Repair for a hole in the wheel well liner - LotusTalk - The Lotus Cars Community
post #1 of 17 (permalink) Old 11-14-2006, 09:44 PM Thread Starter
Well MyElise gave me a great idea that I thought I would share.
I recently tracked my Elise at Lime Rock and burned a hole in my drivers side front wheel well liner. MyElise mentioned that he riveted some HVAC metal to the wheel liner and hasn't had a problem since. So here is a simple pictorial of how to repair the wheel well hole:
First I turned the steering wheel all the way to the left so that I could get access to the liner. I unscrewed the two plastic screws by the oil cooler and then unscrewed the Philips screw on the top of the liner. Then it was easy to just pop the wheel well liner right out without having to remove the wheel nor lift the car up. This is a picture of the wear on the liner.
scottyb is offline
post #2 of 17 (permalink) Old 11-14-2006, 09:46 PM Thread Starter
Then I drilled out the rivets holding the retaining clip on the top of the liner.
scottyb is offline
post #3 of 17 (permalink) Old 11-14-2006, 09:50 PM Thread Starter
I had some Aluminum flash hanging around so I cut it to size and then riveted the aluminum to the liner such that it would be between the clam and the liner.
scottyb is offline
post #4 of 17 (permalink) Old 11-14-2006, 09:53 PM Thread Starter
Then I replaced the wheel liner back into the car with the two plastic screws/anchors and the Philips screw on the top.
Job was finished.
Now I have piece of mind that the wheel will not cause any possible damage to the clam, exposed wires because of the hole. Also if the wheel continues to contact the liner, the aluminum backing should hold up fine protecting the clam.
scottyb is offline
post #5 of 17 (permalink) Old 11-14-2006, 10:37 PM
rnr
rnr's Avatar
What tires are you using? The stock tires should not be hitting the wheel well liner.
http://www.rahulnair.net/blog
06 Elise
13 Evora S IPS
16 Dodge Charger Hellcat
rnr is offline
post #6 of 17 (permalink) Old 11-14-2006, 10:51 PM
R T
R T's Avatar
my stk LSS tires/wheels do
R T is offline
post #7 of 17 (permalink) Old 11-14-2006, 10:52 PM Thread Starter
A048's on the track and the AD07's on the street. I also have the Nitron single adjustable shocks. Many who have tracked the car have worn holes in the liners .
scottyb is offline
post #8 of 17 (permalink) Old 11-14-2006, 11:30 PM
gadams's Avatar
I've worn a small hole (that I've just taped over with racing tape) in that same spot on the passenger side liner when the folks at Criswell forgot to replace the two liner screws liner near the oil cooler. That allowed the liner to fall slightly in, toward the rear of the car, which allowed contact with the tire.
Since replacing those screws (Criswell found a couple to use at my request), I've had no more contact, and I do a fair number of track days.
Are you sure everything's fully screwed down in its proper place? Of course, the liners are fairly flexible, and the pop-screws don't seem that precise. I'd certainly believe that normal variation allows some to touch, while other do not.
- Geoff
2005 Federal Elise, LSS, GG, red interior
1984 Porsche 944 race car
2006 BMW 325i "daily driver"; only seems to be driven in the pouring rain or freezing weather these days
gadams is offline
post #9 of 17 (permalink) Old 11-15-2006, 07:03 AM
Serebo1's Avatar
Scotty, be careful. If the tires do continue to rub, and they most certainly will, they may eventually snag on the liner. I've lost two (liners) that way. I'd hate to see you shred a tire on the aluminum; also, I'd be concerned about how the metal changes the dynamic of the way the liner eventually goes away. Could create an unintended missile inside the clam.
Sorry, not trying to be the voice of doom here. Kudos on your ingenuity.
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior.
Serebo1 is offline
post #10 of 17 (permalink) Old 11-15-2006, 07:36 AM Thread Starter
I'll keep an eye on it, but those are definitely things to think about.
scottyb is offline
post #11 of 17 (permalink) Old 11-15-2006, 07:58 AM
ekological's Avatar
When you took out your fender liner, did you see where the HID ballasts were placed? Those could be pushing the liner out into the tire. Just a thought.
Custom Plug-N-Play Elise HIDs, Arqray SS Double Tip Exhaust, RAC Monolites
ekological is offline
post #12 of 17 (permalink) Old 11-15-2006, 08:46 AM
The Stig's Avatar
Nice!!! I like that alot... I am going to have to do that. Thanks for posting Scotty
Neil
WTF people?
The Stig is offline
post #13 of 17 (permalink) Old 11-15-2006, 12:55 PM Thread Starter
No issue with the ballasts. They are mounted in a bracket away from the liner. I guess a different guy did the install on my car than PChops. I still have the factory Harness as well.
scottyb is offline
post #14 of 17 (permalink) Old 11-15-2006, 01:07 PM
ZJChaser's Avatar
I just took a look. Bone stock exige with about 2500 miles. Both sides look similar, the left side is a tad worse I think due to the fact that all track days so far have been clockwise.
rightseatdriver.
ZJChaser is offline
post #15 of 17 (permalink) Old 11-15-2006, 06:26 PM
Yeah, I wore a fist sized hole in my left front and the hot tire grabbed the exposed HID ballast and wires, pulled them out the hole, and made a copper bird's nest out of them.
I found some black plastic that came from some large washing tray they sell at home depot. I cut out a piece and used a weller soldering gun. I welded it in the hole. I set it back in further so the tire wouldn't do it again. The balast and rewiring was a b!tch. No diagram. The patch came out rather nice. I had bought a new fender liner but didn't need it.
MikeW is offline
post #16 of 17 (permalink) Old 11-16-2006, 05:43 PM
Jack's Avatar
Don't worry -- a few more miles and you have a nice hole.
Jack
2008 2-Eleven
2014 Exige CupR
Jack is offline
post #17 of 17 (permalink) Old 07-14-2007, 08:52 PM
EdHahn's Avatar
I had this one side where the metal screw had backed out about a half inch, allowing the liner to sag at speed. I patched using 2 layers of Gorilla Tape on both sides of the liner.
If you end up using plastic, make sure it is of a type that can handle the heat of being near the oil coolers.
ed
Magnetic Blue/LSS Delivered: 1/13/05
EdHahn is offline
Human Verification
