday when my mechanic called me...the engine pings at idle with the 12.3:1 Mahle pistons installed - probably too high of a compression - NOT a drop-in as described on MWR website. I'll try to return them! The mechanic recommended me just get the oem stock pistons from Lotus!!!
Thought about Wiseco 11.25:1 pistons for 2ZZ-GE, closest to what we have without going over the stock compression... Tomorrow, I'll just call a local Toyota dealership and get stock 2zz-ge Celica GTS 11.5:1 pistons and call it a day. Keep it simple! Much cheaper than from Lotus dealership. The saga continues....damn, did I do the right thing or should I have ignored the piston slap and just drove it?.... Last edited by good2go : 11-01-2009 at 09:27 PM. |
#18 (permalink) |
Hydrocarbons Rule
They have a Mahle 10.5:1 compression piston on their web site that would work well. There would be minimal power loss N/A with them and it would allow you to safely add a turbo or supercharger kit with a little extra boost in the future....
Mahle Piston Set - Toyota 2zz - 10.5:1 compression 82mm - MAH-21105820 van Mahle - Monkeywrench
2006 Exige; BWR Supercharger, Adj Sway Bar, Ohlins Suspension, BSK Oil Catch Can, Moroso Oil Pan, ORC Clutch, Custom Exhaust, Black Volk Racing CE28N's w/ Toyo R1R's, 2 piece rotors, Pagid Blue Pads, BSK Wet Carbon (Side Skirts, Front Lip Spoiler, Gas Cap Cover, Center Console, Door Panels), Dry Carbon rear Diffuser, Harness Bar, BWR Gauge Mount, OMP Superquadro steering wheel, LETSLA Short Shifter, V2arms, Rear Tow Link Brace, RLS Battery Bracket, BOE Tow Bar, Stickers. Last edited by Dragon : 11-02-2009 at 01:21 AM. |
#19 (permalink) | |
#20 (permalink) | |
Hate to say "I told you so", but the mechanic really should have known better in this case.
