Old 08-02-2008, 03:07 PM   #1 (permalink)
AR #0369
foosh's Avatar
Images: 4
Undertray allen bolts stripped/frozen
I apologize if this has been dealt with elsewhere, but a search for all the keywords I could think of produced nothing.
I decided to do my own oil change today. The last one was done at the dealer in conjunction with one of the regular checks while the car was under warranty.
I cannot remove either of the two allen head bolts in the undertray near the NACA ducts. They appear slightly stripped and/or over-torqued. Even though they don't need to be removed the allen bolts in the diffuser move just fine.
Does anyone have suggestions? My first instinct is to try to JB Weld an allen wrench into each, and then replace the bolts later. I hate drilling out bolts. Nothing about this car ever seems to be simple.
foosh is offline   Reply With Quote
Old 08-02-2008, 03:15 PM   #2 (permalink)
道のお父さん
RoadDad's Avatar
I don't have any allen head bolts anywhere near my undertray .
Are you talking about the two large bolts that hold the tray to the cross-member?
"There are two things no man will admit he cannot do well: drive and make love." -- Stirling Moss
Nunquam est ponenda pluralitas sine necessitate.
Pluralitas non est ponenda sine necessitate.
Pluralitas non est ponenda, nisi ubi est necessitas.
Old 08-02-2008, 03:21 PM   #3 (permalink)
AR #0369
foosh's Avatar
Images: 4
Yes. It is an '05 Elise, and those bolts have allen heads in my car.
Old 08-02-2008, 03:23 PM   #4 (permalink)
道のお父さん
RoadDad's Avatar
Nice.
What about something like a screw extractor?
Old 08-02-2008, 03:27 PM   #5 (permalink)
道のお父さん
RoadDad's Avatar
You don't have to drill out the screw with these.
Craftsman 7 pc. Drill-Out/Screw-Out Power Extractors - Model 720SR at Sears.com
They bite into the head and as your drill turns in reverse out comes the stripped item. Only problem I foresee is the allen head being too large.
Old 08-02-2008, 03:31 PM   #6 (permalink)
AR #0369
foosh's Avatar
Images: 4
Yeah, that's probably the best solution.
Old 08-02-2008, 03:33 PM   #7 (permalink)
道のお父さん
RoadDad's Avatar
I'd swap them for hex head bolts when you get them out. M8 x 1.25 x 25
Old 08-02-2008, 03:36 PM   #8 (permalink)
009 License to Drill
BRTHTAKR's Avatar
One of my original bolts here stripped too. They are pretty cheesy. I cut a slot into it and removed with a large screw driver. Seems like I used something like a Dremel with a small disc to cut the slot).
Then I replaced them with SS bolts with a much more substantial size allen.
I discovered this during my first oil change.
Simplicity is the ultimate sophistication. Leonardo Da Vinci
2005 Elise LRG, Trim Shop interior
2007 Toyota Tundra (about 10 cup holders)
2004 BMW X3 (4 small cup holders)
1980 Rover SD1
BRTHTAKR is offline   Reply With Quote
Old 08-02-2008, 03:39 PM   #9 (permalink)
El Jefe - Agent 111
Randy Chase's Avatar
Images: 761
Same thing. Dremel to make a square bolt head out of it. Removed and replaced.
Oh, use loctite blue when you put the new ones in.
We have been feeling the buzz since 2002
2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds.
..is a stranger in an open car. Tempt you in and drive you far away
Old 08-02-2008, 03:44 PM   #10 (permalink)
Just picked up my Elise SC today. Quick questions is there a tool kit that is supposed to come with the car. Car is very cool Chrome Orange, Hard Top, Touring Pkg., Sport Pkg. Believe it or not traded in a 2008 Gallardo Spider left with a big check and a great car.
yelotail is offline   Reply With Quote
Old 08-02-2008, 03:49 PM   #11 (permalink)
El Jefe - Agent 111
Images: 761
Not sure now... but the earlier cars came with the tool for removing the lugbolts (splined driver) and a tool for the locking lugs (which was eventually dropped) and two Allen wrenches. This was in a little pouch with velcro in the boot. Also there was a flat-in-a-can back there above the passenger side wheel well.
Old 08-02-2008, 03:59 PM   #12 (permalink)
thought they would have had the tool to take off the hard top...oh well. What about the tow ring for getting it on a flat bed
Old 08-02-2008, 04:06 PM   #13 (permalink)
AR #0369
foosh's Avatar
Images: 4
Thanks for all the good ideas . As usual, this site is invaluable, and there are plenty of smart, experienced people willing to jump in and help.
Since, I have to destroy those bolts with an extractor/dremel or whatever, I think I'll try the JB Welded allen wrenches first, since that stuff rarely fails me, and then replace them with the bolts above.
If that doesn't work, I'll go get the kit RoadDad suggested from Sears and replace with the hex head bolts above.
You guys are great!
Old 08-02-2008, 04:09 PM   #14 (permalink)
El Jefe - Agent 111
Images: 761
Forgot, it did include the tow ring too.
Old 08-02-2008, 04:13 PM   #15 (permalink)
thanks I will call the dealer and have them send it all to me. air conditioning is what everyone has been discussing. it somtimes blows so cold then gets warm and then gets cold again...at least it is cold sometimes.
Old 08-02-2008, 05:18 PM   #16 (permalink)
Dude, There's My Car
xxxotic's Avatar
I had the same problem with the allen bolt being frozen and the allen wrench opening was stripped. Havent fixed it yet, I just noticed it when I was loosening and retightning the bolts to see if I could locate a rattle. Have to go to Home Depot and get the hex head bolts once I get the bolt out.
I did a search about a month ago and several people reported the same problem. I cant find the thread but the reason was because the top part of the hole where the bolt goes into is uncovered and junk gets in there and freezes up the threads. You should put wd40 on the top area and let it run down to clear out the junk and then make sure the threads are clean. People then put caulk or silicone over the top part to stop junk from getting back in there again.
Here are the links
Undertray bolts... a suggestion
moremonkey.com • View topic - Stuck Diffuser / Engine Tray Bolt Issue...FIX
xxxotic is offline   Reply With Quote
Old 08-02-2008, 05:38 PM   #17 (permalink)
AR #0369
foosh's Avatar
Images: 4
Thanks. Ace10 was kind enough to PM the link to his thread earlier, which I found extremely useful. I will indeed change the bolts to hex heads when I get them out, seal the hole from the top, and properly lube new bolts and receptacles to prevent the problem in the future.
The biggest issue here is that there is no excuse for putting allen head bolts in that application in my opinion. I take it later cars included hex-head fasteners.
Old 08-02-2008, 07:09 PM   #18 (permalink)
BRTHTAKR's Avatar
But if you are going to use a hex head in such a location, at least make it substantial enough that you can engage it once the road grundo is chiseled out.
1980 Rover SD1
Old 08-03-2008, 04:54 PM   #19 (permalink)
AR #0369
foosh's Avatar
Images: 4
For those interested in this mini-saga, I was able to remove the frozen allen head undertray bolts using 2 methods suggested here.
RoadDad suggested getting a Sears screw/bolt extractor kit which I did. It did a great job of removing one bolt. In the process of removing the second bolt, the same extractor bit broke off inside. Once that happens, you are basically screwed because you can't easily drill through those hard extractor bits.
As a "Hail-Mary" move, I cut a slot with a Dremel cutting wheel almost all the way through the bolt head per Brthtakr's suggestion, hammered a big screw driver into the slot, and attached vice-grips to the screw driver. Rather miraculously, it did back out the recalcitrant bolt, and I think the cutting and drilling may have finally freed the bolt.
Between driving to gather extractors, new bolts, figuring and fiddling, it was only a 7 hour oil change, of course, only 30 minutes was the actual oil change........LOL. Gotta love the Lotus.
Old 08-03-2008, 05:12 PM   #20 (permalink)
道のお父さん
RoadDad's Avatar
Didn't think that would happen.
HTML code is On
