#41 (permalink) | |
Ready Steady Go!
#43 (permalink) |
Looks like the A/C folks will have to compete directly against the non-A/C folks. Oh well, at least it's only 45 lbs.
![]() Also... it looks to me like the two front speakers have moved from below the leftmost/rightmost A/C vents to a spot on the top of the dash closer to the windshield. Excellent!!! The 111S I saw had some serious kick/scuff marks on the grilles in the previous position. And the grilles looked pretty lame. The new layout is nice. |
#48 (permalink) | |
Project Nirvana Elise
![]() Join Date: Mar 2003
>>> At this point in its history (i.e., as used on the federal Elise), the chassis goes by the codename 121 and has not altered a lot since the dawn of the Lotus Elise Series 1 at the 1995 Frankfurt motor show. The secret is in the bonded aluminum—actually bonded and then riveted at key stress points using self-sealing fasteners manufactured by EJOT in Germany. Aluminum is a sensitive material given to heat distortion when welded, and bonding solves this problem for a small-scale maker like Lotus (as it does, indeed, for Panoz). Originally supplied by Hydro Aluminum Automotive Structures out of Tonda, Denmark, it still comes from the same company. Hydro was forced to open a U.K. subsidiary at Bromyard in Worcestershire in 1998 to meet volume requirements when the Elise-based Opel Speedster arrived. Ciba Polymers in Switzerland came up with the original bonding adhesive solution. Today, both the red adhesive that bonds the aluminum chassis bits together and the black adhesive that bonds the fiberglass panels to the chassis are produced by Dow Automotive. The naked chassis weighs roughly 155 pounds and there have been no recorded failures to date. —MATT DAVIS |
#49 (permalink) | |
The TRD race 2ZZ with beefed up internals is capable of 230 but not 300, wonder how he did it |
#50 (permalink) | |
On the road again
#51 (permalink) | |
Ready Steady Go!
#52 (permalink) | |
Clutch Artist
There's little room to increase the displacement, and I think the stroke is already too long and connecting rods are too short for reliable operation at 10,000rpm, which is what you'd have to rev to for 300hp.
'00 Celica GT-S |
#53 (permalink) | |
Modified bushings? Which bushings are responsible for what?
One thing I just read in the Autoweek article has me worried.
The Autoweek article doesn't say that control arm bushings have been modified. Thank goodness, because I would have probably had a seizure. It doesn't say they HAVEN'T been modified, though, either.What other bushings are there in a double-wishbone suspension, and what effect would more compliant bushings have on handling? The only other bushings I can think of are the bushings where the wishbones are joined to the chassis. If these were more compliant, wouldn't the car require more static camber to maintain ideal camber during hard cornering? How can that be good? And how can "more isolation from bumps and holes" not have a negative impact on road feel? I do not want to read the word "isolation" in an article about the Elise. I guess I might be overreacting, but I'm once bitten, twice shy when it comes to bushings. I want to be able to "run over an insect and know just through the messages coming through the wheel how many legs they have". Know what I mean? |
#54 (permalink) | |
Looking to buy....
Re: Modified bushings? Which bushings are responsible for what?
2002 Gray Kia Rio (Beater) 2002 Spa Yellow S2000 FOR SALE! 2006 Toyota Matrix 2005 Elise, looking for a SY or CO with a HT and TP in the NC area.
#57 (permalink) |
LSS still allowed in stock class? Curious-what happens if you order LSS and have the dealer install it, does that eliminate your car? It would seem that LSS will not have the softer bushings.
#60 (permalink) |
If LSS is factory-installed as the "sports package", which it sounds like it will be, then it should be stock-legal: even if someone added it "after the fact" since that's covered by an "option package conversion" allowance.
Aftermarket bushings would not be stock-legal. If part of the LSS/sports-package option is the harder Euro-spec bushings, I would be very happy indeed. |
