True DIY Times Mods & Jobs
As many that read my posts can surmise I'm a hands on guy. I an fortunate to have the knowledge, skills and tools to perform most jobs and mods.One thing that I think would be helpful to people using this board is real times for DIY jobs and mods. I define a real-time for a job as the time that elapses between pulling your lotus into the garage to pulling it out with the job completed. I think some posts may state an artificially short time for a install not including the time to take off wheels , pans ect. This came to mind when I installed the force fed damper( see post). We could make this a sticky for true DIY times I'll start.
Install Nitrons includes lifting or jacking,R&R wheels and top front shock mounts 2-2 1/2hrs note does not include setting ride height corner balance or alignment add 3-4hrs(trust me i've done this many times) Force fed damper 1 1/2hrs add 1/2hs for RTD brace. Oil and filter 1hr Change front brake pads 3/4hr, remember all times include jacking and R&R wheels. Change rear pads 1 1/4 hrs. Change springs on Nitrons or Olnins 3-4hr includes resetting corner bal and ride height check alignment but no adjustment. Install Sector 111 RTD brace and reset rear toe and thrust angle 3-3 1/2hrs. This is a start. carl Last edited by carl : 11-18-2007 at 08:45 PM. |
道のお父さん
My addition, when I get the rest of the parts, will be: Cutting rear bulkhead trim panel, placing speaker pods, and installing a Lotus harness bar.
"There are two things no man will admit he cannot do well: drive and make love." -- Stirling Moss Nunquam est ponenda pluralitas sine necessitate. Pluralitas non est ponenda sine necessitate. Pluralitas non est ponenda, nisi ubi est necessitas.
Will race for sushi
Hub/bearing carrier
approx 2 hours... Jack car, remove wheel, remove castle nut cotter pin, remove castle nut, remove three hub bolts (the hard part, tough to get to and probably rusted - removing undertray for wrench clearance is probably necessary). Use a gear puller to remove hub, then replace new hub, connect ABS sensor, replace three hub bolts, replace castle nut, replace cotter pin, replace wheel.
You will need a shallow 19mm 6pt socket, a 19mm offset box-end wrench, several extensions, a breaker bar, a torque wrench, an impact wrench, and a 30mm impact socket. (and an air compressor) Oh, and a propane torch may come in handy if you do have really rusty stuck bolts like I did. Last edited by MotorCade : 11-13-2007 at 08:25 PM. |
#5 (permalink) | |
Will race for sushi
I've had three wheel bearing failures so far on my car, an early 2005. (both together at about 18,000, and left rear at 38,000). Lots of track time, though. Easy part to replace, and reasonably cheap at about $120 retail.
The first replacements were covered by Lotus under warranty, but the third was mine... and a big to Qais at southbay, btw... he got me a slightly used hub for free. Thanks again, Qais!I do tend to favor a little oversteer in my setup, and I use the curbing aggressively. So I'm not really all that surprised. |
#7 (permalink) | |
http://www.elisetalk.com/forums/show...wheel+bearings |
#9 (permalink) | |
2)2hrs with R&R roof and IC bellows 3)1-1 1/2 Saikou Michi 4) 2hrs |
#10 (permalink) |
Has a skinny fetish
People say that putting on an exhaust is easy... I took six hours because taking the stock one off was a bitch. That was four hours alone.
2006 Solar Yellow Elise: clam protection, Multivex Mirror + mod, Center Brake Light Pulser, rear window shield, Von Hep Exhaust (twingle), Al trim ring, S111 Carpet Buttons & CF Center Console & Lidbone, toll mount, tray mod, brake light adj, headlight adj, raised letters, stealth bulb, de-snorkel?, painted cover? & caliper? ║ Forza 2 w/ Wheel & ButtKicker, CA Car Cover (less $: Covercraft Evo 4), CDI torque wrench, ProperAutoCare, Zaino Total Protection Kit, gas bib, stub tool, Etymotics....... |
#11 (permalink) |
not a Mod, just an Admin
Changing/cleaning stock air filter? My experience was 2 hrs by myself (1.5 just trying to line up the cover). With a knowledgeable extra set of hands, 15 minutes to close. With my wife, 30-35 minutes.
#14 (permalink) |
Transmission oil change - 1+ hour
I filled it from the top with a funnel that had a fairly long clear hose attached to it, only way to go in my opinion. 15 minutes to clean up the oil I sloped everywhere when draining the trans ![]()
2005 Elise, CO, LSS, Hard Top 2006 Mini Cooper S - peper white |
#17 (permalink) |
Exige S dipstick tube oil leak. (from Carl) Four days to get the O ring from Toyota, then 1 hour to replace, hardest part was getting your hand in there to get the old one out, and new one in. (don't forget to take out the dipstick first) Doh!
#20 (permalink) |
El Jefe - Agent 111
Craig, you are not that far away, give me a call for help to do stuff. I was just down at PL Seafoods.
P.S. My exhaust changes are about 60 minutes. Diffuser off in 4 minutes. Top on or off in 25 seconds. All four tires swapped in 10 minutes 20 seconds Removing rear clam 2 hours Removing front clam 2 hours Replacing uprights. FORVEVER. ![]() Installing LSD into tranny 10 hours once tranny is out. Changing air filter (with taking rear wheel off) 30 minutes.
* V E R I T A S * A E Q U I T A S * We have been feeling the buzz since 2002 2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds. ..is a stranger in an open car. Tempt you in and drive you far away |
