First Track Day Questions
I have my first track day coming up in a few weeks.
Where can I go get fitted for a helmet in the LA area? Does anyone recommend the CG-lock device from BWR?
2007 Elise - BRG (Full Ventureshield front by SCC, LSS wheels, polycarbonate chin guards, V1 on Mr.C bracket, LETSLA and Janspeed Stage II). 2005 Volvo XC-70 (Beagle carrier) 2001 BMW Z3 3.0 Coupe |
Personally, I don't like the CG lock. In the event of a serious accident you want the seat belts to work as designed and they are not designed with a foreign clamp involved. Until I see formal crash test fottage of the CG lock in action and working then I'd advise not to bother.
A pound at a time.
Check out Werks II out in burbank. Werks II Motorsports - Sparco, Alpinestars, Momo, Hans, Oakley, Arai, Bell, HJC
07 Exige S - PhB., TP, TP, LSD, S111 Rear Panel Delete, 2Bular De-Cat, 2Bular 8x24 Burnt GT3, Custom AEM Intake, 6k HID's, Schroth 4pt ASM Harnesses, Milled Steering Arms, Bronze Volk TE37 w/ RE-01R's, Carbon Craftsquare Mirrors, Carbon Front Lip, Benetec Dry Carbon Undertray/Diffuser |
G-200 Driver
Thanks folks, good inputs.
I bought a CG-lock from BWR last fall, but only used it for a couple track sessions before deciding a harness system was worth the investment. It's probably worth trying as an interim solution to keep you in your seat, but you'll probably want to swap it out if you do track or solo events with any regularity.
2006 Elise British Racing Green; LSS, LSD-TC, 2bular exhaust, Blackwatch Racing front bar, BWR Supercharger, Tillett Seats |
#7 (permalink) |
Excess ain't rebellion
If you want to see what it's like to use a CG lock without spending the $40 or so, get a seatbelt clamp from a baby/kid car seat. It's a metal clip that's used to hold the seatbelt in place when you attach a car seat with a 3-pt harness. It's not as convenient as the CG lock, which can be released easier, but has the same effect. I used one at my last track day and it made me feel more planted in the seat compared to using the seatbelt alone. If you or a friend have a car seat laying around (or one attached to a car using the LATCH system), you'll find the clip somewhere on the back of the frame of the seat. I think Babies 'r' Us sells them too. All that being said, a real harness is probably in order if you're going to spend any real time at the track.
-Brad
'07 Exige S Graphite Gray, LSD w/ TC, Track Pack, Star Shield |
#8 (permalink) |
the designer
The other thing with CG Lock is that some clubs or associations don't allow them so check your rules on that.
2008 Exige S 240 For Sale: 2005 stock shifter console and change holder. PM if your interested. |
#9 (permalink) |
I don't know if the federal elises's have seat belt pre-tensioners - if they do then do you really want a super tight seat belt clamped in place and then in a crash have what is effectively an explosive bolt fire to pull the seat belt even tighter? All that will happen is the seat belt will stretch more than it was supposed to and at best removing some of the energy absorbing effectivness of the belt and at worst increasing the risk of total belt failure.
#10 (permalink) | |
Not to hijack the thread, but... Thinking this through, if you're in an accident with the CG-Lock or the cheap-@$$ version I mention above, the effect of the pretensioner will be similar as if you weren't wearing one:
Now, an accident occurs that triggers the safety devices (not that I'm wishing that on anyone). The pretensioners fire and tighten the belt. If the CG-Lock is locked in place, only the shoulder portion of the belt tightens. If the CG-Lock is not being used, both the shoulder and lap portions of the belt tighten. Isn't the net effect the same since the lap belt was tightened when the CG-Lock was applied? Of course, this assumes you're using the device correctly. I don't sell the CG-Lock or work for anyone that does. Heck, I don't even own one. I'm just kind of thinking out loud here. Thoughts? -Brad
