Old 09-11-2009, 01:12 PM   #1 (permalink)
dos531's Avatar
Skipping/wheel hop when turning left?
I have a wierd problem with my 06 exige. When making left turns somewhat hard, the rear feels like its skipping or getting wheel hop. This happens both on and off throttle, and ONLY when turning left. I have had the car aligned and installed an RTV brace, and nothing seems to be bent...any ideas?
2006 Exige Aubergine Purple
dos531 is offline   Reply With Quote
Old 09-11-2009, 01:59 PM   #2 (permalink)
User, Registered
fpitas's Avatar
Sure the shock is good on the rear left side? You might check the shock (coilover) mounting bolts, too.
Francis
Old 09-11-2009, 02:14 PM   #3 (permalink)
JLSELISE's Avatar
If you are turning left, it's the right side that is under load--so that would be the side to check first, and the shocks are certainly a good place to start.
Joel
'67 S3 Elan dhc (owned since 1970)
'06 Audi A3 3.2
'04 Noble M12 (380 rwhp)
JLSELISE is offline   Reply With Quote
Old 09-11-2009, 02:15 PM   #4 (permalink)
dos531's Avatar
Ok I'll check those bolts, but I dont know how im going to check the shock without another to replace it with. Any ideas?
Old 09-11-2009, 02:35 PM   #5 (permalink)
JonMD11's Avatar
Try swapping them right to left and see if that makes a difference.
'06 Storm Ti Elise, Touring, Stage II, Cup Car Air box/K&N, Manly's Motor Mount Inserts, LETSLA
JonMD11 is offline   Reply With Quote
Old 09-11-2009, 03:38 PM   #6 (permalink)
OSX Black hat
charliex's Avatar
is it purely mechanical , ie the traction control isn't kicking in?
Old 09-11-2009, 03:45 PM   #7 (permalink)
dos531's Avatar
It's definitely more than traction control, and it does it when tc is deactivated as well.
Old 09-11-2009, 03:53 PM   #8 (permalink)
User, Registered
fpitas's Avatar
True, should have said the right side.
Francis
Old 09-11-2009, 03:57 PM   #9 (permalink)
Hello Kitty's Avatar
Arrow Me Too
I have the same problem.
It is caused by the open diff.
The inside wheel is spinning faster than normal because your outside wheel is carrying the load.
The car cant go as fast as the inside wheel is spinning, so the inside wheel hops to release some of the energy.
open diff is soo stupid.
Lotus is just being cheap by using them.
Hello Kitty is offline   Reply With Quote
Old 09-11-2009, 05:13 PM   #10 (permalink)
dos531's Avatar
Yeah I know the open diff isnt ideal, but this doesnt feel like its simply the inside wheel spinning. It feels like the outside rear wheel is skipping or hopping somehow. Plus, if it was the diff, I think it would happen equally to both sides. I am going to try the shock swap when I have time and see if that helps at all. I guess it would be an excuse to get some nitrons
Old 09-11-2009, 05:14 PM   #11 (permalink)
Then it's not inside wheel hop/spin due to an open differential. Under neutral or closed throttle, the open diff would allow the inner and outer wheels to spin at different rates, each matching their respective road speeds. In fact, your description more closely matches what I have experienced in other cars with plate-type LSD's, where the stiction between the plates causes the inner wheel to alternately spin/grip as it tries to match the road speed but can't because it's "tied" to the (faster) outer wheel through the LSD.
If it only occurred when on the throttle, then I would agree that inside wheel spin might be part of the issue, although this does not explain why it only occurs when turning left.
Pengineer91 is offline   Reply With Quote
Old 09-12-2009, 05:14 PM   #12 (permalink)
No your wrong. With a open diff, the inside tire spins 2x, 3x, 4x, 5x,... faster than it needs to based on the throttle.
I have a open diff. I hate it!!!!
Lotus is just being cheap!
Old 09-12-2009, 06:52 PM   #13 (permalink)
perfututum futūtor
RoadDad's Avatar
Me... I don't need to.
Bite me." -Randy
Old 09-13-2009, 02:51 AM   #14 (permalink)
holmz's Avatar
Images: 5
Put both the left and right side up on stands.
Spin either wheel with the parking brake off and see if it is the diff (LSD).
The other wheel should spin opposite, and spin them both CW and CCW.
If it doesn't spin in either direction, then you have an LSD, which probably needs attention.
While it is up, check the shocks/dampers for obvious leaks...
You would need to check the dampers on a shock dyno, but if it is happening at low speeds then this doesn't sound like a shock issue.
holmz is offline   Reply With Quote
Old 09-13-2009, 08:59 AM   #15 (permalink)
glb
Unattractive Nuisance
glb's Avatar
checking shocks w/o dyno:
This sorta worked for me. Go on road that is equally bumpy on both sides. Drive briskly.
Then, feel if one shock is significantly warmer than the other.
I did this when my 2002tii hit a construction hole at high speed. I knew one of the rear tires had broken, but which?
Felt shock 1, quite warm. Felt shock 2, burned my frigging hand!
Old 09-13-2009, 10:45 PM   #16 (permalink)
holmz's Avatar
Images: 5
So which one was the broken one? (It could be either...)
You only know that they are not the same, which would tell you that one of them is hosed, and that you need a shock dyno.
Makes sense though for a quick "is it a shock" test.
Old 09-14-2009, 01:09 AM   #17 (permalink)
British by extrapolation
Mr. Know's Avatar
Images: 6
Any chance a plate LSD was installed by a previous owner? That sounds like a posi rear end in an older car.
Or maybe a Quaife Helical?
07 Magnetic Blue Exige S
Join the Blue Lotus Team on Facebook.
Mr. Know is online now   Reply With Quote
Old 09-14-2009, 02:16 PM   #18 (permalink)
dos531's Avatar
I highly doubt it has an aftermarket differential, but I guess I cant be sure. Everything else on the car was stock.
Old 09-14-2009, 09:57 PM   #19 (permalink)
holmz's Avatar
Images: 5
Well I'll bet it has an LSD in one direction.
Old 09-14-2009, 10:31 PM   #20 (permalink)
dos531's Avatar
im not sure how that would work
