Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > New car information. Specs. Shows. Demos. Costs (MSRP)
Old 05-21-2007, 04:10 PM   #21 (permalink)
A lot of stickers!
Images: 9
Probably one of the best examples of the chopped off rear would include the Kamm tailed Alfa's from the late 50's early 60's as well
Jeff
Jeff
Formerly known as brgm100
1991 Lotus M100 Elan
2005 Lotus Elise
2008 Saturn Astra XR 3 door 5 Speed
Toad is offline   Reply With Quote
Old 05-21-2007, 04:44 PM   #22 (permalink)
ZAMMY
drag, schmag, you don't have broads hanging out of the windows taking cellphone pictures of corvettes!
Old 05-21-2007, 04:53 PM   #23 (permalink)
できそこないの傲慢嫌い
carlover's Avatar
Originally Posted by xtn
The 100lbs of downforce at 100mph for the Exige is no more draggy that any number of cars that produce 100lbs or more of lift at the same speed. It's just a lumpy, scoopy shape people.
Now THIS is how you go 280mph on 200hp or less:
Doesn't generate much downforce does it?
Check the VIN of the Lotus you're considering buying
http://www.lotustalk.com/forums/f3/h...hl30039-66280/
carlover is offline   Reply With Quote
Old 05-21-2007, 05:34 PM   #24 (permalink)
Bane's Avatar
Images: 4
Turn it upside down and it will
So what is the official Cd for the Elise? I saw 0.36 and 0.407 in this thread.
Old 05-22-2007, 07:03 AM   #25 (permalink)
sanchez's Avatar
And no one has ever written a song about a lotus.
In any case I hope the OP gets the info he is looking for.
I don't think I would be too concerned with how much drag the Elise and Exige are making. They are primarily, at least I think, for smaller tracks where their light weight and superior handling are exploited. On the front straight of a track like Road America a 1.8L cycl is not going to keep up with a large displacement V8.
Doesn't make it bad or worse, just different.
sanchez is offline   Reply With Quote
Old 05-22-2007, 07:34 AM   #26 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
In straight and level flight it generates about 680 pounds of lift. The vector is pointed at the sky instead of at the ground, but downforce or lift is all the same as far as drag goes.
Even when upside-down, in straight and level flight it generates 680 pounds of LIFT. Sure, the vector is pointing out the belly of the airplane, but it's still pointed at the sky.
Oh and by the way, I'll say it here instead of editing my previous post:
That's 280mph on 100HP !!!!!!!!!!!!!!!!!!!!!!!!!
Now that's a low drag design.
Old 05-22-2007, 07:59 AM   #27 (permalink)
untitled
Beanie's Avatar
'Calculate HP including that needed to overcome aerodynamic drag
' rho = density of air in kg/m^3
' Cd = coefficient of drag which is unitless
' FA = frontal area in m^2
' V = car velocity in m/s
Pd = 0.5 * Cd * rho * FA * V * V * V
' Pd = Power to overcome aerodynamic drag
' a = acceleration in m/s^2
' MkG = mass in kg
PinW = (MkG * a) + Pd 'power in Watts
HP = PinW / 745.699872
It is all about "Other".
Beanie is offline   Reply With Quote
Old 05-22-2007, 01:43 PM   #28 (permalink)
MIA
sonza68's Avatar
Ahhh...the metric units are hurting my head.
Tom
<insert witty saying here>
sonza68 is offline   Reply With Quote
Old 05-22-2007, 02:43 PM   #29 (permalink)
WTF
climb4fun's Avatar
' MkG = mass in kg
What's exactly your formula?
* =What's that???
climb4fun is offline   Reply With Quote
Old 05-22-2007, 02:44 PM   #30 (permalink)
with future lotus driver
Conan's Avatar
Images: 24
* =What's that???
'*' is typically the charcter used to denote multiplication.
Yes, it IS my real name. No, I don't look like him. I'm Polish. Polish barbarians are skinny nerds.
2006 BRG Lotus Elise (broken), 2009 Honda Fit (gas miser), 2007 Honda Odyssey (the wife's)
Conan is offline   Reply With Quote
Old 05-22-2007, 02:51 PM   #31 (permalink)
Lancia's Avatar
Who needs the metric system?
My car gets forty rods to the hogshead.
Lancia is offline   Reply With Quote
Old 05-22-2007, 05:25 PM   #32 (permalink)
untitled
Beanie's Avatar
The units don't have to be metric, but they do have to be consistent.
That's Visual Basic source code... part of my program for tuning an Apex'i Power FC. I can see a graph of HP and torque and... (see below)... as I drive and/or replay it later. HP calculation takes drag into account. I got the Cd by doing a coastdown test from 80MPH and someone analyzed the results using some math tool I don't have. BTW, someone gave me the algorithm and I believe it's good.
NOTE: Wheel HP
At some point the program *could* (with absolutely minimal user input) just try different combinations of AFR, ignition timing, and VVT timing until it finds the max power for every possible condition. It just takes a lot of time to write all this code.
Old 05-22-2007, 06:35 PM   #33 (permalink)
holmz's Avatar
Images: 5
Originally Posted by Conan
No. You are talking about two different concepts simultaneously. Drag and lift. The TT has very low drag. The round egg shape is very aerodynamic from a standpoint of low drag. However, it is lift that causes instability at high speeds. The prius and insight are probably very unstable at high speeds because they doubtfully have anything in their design to generate downforce. The reason you don't hear about them as being unstable is because no one drives them at 100 mph.
There is never a no one or a never.
Actually the prius does feel unstable at 100MPH - which is easy to get to if you aren't using cruise control.
If you look at the back - you can actually see a little diffuser... (Surprised it doesnt have a smoother underbelly).
But yeah I wouldn't say it generates downforce - it is slippery though. (and sippy too).
holmz is offline   Reply With Quote
Old 08-18-2007, 07:12 PM   #34 (permalink)
From close to Roswell....
apexdc's Avatar
Exige Aerodynamic Analysis
There is an excellent British publication called "Racecar Engineering" that just started a very comprehensive aero analysis of the Exige.
First article is August 2007. The magazine is usually available at places like Borders, Barnes and Noble, etc.
This month they are comparing a box stock Exige with a Hanger 111 racing version. Very interesting stuff.
If you think our cars are bad on drag, check and see what a current Formula One car is. About the same as a barn door!
2006 Elise, Graphite Grey/Red leather, Sport Elise Suspension, Hardtop
Wife drives a 2007 Cooper S, our BIG car!
apexdc is offline   Reply With Quote
Old 08-18-2007, 08:37 PM   #35 (permalink)
Lulu ROX!
Andrikos's Avatar
LOL! That was really funny.
Andrikos is offline   Reply With Quote
Old 08-20-2007, 02:18 AM   #36 (permalink)
Lancia's Avatar
Thanks.
"Everything is more wonderful when you do it with a car, don't you think?"
-girl by the fire, while watching a huge tree rearranged in the bonfire by car bumper and cable
Stop that! You're in direct violation of the laws of physics!
Old 08-20-2007, 10:10 AM   #37 (permalink)
the newest model Civic that started in MY06 has a pretty good Cd. Helps hit those higher mpg ratings too! =)
yacoub is offline   Reply With Quote
Old 08-22-2007, 10:55 PM   #38 (permalink)
Haxord but mine
Westrock's Avatar
* =What's that???
LOL...not used a calculator/keypad much?
-David
2006 Storm Ti Exige + VF Stage 2
Vision Function Supercharger Install Thread
Stereo Harness Info | Exige with no wing??
Westrock is offline   Reply With Quote
Old 08-22-2007, 11:02 PM   #39 (permalink)
Haxord but mine
Westrock's Avatar
Originally Posted by gogogo View Post
Ok, maybe my TT point was a bad example but Prius, Insight has excellent Cd. Figures.
Yes, once when I was trying to figure out what the actual differences were between fastback and hatchback and such. I came upon some of the lesser know styles and the Prius and Insight are part of the Kammback design....which is supposedly one of the best.
Very cool stuff for sure....a balance of art and science I guess.
I remember a couple years ago one of the major car mags did a comparision of the, then, new Z06 versus the Viper to see which was fastest. I believe it turned out the Vette was as fast if not faster flat out then the Viper despite the 150HP definciency. As it turned out the Viper was horribly unaerodynamic, like a Cd of 0.4x while the Vette as mentioned was around 0.28.
-David
Old 09-04-2007, 07:06 AM   #40 (permalink)
Live to Drive
Bavarian Motorist's Avatar
It's Dodge's design elements. Too boxy!
Not that it matters, but the current Z06 has a cd of approximately .34 as opposed to the regular C6. I just hope it's purposeful drag and not just appearance-induced drag.
