Old 11-24-2008, 09:30 PM   #1 (permalink)
Form and Function
plastique999's Avatar
Vanishing Oil Syndrome
Has anyone ever had issues where they have been burning vast amounts of oil with no sign of leak?
After driving just under 1000 miles since oil change, my dipstick was dry and took 2 1/2 quarts to normalize (I also have Moroso oil pan).
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 11-24-2008, 09:34 PM   #2 (permalink)
Dinky Plastic Car Owner
tsunami racer's Avatar
when the car was new, my exige drank oil a bit, but not that terribly much.
my audi RS4 used to consume a quart of oil every 1000 miles and everyone said it was normal.
2007 EXIGE S - Nightfall/Black
2007 Lotus Elise (sold)
2004 Subaru STi (sold)
1989 Metro Bus Pass (sold)
1984 BMX Dirt Bike (sold)
1979 Big Wheel (sold)
tsunami racer is offline   Reply With Quote
Old 11-24-2008, 09:41 PM   #3 (permalink)
milehitom's Avatar
Yes. it's called a Fiat Spider I keep a few quarts in my trunk at all times...
It's actually quite normal for a cast-iron block car.
I have an '05 Elise, as well. Zero disappearing oil issues with mine. I'd be tempted to pop the diffuser off and see if there's some oil splatter on the inside. Is it possible that with the Moroso pan, not enough oil was added at the last oil change?
Tom
milehitom is offline   Reply With Quote
Old 11-25-2008, 07:24 AM   #4 (permalink)
2009 XP National Champion
fzust's Avatar
If you didn't change it yourself, it could be that whoever did it, filled it and then whatever oil drained from the coolers was pumped back in and put you a couple quarts low. The second option is oil dillution. If you have fuel getting past the rings, then it could be dilluting the oil, which makes the oil much more prone to burning in the cylinder and without smoke. Compression & leakdown should tell the tale there. Probably better to top off the oil again and keep an eye on it.
Old 11-25-2008, 08:33 AM   #5 (permalink)
lt0302's Avatar
Arrow Check
I have an 05 with the Moroso Oil pan and my plug leaked........when to checkers got a teflon washer for 3 bucks and no problem. Might want to check yours......I know others have had that issue also.......
05 Lotus Elise R/K Supercharger, Stage II, Moroso Oil Pan, RTD Brace, High Volume All Aluminum Radiator, Stainless Steel Break Lines, Oil Catch Can, ACT Clutch, HID, Carbon Fiber Spliter, Reverie Side Scoops, CF side skirts, FF gauge pod, BWR gauge pod, Cup Air Box, S111 front & rear tow hooks, upgraded tail lights-LED, Driving lights, LETSLA, ...
lt0302 is offline   Reply With Quote
Old 11-25-2008, 09:07 AM   #6 (permalink)
registered nipple
fishguy's Avatar
Images: 1
make sure to check the oil level before every session that you are tracking you car.
2008-2009 SCCA AZ Regional "Driver of the Year"
1986 Swift DB-1 Sold
2008 HSR-West FF 3rd generation Champion
2008 "The Series" FF 3rd generation Champion
1987 Porsche Spec 944
2008-2009 season SCCA AZ regional Champion
Old 11-25-2008, 09:20 AM   #7 (permalink)
without a Lotus
FLuXeXigeS's Avatar
Eddie, you might also want to check the OIL pan itself, i heard of a few people having leaks on them brand new, around the welds...my .02
time for me to check my oil
-Coi- currently having Lotus withdrawals
Facebook | Twitter | Pics | Vids
eBay Store
FLuXeXigeS is offline   Reply With Quote
Old 11-25-2008, 09:36 AM   #8 (permalink)
Form and Function
Compression and leak down tests have been done and were normal...
The vanishing oil happened once, as well, before the Moroso oil pan....so that's prob. not it either...
The other quandary is that both times this happened, my oil sensor Never lit up...so I'm assuming the oil sensor is faulty as well...
www.FaceNBody.com
Old 11-25-2008, 09:44 AM   #9 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
The sensor is a pressure sensor, not a level sensor... so even if your oil level is low, but not so low that it's below the pump's pickup in the oil pan, you'll still have pressure. Does the light go on before you start the engine, then go off as soon as it starts? If so, it's probably fine...
Old 11-26-2008, 11:34 AM   #10 (permalink)
Form and Function
Andy, not sure if the engine lit up then off after start....can't check now as my motor is apart...
So far, I think the oil loss was due to blow by - one of the rings may have been bad
www.FaceNBody.com
Old 11-27-2008, 03:57 PM   #11 (permalink)
Form and Function
What are some ways to prevent oil starvation again?
I have the Moroso oil pan, and I will be adding Accusump, as well as sensors for oil pressure and oil temp.
I just want to ensure that this problem won't happen again.
www.FaceNBody.com
Old 11-27-2008, 11:35 PM   #12 (permalink)
without a Lotus
FLuXeXigeS's Avatar
if its due to blow by maybe sleeving the cylinders and getting better piston rings may also help
eBay Store
Old 11-28-2008, 12:04 AM   #13 (permalink)
Hydrocarbons Rule
Dragon's Avatar
Images: 2
If it's not a leak and since the above checked out my next guess would be valve guide seals.
Dragon is offline   Reply With Quote
Old 11-28-2008, 08:13 AM   #14 (permalink)
Form and Function
True Coi, but that would put me in the direction of building out a race engine, and at this point, I'm most concerned about building a Reliable engine.
After our discussion, I decided to replace the short block, and do some "tweaking" for more power and durability.
This is probably the diagnosis...should know soon as the motor is apart.
www.FaceNBody.com
Old 11-28-2008, 09:20 AM   #15 (permalink)
without a Lotus
FLuXeXigeS's Avatar
are you getting the short block we found online?
eBay Store
Old 11-28-2008, 09:35 AM   #16 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
A couple pennies for the jar...
You should be able to pick up a short block for ~1,400 bucks and 9:1 forged pistons from MWR for ~500 bucks. Install them yourself...You'll then have a short block good for all the power you will likely ever run... and be more reliable than stock... You can even reuse the head bolts one time for milder builds like you're probably doing... This can be a very reasonable operation and you'll come out with a heck of a nice setup with a lot of potential...
Best,
Phil
Old 12-13-2008, 03:32 PM   #17 (permalink)
Form and Function
Hey Coi, I actually am replacing with the stock short block...
I am also upgrading the valve springs, installing Accusump, datalogger with sensors, possibly catch cans, and ACT clutch...adding the 2bular decat and GT3 exhaust....gonna be bitchin!
Future: TVS upgrade...
Best,
Phil
Thanks Phil, I was strongly considering this, and Coi and I were looking at the blocks on the MWR website. I was debating whether or not to upgrade the pistons, but decided not to...perhaps should have
I am following your TVS thread closely, and after my motor is built, I would like to add your kit as an upgrade....
I have seen others upgrading to 255 fuel pump as well...any other suggestions with your kit?
www.FaceNBody.com
Old 12-13-2008, 06:53 PM   #18 (permalink)
without a Lotus
FLuXeXigeS's Avatar
^thats tight eddie, when is the ride gonna be ready?
eBay Store
Old 12-14-2008, 12:49 AM   #19 (permalink)
Form and Function
Should be picking it up this coming week....new data logger should be sweet!
And I can't wait to spit flames!
www.FaceNBody.com
