#41 (permalink) |
Derriere Extraordinaire
Oh yeh...Sector CF Zoom mirror:
Total crap shoot depending on what mount you get. Mine: 2-3 hours (15 min cautious assessment/removal of stock mirror). *Includes trip to local home depot to purchase hardware to retrofit mirror that "installs in minutes" LOL
2006 KG-Sport Pack, LSD, TC, SS, Multivex, Lotus Stage II/powercoated diffuser, CF Zoom Rear View, Sector LidBone, Darth Holder (thanks Kestrel!), Sector 4Tress Harness Bar/CRD Mount, couple exige trim pieces 2004 Nissan 350z - Super Black-too many mods to list-SOLD to my brother 1978 Chevrolet Caprice Classic -(daily driver) *Seasoned veteran member of the KG Mafia |
#42 (permalink) |
R&R valve cover and inspect cams, NA 1 1/4 hr SC 2hr. Note on the Sc you need to remove the IC and the engine cover latch and heat shield. Also replace the O ring on the oil feed tube, the main VC gasket and breather gasket. carl
#43 (permalink) |
Larini Sports Cat + SE Exhaust 07 Elise Install
Other end of spectrum from Randy Chase, 4Carl and other experts. First, I am a Lotus Newbie (Aug 07), have lots of hand tools, but no machine shop capabilities and am of average mechanical ability. Working alone.
Remove rear diffuser 15 min Jacking up car with jack stands/hockey pucks 45 min first time - wanted more clearance than Rhino Ramps Remove stock exhaust 2 hours - difficult to get off without damaging heat shield - WD 40 helped - Much ad hoc leverage required Remove stock cat 45 min Note: time spent arranging steady rests/supports to avoid: heat shield damage; dropping of units on my chest; and possible damage to supports. Install Larini sports cat 8 hours Note: per other posts, the ball and socket joint between header and sports cat did not fit the same as stock – the “ball” is a little bit bigger. Result is that I could only get one of the stock bolts mated with the header flange with the springs in place. Spent many hours trying solutions: clamping flanges together and several variations on pre-compression of the springs. Nothing worked. Final solution was a longer metric bolt from the local hardware store – went in place easily. Others have reported a solution involving shaving a coil off the springs, but I was leery of this approach. Some have speculated that the joint may be too tight and not allow normal movement, resulting in damage from bumps. My theory, which will be tested when back on road in spring, is that normal expansion/contraction heat cycles, combined with some degree of joint movement over bumps, will ultimately result in proper seating of the ball/socket assembly. More to come on this. Removal of 07 rear panel 1 hour Note: due to the “bumpers” on the 07, the Larini SE tips cannot be accommodated. Had to purchase an 06 rear panel. Cutting heat shield to accommodate SE tips 30 min Installation of Larini exhaust 4 hours Note: difficult to get muffler fully onto cat pipe U bend due to interference fit. Tried all sorts of leverage techniques to force fit. Still came up 1/4” short on centering the SE tips. Had to play with two degrees of freedom (ball/socket joint rotation plus muffler rotation to get tips properly aligned. Attach Euro screens and refit rear panel 2 hours - working alone from under the car, difficult to align screws which must go up through the boot floor Block stock exhaust opening in rear diffuser 2 hours - pop riveted 0.020” aluminum sheet over opening, painted flat black to match diffuser Clean up, tools away, trips to hardware store, 2 hours etc. Total 23 hours 15 min Final commentary. Based upon learnings, could now do task in about 8 hours working alone. My hat is off to those who can do same in a couple of hours. A helper would reduce time significantly further. Hope this helps anyone coming to this cold like me. fredkto |
