Old 05-30-2005, 06:28 PM   #1 (permalink)
Head LOONY
tvacc's Avatar
Removing Front Panels?
How do the front panels come off? I removed the screw...but the panels are not removing easily. I dont want to force it..Can somebody help me out?
I want to check the fluids and run a wire for my Laser Shifter...
Tony V
tvacc is online now   Reply With Quote
Old 05-30-2005, 06:31 PM   #2 (permalink)
No more cone damage!
Surferjer's Avatar
Tony-you pull them away from the center and towards the windshield at the same time, lifting slightly. Don't be afraid, it's okay.
1993 MR2 autox car
Old 05-30-2005, 07:04 PM   #3 (permalink)
The covers are retained by the bolt that you can see (tool in your tool kit removes it) and two prongs that fit into rubber inserts that live in the central spine element. You can see these if you look into the gap between the covers and the spine. Additionally, the panels have a black plastic lip that fits under the radiator exit grills. Some cars have had their covers replaced without ensuring that the lip is in place under the radiator grill's rear edge.
Old 05-31-2005, 05:34 AM   #4 (permalink)
I actually removed one of mine for the first time yesterday as I noticed it was not sitting right UNDER the radiator grill as it should. Was pretty easy - just remove the screw and pull towards you as surferjer said...
ivan1 is online now   Reply With Quote
Old 05-31-2005, 05:40 AM   #5 (permalink)
I also just removed them the first time the other day. The instructions from the manual worked for me. Took me a minute to pull them loose, I was scared of applying any kind of force. But with a little wiggling, the prongs came out of the center spine. For installing them again, make sure that you slide the lip of the cover under the grill before you start to push them back towards the spine.
Once you've done it a few times, it's probably a matter of seconds.
Reto
2005 Lotus Elise (yellow, sport pack), #94 SS
2005 Nissan Xterra (LSV)
ConeFusion is offline   Reply With Quote
Old 05-31-2005, 06:24 AM   #6 (permalink)
Surferjer's Avatar
It is a few seconds. I pull my passenger side all the time to pull the horn fuse before meets. Honking the horn while on course may be amusing, but it always upsets my concentration when it happens.
1993 MR2 autox car
Old 06-01-2005, 12:00 AM   #7 (permalink)
'05 SY #0038
doma's Avatar
Images: 6
Given time the panel may remove itself! i.e., one day I noticed the panel was poped up and the screw was all the way undone and just rattling around. These Loti do shake their screws loose.
Braille Battery - Micromirror - Alpine Head Unit & Speakers - HID Headlights - H&T Pad - Snorkel Delete - Non Dust Brake Pads - JL Stealthbox - JL Amps - Sirius Sat - Rudolph Antlers and Nose Kit
Astronomy Picture of the Day
doma is online now   Reply With Quote
Old 06-01-2005, 08:10 AM   #8 (permalink)
Good post....My car got egged in Las Vegas last weekend. All of the impacts (3) were on these panels or the windshield and if it had to happen I'm glad it happened there instead of on the clams so it can be easily removed and repainted. Fortunately I got the egg off within an hour and before sunrise.
ST8VART is offline   Reply With Quote
