Old 09-25-2009, 02:10 PM   #1 (permalink)
Should this bracket on the suspension be bolted to anything or just floating in air?
On my 2005 Elise, the bracket pictured below is on both the driver and passenger side suspensions in the wheel well.
On the driver's side, it is bolted to a metal piece above.
On the passenger's side, it is floating in the air (pictures below).
Is it supposed to be connected to anything on the passenger's side?
NorCal is offline   Reply With Quote
Old 09-25-2009, 02:31 PM   #2 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
It's fine... the bracket is actually bolted to the chassis by two bolts behind the shock (on both sides of the car). I would guess that bracket would be for the ABS unit on a right hand drive car (that's what it's bolted to on the driver's side).
Old 09-25-2009, 08:19 PM   #3 (permalink)
FIL
Serial Thrilla
FIL's Avatar
Yes, those arms are go to an ABS module on the driver's side of the car, but Lotus only makes identical brackets, so on the passengers side it just hangs, check the drivers side and you'll see what I'm talking about...
05' Elise - BWR supercharger, Quaife LSD, Nitron Race Triple Adjustable, LETSLA, Larini Decat, Larini Exhuast, ACT HDSS, Fidanza flywheel, V2 Fuel Tank, V2 Steering Arms, BWR sway bar, desnorkled, ForcedFed CF splitter, Manly's engine mounts, S111 harness bar, Schroth harness w/ S111 seat grommets, Oil Drain Valve, Painted Black Diffuser, Braille battery, Custom Battery Switch
05' Corvette - Z51 Convertible - 630hp 6.6L [DON'T YOU JUDGE ME!!!] (SOLD!)
FIL is offline   Reply With Quote
