Monkey Tuned!
Please help. What is this part called?
This particular part, the black rubber that I have isolated in the small picture to the right, is leaking grease on both passenger and driver side. I was told it is a warranty item and I should have it replaced.
Please help w/ the following questions: 1. What is it called (so I can tell the service dept what it is prior to coming in). 2. Has anyone actually have this part replaced? And not fail / leak again? 3. Has anyone had a dealer just wipe the surrounding area clean and call it good? Thanks. |
It is a ball joint boot and it may leak a little grease if too much grease is inserted in the joint. Unless the integrity of the boot has been compromised with a tear or a visible hole, I would just wipe the grease off of its exterior and call it good. If torn it needs to be replaced, and it may or may not be available separate from the ball joint.
Jerry
2007 Laser Blue Exige S 1965 Elan (26r clone) vintage race car 2005 Audi S4 |
Third Eye Open
It is a tie-rod and it is sealed, You cannot add grease to it (no zerk fitting), It is a factory replaced item and I had one replaced on my car and the bastards left the steering rod boot all twisted up because they were too lazy to loosen the clamp on the dust boot when they did the alignment.
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's! Last edited by ZTEC : 08-13-2007 at 11:55 AM. |
No more cone damage!
Mine is leaking on the driver's side. I just haven't been concerned enough to take it in yet.
Jer-2005 Elise (retired from autox) 1993 MR2 autox car 2002 Ford Excursion DIESEL 4 X 4 1993 Miata (throwout bearing or clutch failure) 1987 Toyota Corolla FX16 Lemons car (needs new head) 1984 Chevy Citation Lemons car (needs a motor) |
#6 (permalink) | |
V Not my picture V
Zerk fitting....... ![]() |
#9 (permalink) | |
call me robbie.
'06 Exige - Aspen White [sold] and living like no one else! |
#10 (permalink) |
OOPS! Tie rod end is correct. I was looking at the picture, but thinking of the upper ball joint on my Elan, which exhibited the same symptoms. For those who are worried about no zerk fittings, virtually no cars made today have zerk fittings on their tie rod ends. Better grease and better internal sealing make these parts pretty much 0 maintenance.
Jerry
#11 (permalink) |
McLareghini Bugatterrari
"Sealed for life," means, "Sealed until they aren't."
"Zero maintenance," is marketing speak for "Throw 'em away." xtn (translator of all things idiotic)
#12 (permalink) | |
As other's have said, a little bit of grease leaking out is not a big deal - it just indicates that there was excess in there to start with. If the boot is torn, cracked, or just "collapsed" (i.e. no more grease under the rubber), then it needs to be replaced. Otherwise, it's fine.
#13 (permalink) | |
Why would having/not having a zerk fitting matter? |
#15 (permalink) | |
call me robbie.
