| LinkBack | Thread Tools | Search this Thread | Display Modes |
#22 (permalink) |
I tried this, and all it managed to do was move my window further away from the car when fully raised.
So I readjusted while window was up and all is well now
2005 Magnetic Blue Elise - "the Lotus" (original I know) 2001 Jeep Wrangler - "soul crusher". If you dont GET it after you drive it, then you dont GET it - serpent |
#23 (permalink) |
Alarmed & Dangerous
I wanted to warn anyone who does this adjustment that it can lead to problems. I recently adjusted the passenger window using the front screw and it fell out into the door cavity. I now had to remove the door panel and use a magnetic pick up to retrieve the screw which was easy. The hard part was getting double ended screw back in location. The screw is located between the access hole and the base of the window frame, this location is almost unaccessible, both physically and visually. I had to remove the inside door lock release which gives a small hole to get your hand through and try to install the screw by feel alone. This was a painful experience because while pushing the window frame, which hurts your fingers, out to give space, your wrist is being cut into by the hole edges. I can't explain how frustrating this was, not really knowing what I was doing, being blind and additionally, anyone with large hands would probably find this procedure impossible. Eventually, I got the screw in a position that may not be perfect but everything works OK.
Michael |
#24 (permalink) |
In many cases, the rail's top screw is loose. To reach it, just take a philips screw driver with the window down, and tight the screw. Hard to see that's screw, but you can reach it by the window slot.When
____________________________________ Elise 2006, white, Katana Europa 1969, green, H22A, 194 whp, 1550# CONFIGTECH.ca / Solidworks |
#25 (permalink) |
Probably Lurking
@TheViper - Already posted earlier in the thread but I'll note it in the first post.
@elise/europa - already noted in the first post.
-Shawn (2005 Lotus Econoxotic) Uberpost -- things owners should know - common problems/fixes - rattles, squeaks, noises - read the manual - good ideas? - maintenance - mods - reference - abbreviations |
#26 (permalink) |
PETROL HEAD
Got the door panel off and some of the screws and 10mm bolts where loose. When the window is right to the top it rattles like hell, take it down 1/2 inch and no problem. I don't think this is an adjustment issue.
2009 EVO X MR 2007 CRG 125 Kart 2008 Jeep Grand Cherokee Diesel |
#28 (permalink) |
Dark As Knight
I've got this problem too, I tried the screw adjustment, but to no avail. Time for the next step.
05 Starlight Black on Black-Vader Package:Sport/Touring/Black LSS/Black Diffusor/Hardtop/Starshield/Extra Starshield/Leather Console/Tint/HID/Yellow Hi Beams/Micromirror/Carpet Buttons/Stan Shifter Mod/Trunk Bootie/Larini SE/Euro Grill/Fujita Intake/Azenis/ipod mod/4 JL Audio VR525-CXi/Starlight Black A/C Surround/Kemmler Seat Mod/Hardwired V1/Schroth Profi ii ASM/V-FORCE Harness Bar/S111 Harness Hardware/CRDMount/TitanQR/HNT Pad "Stuff sold by the gram is more fun than stuff sold by the pound" |
#29 (permalink) | |
PETROL HEAD
#30 (permalink) |
Alarmed & Dangerous
The top moves in and out, increasing or decreasing the angle of the window
Cheers, Michael
#31 (permalink) | |
PETROL HEAD
Regards Terry
#32 (permalink) | |
I played with the adjusters to no avail. After some rooting around I found the rail screws (somehow I missed this post..) The rail screw at the back of the door was all the way out. I sqeezed the screwdriver through the window slot and tightened it. The rattle's gone ![]()
"People think I'm an idiot or something, because all I do is cut lawns for a living. People don't say that about you...as far as you know." |
#33 (permalink) |
developed this rattle this weekend, the whole window was tilting back and forth as I put it up / down and would sometimes get stuck. I'll try this, it looks promising.
06 Exige CO BWRized 05 Civic "Special Edition" 05 Elise CO, Trim shop interior and other things...SOLD |
#34 (permalink) |
OK not thread jacking but just hushing the search police and maybe helping future people looking into this issue
I found these two screws in the bottom of my door and I do not know where they came from, does anyone know where they might go? I can grab the top corner of my window and tilt it back and forth... ![]() ^yeah I know nice background right?
#36 (permalink) |
that might have something to do with the whole window tilting then eh? I'll have to feel around better in there. I'm sure its going to be a lot of fun tightening these back down.
#37 (permalink) |
Daily Driver
The one on the right holds the front or back guide rail at the top to the door and the other could go a number of places in all the doors hardware.
2005 BORDEAUX RED PEARL ELISE: Sport Pack, Hard Top, Star Shield, Black Mesh Grill, De-snorkled, K&N Filter, CF Side Scoops & CF Splitter. 2005 TORNADO RED TRIUMPH DAYTONA 650 - SOLD 2004 SUPERCHARED TOYOTA TACOMA 4WD - SOLD |
#38 (permalink) |
Ok like stated, the one on the right was to the front rail at the top (the one notorious from coming loose and preventing your window from going all the way up.)
However I'm still trying to figure out the one on the left. I think it might be #28 by lotusgarage's description: ![]() However I think there is something that needs to be adjusted because I can still grab my window and lift it up and down! Maybe the "adjuster blocks?" (#22)
#39 (permalink) |
so... I put that top screw back in, apparently the hex head screw pictured above goes to the mirror possibly.
Here is what my window is doing even with that top screw in. It makes an annoying rattle at various RPMs too. anyone? ![]()
#40 (permalink) |
Daily Driver
Roll your window all the way down and look at the top of the back rail. It is bolted to a bracket that is fixed to the fiberglass door via epoxy. Mine broke free when enough people closed the door too hard. I had to take the top window gasket off in order to get in there and rough up the area, then re-epoxy the bracket to the door. Sounds like that maybe your issue. My window no longer rattles since the fix, though the glass slides forward and back whenever its rolled down, then wont roll up properly when the door is closed. I believe its the three problematic bolts listed in this thread, but I can't seem to tighten them or loosen them for that matter because I believe they are stripped. I'm not the first owner, but I'll get around to fixing that issue as well one of these days. Good luck,
