Old 05-19-2005, 07:52 AM   #1 (permalink)
Probably Lurking
Keeper's Avatar
Window Rattle Fixed
My passenger window rattled when it was all the way down. Before the adjustment I could easily hear the rattle noise when closing the door or wiggling the glass. I had tried tightening the screws at the top of the rails as has been suggested, but they were already tight. (BTW, that's a very easy check and you should start there.)
Read the warning posted later in this thread from TheViper before adjusting these screws: Window Rattle Fixed
It sounded like the rattle was coming from the glass hitting the aft rail. Assuming clockwise turns of the window angle screw at the bottom of the door would only press the window tighter against the seal when up, I figured it wouldn't hurt to try it.
I turned the screw a half turn clockwise and the rattle diminished. I turned it another half turn and the rattle was essentially gone. I turned another half turn for good measure and called it good.
I may have been a little lucky, but I bet some independent adjustment of the window angle screws will fix this rattle for most people.
-Shawn
Keeper is offline   Reply With Quote
Old 05-20-2005, 07:58 AM   #2 (permalink)
hpman's Avatar
please post photos of the location of the adjustment screws.
hpman is offline   Reply With Quote
Old 04-28-2006, 08:30 AM   #3 (permalink)
Probably Lurking
Keeper's Avatar
Almost a year later . . .
Old 04-28-2006, 09:44 AM   #4 (permalink)
AR/Biscuit Touring HT SS
glitch's Avatar
i have this exact same problem. i'll definitely have to try this fix when i get home tonight.
glitch is offline   Reply With Quote
Old 04-28-2006, 09:48 AM   #5 (permalink)
edaddy's Avatar
Images: 2
Shawn, Thanks for your post. I too have the same problem with the passenger window. Which of the two screws did you adjust?
#2116 - Aztec Bronze
edaddy is offline   Reply With Quote
Old 04-28-2006, 10:22 AM   #6 (permalink)
What a Machine!
Gridlock's Avatar
Man, I positively live this forum!! I have had this rattling window problem since I bought the car over a year ago... I sort of tuned it out, but it was always annoying. A couple of turns of both screws, and WELLA, rattling gone!
- Stew
Gridlock is offline   Reply With Quote
Old 04-28-2006, 11:26 AM   #7 (permalink)
glitch's Avatar
have you noticed whether it messes w/ the window position when it is all the way up? both my windows line up perfectly with both tops in their current position and i'd hate to screw that up to fix a little rattle...
Old 04-28-2006, 12:38 PM   #8 (permalink)
What a Machine!
Gridlock's Avatar
I haven't checked that yet. I checked that the window goes up and down without binding, but have not checked the way it lines up at the top. My impression is that it doesn't effect the position, but I could be wrong. The screws that I tightened a bit certainly seem quite loose to me.
- Stew
Old 05-23-2006, 09:23 PM   #9 (permalink)
Probably Lurking
Keeper's Avatar
Somehow I missed your post.
I adjusted the window so that it made good contact with the weatherstrip then I tweak each one until the rattle was gone. I tried to favor tightening vs. loosening to prevent leaks.
Old 05-25-2006, 03:39 PM   #10 (permalink)
AR #0369
foosh's Avatar
Images: 4
Thanks, I just acquired a used '05 Elise and discovered this thread. You just cured one of my rattles as well as a passenger side leak problem.
Can't the internet be wonderful?
foosh is offline   Reply With Quote
Old 06-10-2006, 09:34 AM   #11 (permalink)
chill's Avatar
Images: 2
whew.....
Hey Clay... Glad you're enjoying your car!
This kinda thread is what its all about! I just stumbled on the thread last night, went to the garage this morning, tightened the screws and the door doesn't rattle anymore... after only 10,000 miles....
...hmmmm... what else can I find around here? Let's see, my trans buzzes at stable rpms... no wait that is in a thread already... no, 2 threads, 3.....
...I need 048s...
...rear suspension brace anyone?
...what's an ECU dump smell like?....
...how much does the dash sharp edge fix weigh??
I Love EliseTalk!
"If everything seems under control, you're not going fast enough." - Mario Andretti
chill is offline   Reply With Quote
Old 06-10-2006, 07:02 PM   #12 (permalink)
NapaTim
landenistim's Avatar
I am rattle free - thanks!!!
BRG Elise
Mazda RX-8
Porsche Cayenne S
landenistim is offline   Reply With Quote
Old 06-10-2006, 07:11 PM   #13 (permalink)
Red Alert
OriginalBlackCi's Avatar
Thanks for bumping this, I've had this problem for a while and missed this thread.
--Ramsen
www.euroteknik.com-- Chicago's Premier Euro Community
OriginalBlackCi is offline   Reply With Quote
Old 12-01-2006, 12:59 PM   #14 (permalink)
Athens, GA Orange Elise
TheSaint's Avatar
my window sounds like its about to crack when it gets half way down....it gets right..then "pops" past the half way point as it goes all the way down...does the same when closing it. Any thoughts?
2003 Porsche 911 Turbo - Silver / Red
Sold 2005 Lotus Elise - Chrome Orange
Sold 2002 BMW 745i - Gray Metallic
Atlanta, GA
TheSaint is offline   Reply With Quote
Old 12-01-2006, 01:03 PM   #15 (permalink)
It's a Lotus
LARRY's Avatar
Shhhhhh...don't say that too loudly around the car. It'll hear you and the squeaks will.......................start!
2005 Saffron Yellow Elise. Stage II Exhaust. 2007 ProBax seats.
LARRY is offline   Reply With Quote
Old 12-06-2006, 01:01 AM   #16 (permalink)
GRL
GRL's Avatar
Check that your power window cable harness is not obstructing the window's travel. My PAX window had the same problem and by re-dressing this power feed harness it's as smooth as silk now
05 Elise: Starlight Black, 2Bular 7x18" Exhaust, Re-trimmed Interior.
GRL is offline   Reply With Quote
Old 01-01-2007, 05:38 PM   #17 (permalink)
cdn_alien's Avatar
Help!
I did what everyone suggested. I turned the screw clockwise one turn, and tried closing the door to see if the rattle diminished. It went 'clunk', and the screw fell out onto the floor! The window still seems to be working, but whenever I lower the window, the screaching sound (like the window about to crack) is still there.
Can anyone help?
cdn_alien is offline   Reply With Quote
Old 01-01-2007, 06:15 PM   #18 (permalink)
ToYoTa dRiVeR
Imolas54's Avatar
just in case.... did you try putting the screw back in and turning it the other way?
Imolas54 is offline   Reply With Quote
Old 01-02-2007, 07:52 PM   #19 (permalink)
cdn_alien's Avatar
I can't do that. I think the bolt fell "into" the door cavity, and came out the bottom through another opening.
Current: '06 Chili Red Elise, '06 Infiniti M35
Sold: '03 Nissan 350Z , '00 BMW 325Ci, '99 Miata, '90 Miata
Old 03-13-2009, 01:35 PM   #20 (permalink)
Also, my rug was stolen.
elisesile's Avatar
bump - so I remember to try this tonight when I get home
05 Lotus Elise S/T
06 Porsche Carrera S Coupe - for hauling kids and luggage
elisesile is offline   Reply With Quote
