Old 09-05-2009, 11:30 AM   #1 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
Strange AC failure - FYI
I had a bolt head shear on a bracket that held the 2 hard lines going into the Expansion Valve releasing the entire contents of my cooling system, I am hoping this will be a simple fix but a strange one indeed and just wanted to give you guys a heads up! In the diagram the "Screw" is labeled number 34 and is an M6 X 16 cap head and the other 2 circled parts number 31 and 28 are the O-rings that are nowhere to be found! The second pic is of the bracket that holds down the hard lines in the expansion valve and the failed screw sits on the other side of this hard line.
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's!
ZTEC is offline   Reply With Quote
Old 09-05-2009, 11:39 AM   #2 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Here is a thread about the exact same incidence.
Refrigerant escaped
Old 09-05-2009, 12:27 PM   #3 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
Thanks Michael, You are correct and this failure is identical to mine! I am really hoping this is a simple fix with new o-rings and a new Screw, If you know of a torque value it would be much appreciated. Nick
Old 09-05-2009, 10:16 PM   #4 (permalink)
I think you'll find that the O-rings are still on the ends of the tubes. There is a flange about 1/4 in. from the end of each tube. The O-ring should be on the tube under the flange. Feel around for it. It is nearly impossible to lose the O-rings with this configuration.
Bill In Cincinnati
webowser is offline   Reply With Quote
