Go Back   LotusTalk - The Lotus Cars Community > Community > Regions > Northwest Region
Old 08-05-2009, 11:19 PM   #1 (permalink)
abraham's Avatar
Recommend a garage near Bellevue/Redmond?
Since I spun out of the pavement at Bremerton two months ago, the car has a rattling sound from the driver rear around 10mph, like two metal parts knocking each other. Went to Park Place multiple times, could not solve the problem.
First time, they claimed the ceramic parts inside the catalytic converter got loose. Got a new cat, rattle still there.
Second time, I brought the mechanic for a ride. He claimed to hear all kinds of rattles, but not the one I describe. Tightened rear clamshell and license plate, removed LiDbone. No use.
Third time, mechanic said rattle came from driver front. Tighted front suspension bolts, removed LF grille (I installed it with a zip tie). The result was just like before, but PP claims no more rattle!
I suspected I had auditory hallucination , but then an instructor at Pacific Raceway confirmed the rattle this Monday. Now I need a reliable garage to locate this rattle and fix it, as I am getting obsessed to it I must get rid of the damn rat!
2005 AS Elise, everything stock except stage II exhaust
Daily driver? Why do I need one?
abraham is offline   Reply With Quote
Old 08-06-2009, 09:53 AM   #2 (permalink)
No Livestock on Track!
Evil Twin's Avatar
Images: 14
FWIW, I'm an instructor and an Elise owner, and I often get weird sounds that I cannot place. Don Kitch (owner of Proformance at Pacific Raceways) drove my car once after I heard a rattle that concerned me and came to the same conclusion: these cars make noises. Which is not to suggest that you shouldn't try to track down the source of the problem -- particularly if it seems to be coming from anything related to the suspension! -- but it is to suggest that you might reasonably *never* identify the source of the sounds and (in my experience) they often "go away" after a while.
2005 Graphite Gray with Black Interior, Sports Package, Touring Package, Hard Top, Starshield, 6-point Schroth Harness, Fire Extinguisher, and Wiring Loom for DL-1. Otherwise bone stock -- and staying that way -- okay, okay, that's true if you ignore the Braille battery, Micro mirror, Multivex mirrors, ROTA slipstreams, RA-1s, two-piece rotors, springs, polyurethane ASB bushings, RTD brace, Sparco seat, and all the stuff I've taken out of the car...
Evil Twin is offline   Reply With Quote
Old 08-06-2009, 12:51 PM   #3 (permalink)
Lotus-Position's Avatar
Yeah, Bog (a PP mechanic) and I went for many rides trying to figure out an annoying rattle coming from the front at low speed over bumps. Tried all kinds of stuff... finally figured out it was my after market pads rattling in the calipers
I even considered trying one of those remote listening devices... I guy could go crazy trying to track them all down though.
There is one way to fix all rattles though... ear plugs and turn up the radio!
Lotus-Position is online now   Reply With Quote
Old 08-06-2009, 08:25 PM   #4 (permalink)
abraham's Avatar
Thanks for the rattle stories. I will start by tightening the rear suspension bolts, as it "seemed" to be getting better with the front suspension "fix".
If I can never figure out the source, will try using the stereo to cover it. Never turned it on since I bought the car, as the engine sounds way better.
Old 08-06-2009, 09:10 PM   #5 (permalink)
Meow talk lotus one day?
andykeck's Avatar
Images: 1
If you do decide to take it somewhere, you need to go see Colin Cantrell:
Cantrell Motorsports
andykeck is offline   Reply With Quote
Old 08-09-2009, 08:14 PM   #6 (permalink)
I'd wait to see if it goes away. I was driving across some nasty roads and the drivers side of my front clam started squeeking every time i'd go over bumps. The next day it stopped.
2006 Polar Blue Exige
2002 Acura RSX
Lightning is offline   Reply With Quote
Old 08-09-2009, 10:09 PM   #7 (permalink)
abraham's Avatar
I has been two months, with numerous self checks and services at PP. It just never stops
