'73 Europa headlights
Has anyone ever had a problem with the headlights such as the right one is dimmer than the left and I replaced it with a new sealed beam and it still is dim. All the rest of the lights work just fine,I'm thinking that the mice that had been living in this car before I got it had eaten the insulation on the wires as they did to the ignition wires. Has anyone have a solution to fixing this by maybe adding a new wire or bypassing the present ones? Any ideas will be appreciated, Bobby
#2 (permalink) | |
G-200 Driver
Heyy... I was going to say the same thing !! ( yeah right ).good advise... I've never turned on the headlights in my Europa.... I have no idea if they even work ..... or the windshield wipers... no idea..
74 Europa Zetec TC Special 3614R Elise #2292 / Chrome Orange !! / Starshield / Sachs suspension / RTDbrace / Uprights machined / Down Low rails / ... "My daily driver does .85 Mach" " I started flying when Sex was safe and Hang Gliding was dangerous " ![]() BUY My Europa ! http://www.lotustalk.com/forums/f94/...pa-sale-43829/ |
--Moderator--
As others have said it is most likely to corrosion/bad connection. In either case find it quickly. It means there's resistance somewhere and resistance = heat = fire hazard!
Cheers, Kiyoshi
life is better behind the wheel of a Lotus... |
'73 Europa Headlights
Thanks for the advice, I did find a broken ground wire that looks like the mice chewed on it. I'll need a connector as the wire is short on one end and hard to get a grip on it. It does lead to the front lights on that side. I'll need the headlights to pass inspection for registration. The car will be ready for the road now and is running great after getting the carbs cleaned out. So far I used 2 cans of penetrating oil on a lot of parts that need working on. Thanks again for the advice, Bobby
#6 (permalink) | |
#7 (permalink) | |
Call Me LEO
![]() Not that newer cars are immune...I owned a 94 Volvo that fried it's fuses. ![]() IIRC British Wiring - harnesses for classic cars and motorcycles is a good source for modern fuse box conversions. They can talk to you about your problems also, as they are quite knowledgeable about different solutions. HTH Atwell Haines '88 Esprit (one main fusebox with several other fuses hidden in random places) ex-79 Spitfire (three fuses for the whole car) ex-57 Morgan (two fuses for the whole car...and cloth wiring, probably not flame retardant) ![]() Lotus Enthusiast's Organization NJ |
#8 (permalink) |
Thanks for the info, I found the broken wire and that was the problem. I will do as you all suggested and start tracing the ground wires and cleaning them up. I got some dieletric grease and have been putting that on the connections as I go along. The car is now ready for the road, inspection will be done this week and registration and I'll be taking it to work a couple of times a week when I go back in Nov. I believe using the car will help keep it in condition and it has been sitting for 5 years and needs running, Again Thanks, Bobby
#10 (permalink) | |
Call Me LEO
I like to use CONDUCTIVE grease on the ground connectors. Unbolt the wire rings, clean up the metal mounting surfaces, and smear a little conductive grease on them. Not only will the connection resist corrosion, but those pesky electrons will "jump" to the chassis like nobody's business. ![]() You can get conductive grease in the electrical department at Home Depot or other home or hardware stores. It is used in the home for joining aluminum wires. DON'T pack multi-pin connectors with conductive grease for obvious reasons. There, Dielectric is the way to go.HTH
Atwell Haines '88 Esprit Succasunna, NJ USA Lotus Enthusiast's Organization, NJ/NYC Area www.LotusEnthusiasts.Org |
#11 (permalink) |
I'll get some of that conductive grease and do that. I'll also post some pics of the car soon as I get another polish job on it. It will be black later on probably sometime around January or so. Bobby
#12 (permalink) |
The big trouble with the europa and as well many British car is not really Lucas, but meanly how the wiring is assemble.
On the Europa, the power is going through the light switch on the dash, and the switch can become warm, too much current in it. The best is modifying the wiring to put a relay and use the switch to power up the relay. Also, all female connector are built with very flexible steel, and when you insert the male on it, the female become loose and the press fit is lost. Solution for that? not really good one except modifying all end and use modern female and male connector.
____________________________________ Elise 2006, white, Katana Europa 1969, green, H22A, 194 whp, 1550# CONFIGTECH.ca / Solidworks |
#13 (permalink) | |
#14 (permalink) | ||
The connectors are relatively cheap, and easily replace. I bought a kit a while back that included a selection of plugs, the female connectors in various combinations, spade terminals, boots, etc. And the special crimper for the Lucar connectors. Note that I said Lucar connector as they are a specific type. The standard bullet connectors that you can buy at your local auto parts are not the same. The bullets will plug in, but you won't get a good connection. The Lucar "bullets" are slightly different shape. Get the proper Lucar connectors (have I said "Lucar" enough times?). If you really want a good fix, squirt dielectric grease into the "barrel" connectors before inserting the plugs. The grease should be displaced as you plug in the plug allowing a good mechanical connection (and electrical). Then the dielectric grease keeps things from corroding.
#15 (permalink) |
After reading your comments I can see now why when we tried using a jumper wire connection it would not work. After taking out the headlight, we just twisted the 2 wires together and capped them and the headlight works just fine. As I am doing this I noticed the panel or dash lights are not bright either and am tracing the grounds for the reason why. Before this I had not tried them and that will be the next fix along with checking out the fan for the compartment, it seems to be a little weak. Thanks again for all of you for the advice, Bobby
#16 (permalink) | |
#19 (permalink) |
Bobby, I sold my TCS in April after 3 month int redo. I did not try to trace and fix the grounds but added at least 3 new grounds. it was easy to do. The black trim at the bottom of the dash is metal and a source of grounds so I ran 2 or 3 grounds from the bolts on the shifter under the carpet to the bolts holding the trim to the dash. I ran a ground to each end of the dash. I also then ran a extra ground to the tach. You my want to replace the voltage sabalizer. I added an extra grounding strap inthe engine bay. The cost was very little and it helped with brighting the das lights a little. Also replace all of the gauge bulbs they do get weaker with age. I think a couple of my bulbs might have been original to the car from 74.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| bobbythejudge |
| Display Modes | |
