Finally Elise Driver!
I found all the toyota engine and transmission manuals at the european site:
Edit: ChrisH found updated links, I'll check later if I can find updated links to the toyota-europe site. http://techdoc.toyota-europe.com/fin...p?&d=1&lang=En Access for one day is 16 euros, I don't think they don't do the separate subscriptions toyota vs lexus, you can access both. Lotus name: Elise/Exige 6 Speed Engine Manual Lotus part: B120T0327J Toyota name: English Repair Manual ENGINE (1999-->) vehicle id: ZZT230 Toyota part: RM733E Toyota name: English Repair Manual ENGINE (2000-->) vehicle id: ZZT231 Toyota part: RM733E Both links take you to the same document, Both Available when you search for Celica/English and it will be under Repair Manual/Engine. Lotus name: Elise/Exige 6 Speed Engine Supplement Lotus part: C120T0327J Toyota name: English Repair Manual ENGINE (2001-->) vehicle id: ZZE123 From Oct. 2001 production. Toyota part: RM929E Strange too, the description is for a Main Manual not a supplement. But it's the right manual Available when you search for Corolla/English and it will be under Repair Manual/Engine. Lotus name: Elise/Exige 6 Speed Transmission Lotus part: D120T0327J Toyota name: English Repair Manual CHASSIS + BODY (2001-->) vehicle id: ZZE123 C64 Manual Transaxle Toyota part: RM930E Another strange one, they didn't put the document under the transmission. But it's the right manual too. Available also doing a search for Corolla/English and it will be under Repair Manual/Chassis+Body You don't have to pay to do the searches, and 16 euros is not that much money. (around $25) Anyway tomorrow I'm going to try to create a one day account, hopefully they allow access from the US, or I'll have to use my parent's address in Spain and pay taxes I guess. If anyone does this before I have a chance tomorrow, please post if the documents are the right ones before any others try. I also did a post on at the end of the Lotus service manuals thread: Elise Service Manual for $25 from LCU. - Page 3 - LotusTalk - The Lotus Cars Community
05 Elise Racing Green/Red, Touring, Hardtop, StarShield Last edited by Miguel : 10-31-2008 at 06:37 AM. |
Check the other thread linked above for a follow up of getting both engine manuals and the transmission one.
In short, it's a PITA because you have to download one section at a time for each manual. RM733E consists of 230 pdf documents and both RM733E documents are the same, get the one labeled 2000 just in case. I ended up with only 229 in the 1999 one but maybe i did miss a link. RM929E consists of 29 pdf documents. RM930E consists of 16 pdf documents. I also got all the SDS for both the Celica and the Corolla, also some electrical documents where it refered to the 2ZZ-GE engine. And also RM925E the corolla repair document I tried to get all the sections in connection with the 2ZZ-GE engine and the C64 transmision. Including intake, exhaust, etc... Allow yourself a lot of time to do this because it's a lot of right clicks and save as. As well as having a directory ready for each document because acrobat tends to freeze if you try to create a directory from it's save as dialog. Also you have to log-in after each document because it will probably time you out, so don't forget your username and password. When creating the account it doesn't list the US in the country list, I placed UK instead and since may address and zip code was the right one for my credit card it went through with no problems. Once you find the document, there should be a link to view it, that will open a window in full screen with navigation links of the left and the pdf contents on the right, you can right click on the navigation links and save as and put them on your prepared folder. some other are tricky and you have to actually display the pdf document and use the acrobat save button to place it in the right place (only the electrical stuff IIRC, not the main documents). After you are done downloading all the pdf files, make sure you have the navigation tree as expanded as possible, right click on the background of that panel and do a select all, then control-c to copy and paste in word, it will maintain the hyperlinks, you can then save it as an html file in the directory you prepared, for example I called the one for the engine RM733Eindex.htm Then you have to edit that html document and remove the remote link to the european server leaving only the name of the pdf file so that it can access it directly from your computer. I know it's a lot of work, but worth it for me, maybe Ground Loop knows of a way to do everything automatically, I couldn't retreive the whole trees with wget so AFAIK it has to be done manually. Edit: sorry for putting so many things in bold, but it's a pain to do this and you better read this message in detail before trying to do it. I won't be back on my computer until Monday so good luck ![]()
05 Elise Racing Green/Red, Touring, Hardtop, StarShield Last edited by Miguel : 07-15-2005 at 02:28 PM. |
I noticed today that you can order the CD's from them too, price unknown.
Edit: seems they are working on the CD ordering, still since they seems like dead links at this moment.
05 Elise Racing Green/Red, Touring, Hardtop, StarShield Last edited by Miguel : 07-22-2005 at 11:42 AM. |
Found myself on baby duty tonight so I downloaded the 3 manuals between feedings. 229 RM733E files, 29 RM929E files and 16 RM930E files. I can put these files on a CD and ship it out to anyone who's interested. I'm not offering to pirate the files so all I can save you is the time and hand cramp from clicking and saving all those files. You'll have to pay for a subscription to the site, login using the account you setup and email me a screen capture with your name and subscription info.
Seems like I also missed one link - and it's probably the one I'm really going to need. |
#5 (permalink) | |
Also my RM733E had the following 230 pdf files: m_ch_0001.pdf m_ch_0002.pdf m_ch_0005.pdf m_ch_0006.pdf m_ch_0008.pdf m_ch_0012.pdf m_co_0001.pdf m_co_0002.pdf m_co_0004.pdf m_co_0005.pdf m_co_0006.pdf m_co_0007.pdf m_co_0008.pdf m_co_0009.pdf m_co_0010.pdf m_co_0011.pdf m_co_0012.pdf m_co_0013.pdf m_co_0015.pdf m_co_0017.pdf m_co_0018.pdf m_co_0019.pdf m_co_0020.pdf m_co_0023.pdf m_co_0024.pdf m_co_0025.pdf m_co_0027.pdf m_co_0028.pdf m_co_0029.pdf m_co_0030.pdf m_co_0031.pdf m_di_0001.pdf m_di_0003.pdf m_di_0004.pdf m_di_0018.pdf m_di_0021.pdf m_di_0022.pdf m_di_0024.pdf m_di_0026.pdf m_di_0032.pdf m_di_0033.pdf m_di_0039.pdf m_di_0045.pdf m_di_0046.pdf m_di_0052.pdf m_di_0053.pdf m_di_0060.pdf m_di_0063.pdf m_di_0065.pdf m_di_0067.pdf m_di_0073.pdf m_di_0079.pdf m_di_0082.pdf m_di_0084.pdf m_di_0086.pdf m_di_0089.pdf m_di_0092.pdf m_di_0097.pdf m_di_0104.pdf m_di_0105.pdf m_di_0107.pdf m_di_0114.pdf m_di_0117.pdf m_di_0119.pdf m_di_0120.pdf m_di_0123.pdf m_di_0127.pdf m_di_0129.pdf m_di_0133.pdf m_di_0138.pdf m_ec_0001.pdf m_ec_0002.pdf m_ec_0003.pdf m_ec_0004.pdf m_ec_0005.pdf m_ec_0007.pdf m_em_0001.pdf m_em_0003.pdf m_em_0004.pdf m_em_0014.pdf m_em_0015.pdf m_em_0016.pdf m_em_0019.pdf m_em_0023.pdf m_em_0025.pdf m_em_0026.pdf m_em_0037.pdf m_em_0043.pdf m_em_0047.pdf m_em_0049.pdf m_em_0060.pdf m_em_0062.pdf m_em_0066.pdf m_em_0071.pdf m_em_0075.pdf m_em_0084.pdf m_em_0090.pdf m_em_0092.pdf m_fi_0001.pdf m_fi_0006.pdf m_fi_0010.pdf m_fi_0011.pdf m_fi_0012.pdf m_fi_0013.pdf m_fi_0014.pdf m_fi_0015.pdf m_fi_0016.pdf m_fi_0017.pdf m_fi_0018.pdf m_fi_0019.pdf m_fi_0021.pdf m_fi_0022.pdf m_fi_0024.pdf m_fi_0026.pdf m_fi_0027.pdf m_fi_0028.pdf m_fi_0029.pdf m_fi_0030.pdf m_fi_0031.pdf m_fi_0033.pdf m_fi_0035.pdf m_fi_0036.pdf m_fi_0037.pdf m_fi_0038.pdf m_fi_0040.pdf m_fi_0042.pdf m_fi_0043.pdf m_fi_0044.pdf m_fi_0045.pdf m_fi_0047.pdf m_fi_0048.pdf m_fi_0049.pdf m_fi_0050.pdf m_fi_0051.pdf m_fi_0052.pdf m_fi_0053.pdf m_fi_0054.pdf m_fi_0055.pdf m_fi_0056.pdf m_fi_0058.pdf m_fi_0059.pdf m_fi_0060.pdf m_fi_0061.pdf m_fi_0062.pdf m_fi_0063.pdf m_ig_0001.pdf m_ig_0005.pdf m_ig_0006.pdf m_ig_0007.pdf m_ig_0008.pdf m_ig_0009.pdf m_ig_0010.pdf m_ig_0011.pdf m_ig_0013.pdf m_ig_0014.pdf m_ig_0015.pdf m_in_0001.pdf m_in_0003.pdf m_in_0004.pdf m_in_0008.pdf m_in_0009.pdf m_in_0010.pdf m_in_0020.pdf m_in_0025.pdf m_lu_0001.pdf m_lu_0003.pdf m_lu_0005.pdf m_lu_0009.pdf m_lu_0010.pdf m_lu_0011.pdf m_lu_0012.pdf m_lu_0013.pdf m_lu_0014.pdf m_lu_0015.pdf m_lu_0016.pdf m_lu_0017.pdf m_lu_0018.pdf m_lu_0019.pdf m_lu_0020.pdf m_lu_0021.pdf m_pp_0001.pdf m_pp_0003.pdf m_pp_0004.pdf m_pp_0005.pdf m_pp_0006.pdf m_pp_0007.pdf m_pp_0008.pdf m_pp_0009.pdf m_pp_0010.pdf m_pp_0011.pdf m_pp_0012.pdf m_pp_0013.pdf m_pp_0014.pdf m_pp_0015.pdf m_pp_0016.pdf m_pp_0017.pdf m_pp_0018.pdf m_pp_0019.pdf m_pp_0020.pdf m_pp_0021.pdf m_pp_0022.pdf m_pp_0023.pdf m_pp_0024.pdf m_pp_0025.pdf m_ss_0001.pdf m_ss_0002.pdf m_ss_0003.pdf m_ss_0004.pdf m_ss_0011.pdf m_ss_0013.pdf m_ss_0014.pdf m_ss_0015.pdf m_ss_0016.pdf m_ss_0017.pdf m_ss_0018.pdf m_ss_0019.pdf m_ss_0020.pdf m_ss_0021.pdf m_ss_0022.pdf m_ss_0023.pdf m_ss_0024.pdf m_ss_0025.pdf m_st_0001.pdf m_st_0002.pdf m_st_0003.pdf m_st_0005.pdf m_st_0009.pdf m_st_0010.pdf m_st_0013.pdf m_st_0015.pdf 230 File(s) 19,762,061 bytes 0 Dir(s) 87,477,243,904 bytes free Sorry about the formating of the directory dump.
05 Elise Racing Green/Red, Touring, Hardtop, StarShield |
When I search under Celica/English it says no documents are available. WTF?
'05 Storm Titanium / Red Touring / Hardtop / Stage 1 / Exige Wheels / Ohlins / RTD Brace / Traqmate |
#8 (permalink) |
Exige enthusiast...
difficulty finding and downloading manuals
During my past visits at the Toyota Europe site, while attempting to download manuals for the Elise engine, I was not impressed with the ease of either finding the correct manuals or with the ease of downloading them.
Their search engine often returned no matches while the manuals were in fact there. Miguel has done a fine job describing exactly what manuals are there and how to avoid the difficulty in getting them. I suggest looking carefully at the car and the model to decide where to find the manual and then going there directly. It takes a lot of patience to download them and confirm you got them all. There might even be some benefit to getting some of the other manuals in oder to confirm some of Toyota's engine practices... Do not believe the search engine results. Michael |
#9 (permalink) | |
(I finally got around to finding the time to download the manuals the other night, but they weren't there). Anybody want to provide a service of burning the engine manuals to CD? I'll still pay Toyota and download the trans manuals, but I want the engine manuals too... Teach me for procrastnating...
#10 (permalink) |
Yeah, I tried to get the celica listing and it doesn't show anything at all, maybe they are updating the contents for the Celica or something.
Edit: Tim, you should have downloaded the manuals instead of people that called the standard wheels Touring wheels.
#11 (permalink) | |
.I have been waiting for some time when I could sit down and do it since it is supposed to take a while. Normal days I'm too busy. The weekends are usually take up with other things and Honey-Dos. The other night, my wife was at a board meeting until very late, so I thought I'd go for it. Then I found out it was gone.
#12 (permalink) |
OhioLotus.com
Bump. I'm still trying to find the repair manuals for the the 2ZZGE. I can't seem to find anything on that Toyota Europe site. Found someone selling the paper version, but would rather have on PDF (http://www.books4cars.com/search~fin...~offset~-1.htm). Any ideas here?
#13 (permalink) |
The transmission (RM930E) and the engine supplement (RM929E) are still in there.
The main engine repair one (RM733E) is no where to be found.
#14 (permalink) |
Am I getting this right? To get an engine service manual I need to subscribe to the Toyota Europe site and hope to get it all. To get Lotus manuals, somehow the site has to be fixed and then I have to pay a subscription and never receive updates? There is no other way? What a joke!
#15 (permalink) |
Exige enthusiast...
there is another way..
There is another way, normal if you will, of getting all the required manuals.
You just go to the local parts counter at your local Lotus dealership and order "paper" manuals. They still come the good ol' fashion way. They come as one Lotus Service manual, one engine and one supplemental engiine manual. You might try and get the parts manual and all the updates and even the technical service bulletins while you are there. I apologize, as sarcasm does not convey well on the forum. In truth, it would be so much better to have the electronic forms of the documentation available readily on the web. Many of us know how to do that but it seems the manufacturers do not. They have converted to electronic form internally so I was hoping it was just a short step to making them available online. It appears Lotus and Toyota tried but for unknown reasons were not successful. Those of you that enjoy conspiracy theories might suggest that the dealerships and their service departments stopped the readily available information flow, fearing it might take away business as we will all start doing our own maintenance. The worst part is that we could solve this problem quickly all on our own! Apple will include a bit torrent client in the next release of the operating system. Several game developers distribute updates using a peer-to-peer client. We(!) could set up a distribution method if Toyota and Lotus would just let us. I have it but cannot give it to you without getting into trouble. Worse, none of the Technical Service Bulletins are getting updated any longer. Rant over, sorry for venting, just make it so... Michael |
#17 (permalink) |
The two supplements are available,
http://techdoc.toyota-europe.com/pdf...EG0013_0_1.pdf http://techdoc.toyota-europe.com/pdf...EG1012_0_1.pdf Still no luck on the actual manual. |
#18 (permalink) |
Meow!!
You have to register (free) but the 2000 Celica repair manuals are posted online in 2 PDF's - and a parts manual to boot:
http://newcelica.org/forums/showthread.php?t=216130 Enjoy!
d.a..v...i....d David Thomas Stewart - davidtstewart@gmail.com TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs. Lotus cars aren't made, they're hand built from dreams. If you must choose between two evils, pick the one you've never tried before. Last edited by darkSol : 11-04-2006 at 08:34 AM. |
#19 (permalink) | |
Mountain Road Nut
#20 (permalink) |
I found this service manual on-line. It's for the S2 with Rover engine. I haven't gotten been able to find the 2005 US version from the Lotus site yet.
I don't think this is exactly what I wanted, but for $8 what the heck.
Current: 2005 Elise LRG - BWR SC Gone, but not forgotten: '91 NSX, '95 Z3, '79 280ZX, '66 Mustang and others. Friends don't let friend's drive 4-doors. |
