Rocker panel repair/replacement
In a disheartening garage mishap this afternoon, I managed to allow my jack to slip off the main jack point and crunch the driver's side rocker panel. I also cracked the panel immediately in front of the rocker, inside of the front left wheel, as the car dropped on a padded jack stand that was not yet in place beneath the front jack point.
I would appreciate some advice on: 1. Recommended repair path options and decent body shops. A search revealed Matt's recommendation for Stuart's Paint and Body in an older thread. Is this the best option for out-of-pocket repairs in the DFW area? I am keeping the car in otherwise good shape but it's by no means a garage queen. I'd like to get it solidly and nicely fixed but don't require OEM replacement parts if they're not necessary. Does this look like a fiberglass repair or a full part replacement? 2. Guesses at what amount of dollars I might expect to pay for repairs. 3. Other than the fiberglass repair, do I need to be concerned about the crack in the "front" panel? Any potential structural issues I might have caused? 4. Are there any concerns with this incident affecting the track-worthiness of the car if I drive it as-is before I get it fixed? I have a track weekend at MSR on the calendar in two weeks. Thank you for your consideration. I would appreciate whatever advice you can provide. ![]() ![]() ![]() Front panel damage, in front of rocker panel, underneath and inside of front driver's side wheel (between wheel and jack point). The white streak in the upper right is a relatively shallow rock scrape. ![]() ![]()
'05 Elise |
Regurgitated User
sorry to hear - it has happened to a few people and perhaps they can chime in...
as far as what i have heard very minimal concerns about structural damage. however getting the sill off (and at that point probably just as easy to use new) is not exactly easy... the front looks repairable to me, its not very stressed in that area, and you could epoxy it and re-finish it. just my intial thoughts.
Driving it around!
Sorry to see the damage. You should be able to have two areas of damage repaired by a body shop competent in the repair of fiberglass. The damage is not bad enough to warrant the expense and time to remove the bonded onto the chassis rocker panel and it should be possible for a good body shop to return that panel to like new condition. You shouldn't have any structural issues with the car and you can drive it as is if you can't get it repaired right away. As far as the cost to repair, I really don't know, but I am sure that someone else who has had similar damage can give you an idea.
My car hit a bunny at top speed and had to have fiberglass work on the bottom front. You will never see the repair this far down unless you jack it up and look for it, if at all, so no worries. Fiberglass is so easy to work with too, dont sweat it. Almost any body shop should be able to do this. Just call your local Corvette dealer and ask where they recommend for fiberglass repairs.
2006 polar blue Elise, VF stage II, clam hinge, von Hep exhaust, HID, Zeitronix/Dashdaq (GPS, wideband O2, EGT, fuel+oil pressure), BWR fuel rail, moroso oil pan, HD SS clutch, RTV brace, green wire mod, harnesses, Oddysey 625, alpine pdx-5, jvc avx77 head unit, jl speakers, voltmeter on dash, custom gauge pod, etc. |
Super charged!
The sill doesn't look punctured - which is good if you have the LSS with oil coolers - those lines run through the sills and are extraordinarily difficult to replace. The pictures of the sill damage under the door does look a little chunky - meaning it may just barely be intact. It almost looks as if you could touch it and push a hole through. That may be some tricky bodywork - it can be done but I would always worry about the area repaired resurfacing and being evident a few months down the line after the paint cures and shrinks. (fiberglass contracts with temps)
As tesprit mentioned - these are bonded at the bottom to the panel underneath - not fun or easy to replace. Another terrible thing about these is if you open the door and follow the panel you will see it connects to the roll hoop. Proper replacement would mean the rear clam would have to come off. If you have someone repair all these areas as they are (and not replace) you will have to be concerned with color matching/paint quality. In my opinion - if you are going to have insurance pay for this, get new material. If you are paying out of pocket for this (which may help you save resale due to carfax) then just have a body shop patch and repair.
2009 Exige 260 SPORT - Chrome Orange / Carbon Fiber / Black with the mustache Purchased through St Louis Motorsports |
#6 (permalink) | |
Super charged!
The Elise, like modern Corvettes, is a combination of materials (The Exige only shares the sills and doors with the Elise). The doors have some flex to them - the clams are more brittle with no give. The thickness of the material is unique on the Lotus - it is pretty thin compared to a Corvette. And to just slap raw fg matt on it with some resin, sand primer and paint - may patch the area - but due to the thickness and different materials and now a compromise of a once solid piece - there is a chance it can resurface. Fiberglass has a tendancy to contract and expand. Just like you see a steel bodied car that had bondo or an epoxy put in a repair show later - this happened because of the different reaction of different materials. Can you imagine someone putting fiberglass in a urethane (flexible) bumper. Any kind of flex and the fiberglass pops out - because it doesn't give. Sure you patched the hole for a while but this isn't really a quality repair. I tend to find people who take this approach don't usually keep their cars very long. They either aren't aware of the problem resurfacing later or don't care. Now having said all that - I won't say it can't be repaired but to do it right and get the thickness and integrity close to the panel would take almost as long as replacing the panel entirely. In fact, this is what GM advises for modern Corvette panels in SMC (sheet molded compound) - because they understand it was produced uniformly by a machine. Anyway - to each their own - it's your car, do with it what you will.
#7 (permalink) |
Elise 1 : Monkey 0
Oh ****, my sympathies for what consolation they are.
I thought I had a bad day yesterday when I managed to take out a monkey in my week old Elise. I was lucky to get away with a crazed patch on the front nearside corner. 24 hours of what if's and if only's.... |
#8 (permalink) | |
anglophile in exile
![]() Can't see any justification for replacement of the sill panel (too much work to remove/replace) and the front crack is trivial. I would guess you are going to be looking at the $500 mark for both. |
#9 (permalink) |
If it is just that outside area that is painted body color, I would guess around $500-600..
Just make sure the bodyshop is really good at doing blend jobs. (blending the paint and clear coat, then buffing it all out so the finish matches). Red is a hard color to blend/match. |
#13 (permalink) | |
).My question is, after reading a horror story Lifting your C5/C6 Corvette 101: a few tips. | Editorials Blog & Discussions at Corvette Fever Magazine I got freaked out as my car is in the shop right now and I hadn't specified the jacking points to them (I have now called, emailed messages for tomorrow, am going to take the instructions tomorrow morning to them - they may be starting on it tomorrow). How much do your average certified and trained body repair technicians know about finding jacking points? Have people had problems with this often? Is this something that to a mechanic would be obvious before jacking up the car (where to put the jacks on this car)? I didn't realize at first that they would have to raise the car to remove the front clam to work on it. Did I screw up not taking it to a lotus dealer to have them outsource it to another body shop and bend me over at the cash register? This one seemed like pretty run of the mill body shop material until I looked into it more. I'm nervous now... |
