Old 05-21-2007, 06:36 AM   #1 (permalink)
Laughin' Easy
FlyLo's Avatar
What is the proper torque for the front control arm/toe link?
The toe link (?) for my right front wheel has a loose bolt. It looks "just like" the joint for the rear toe link.
I've tightened it, but I don't know the correct torque.
Can someone help?
Thanks.
Also, if you can confirm the updated torque spec for rear toe link, that would be great.
FlyLo is offline   Reply With Quote
Old 05-21-2007, 08:35 AM   #2 (permalink)
Regurgitated User
fitfan's Avatar
what updated spec ?!?!
Driving it around!
Old 05-21-2007, 08:40 AM   #3 (permalink)
Randy Chase's Avatar
Images: 761
<img src="http://www.elisetalk.com/forums/attachment.php?attachmentid=49972&stc=1&d=11745930 61">
Originally Posted by MyElise
1 Lb-Ft = 1.35582 Nm
re: Toe Link (and recheck them after some time/miles)
Originally Posted by Jack
It used to be 50nm -- Lotus now recommends 60nm for that bolt.
Please do not PM me. My box is full. Thanks.
Old 05-21-2007, 08:44 AM   #4 (permalink)
Laughin' Easy
FlyLo's Avatar
Ack. I can't see attachments from EliseTalk. Must be an "enhanced" work filter.
Old 05-21-2007, 08:46 AM   #5 (permalink)
Images: 761
Even if you click on this link?
http://www.elisetalk.com/forums/atta...1&d=1174593061
Old 05-21-2007, 11:07 AM   #6 (permalink)
TimMullen's Avatar
Images: 19
I think Randy listed the torque settings for the rear suspension - which are essentially the same as the front. The front settings are listed below, and assuming that you are talking about the track rod end/steering arm joint (the red arrow in the diagram), then the nut should be torqued down to 30 NM (whatever that translates to in foot-lbs) - this value has not been adjusted, it was the torque for the inner end of the toe-link in the rear that was changed.
The other end of the track rod (aka tie-rod, aka toe-link rod - but it shouldn't be called that on the front) is connected to the steering rack and not part of the suspension bushings (the part that needs to be checked often in the rear).
94 Miata R Package - Black
Old 05-21-2007, 11:17 AM   #7 (permalink)
Laughin' Easy
FlyLo's Avatar
"The page cannot be displayed"
Yep. Even the avatars are blocked. I think we "updated" our web filters.
Old 05-21-2007, 12:16 PM   #8 (permalink)
TimMullen's Avatar
Images: 19
I've been getting similar results at work. Lots of linked photos are blocked, but the attached ones usually are shown. No problem at all from home. Damn filters at work...
Old 05-21-2007, 04:35 PM   #9 (permalink)
Laughin' Easy
FlyLo's Avatar
Track rod end to steering arm 30 Nm
Perfect and thanks!
