Rattle with A/C on
I have searched for this issue but can't find any other reports of it. When my A/C is turned on, and only when the A/C is on, I have a bad rattle noise that seems to come from the right side of the cabin. It is pretty loud and happens at roughly 2k-4k RPM of the engine. Has anyone run into this before? So far I have not been able to pinpoint where it is coming from, I can't even determine if it coming from the dash area or perhaps the engine.
Appreciate any help! |
Alarmed & Dangerous
Is the noise present only when the A/C is on, or with it off, and only the fan blower on.
Alarmed & Dangerous
You might want to check the compressor in the engine bay and the cooling fans up front.
#6 (permalink) | |
It's a Lotus
NOT air conditioner related though.
2005 Saffron Yellow Elise. Stage II Exhaust. 2007 ProBax seats. "We know they're magical and worth every minute we spend on them. The whole Lotus owners' world is like a secret handshake among people who understand that." (R&T) |
#7 (permalink) |
No, it's only an N/A
It is coming from the side of the car. There is a line that runs along the passenger side of the side sill that is now vibrating enough to hit the side sill. Take out your side scoop and put a piece of hose around the line and it should stop the noise.
Useful links to vendors removed at Nadeem's request. "Nice avatar by the way, I doubt Colin Chapman would have followed the herd as I have seen many here do. --Nadeem" |
#8 (permalink) | |
I'll post again after I check it out. Thank you! |
#9 (permalink) |
Idiot Driver
I've got the EXACT problem with my 06. I'll try the side vent inspection/modification as well.
2006 Elise*Touring Pack*Premium Pack*Sport Pack*Hardtop*LSD*Traction Control*Starshield*-Chrome Orange*OHLINS Coil-Over-Springs* 2001 Chevy Tahoe SUV 2007 SugarSand Tango SS |
#10 (permalink) |
Just got mine fixed. It turns out that there was a loose nut accessible from the passenger side front wheel well. With the nut night tightened down all the way the rattle has gone. I've also had the AC line that runs through the side sill rattle against the frame. Both issues are addressed now.
#11 (permalink) |
AC rattle result?
Hey guys I had posted the same exact noise on my O6 Elise recently. Its annoying as heck. I havent been able to check the AC line. Did this work for you and how easy or hard is it to remove the side scoop? Also will putting something on the line all the way near the scoop help the noise when it seems to come up from closer to the front?
#12 (permalink) |
Keep it simple and real
I had this issue with my '06 Exige. It was corrected under warranty and was a relatively common problem. I recall that the a/c lines were zip tied into place to prevent them from vibrating (resulting in the rattle sound) under certain conditions.
#14 (permalink) |
Live from the Bubble Room
Dont know about the side scoop? I fixed the rattle by removing the undertray, you can see the lines coming from the engine bay and enter the sill just in front of the rear wheel, a few tie wraps and some of that foam ac tube insulation stuffed into the sill cured it.
"Never leave well enough alone" Raymond Loewy |
