Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Other Lotus Models
Old 01-31-2009, 10:22 AM   #1 (permalink)
#101
AgentTripleX's Avatar
Europa Lift/Jack Points
Curious where they are? I've got to get one on a lift to check out the undercarriage, but the bottom is all fiberglass. Anyone know where they are?
http://www.facebook.com/SPRVXN
www.twitter.com/autoVXNS
http://sprvxn.tumblr.com/
"We always deceive ourselves twice about the people we love - first to their advantage, then to their disadvantage." Albert Camus
"The refusal to choose is a form of choice; disbelief is a form of belief." Frank Barron
AgentTripleX is offline   Reply With Quote
Old 01-31-2009, 10:51 AM   #2 (permalink)
Plain ol' Lotus-nut
khamai's Avatar
Chassic Europa right?
In the front under the suspension pick-up points on the chassis. Do not use the center of the boxed section of the chassis without using a piece of plywood to spread the load. You can also go right behind the front wheel on the rocker, by spreading the load with a wood block.
At the rear, just forward or behind of the wheel on the body, again with a wood block. Or, under the tranny where the lower suspension arms attach.
Cheers,
Kiyoshi
life is better behind the wheel of a Lotus...
khamai is online now   Reply With Quote
Old 01-31-2009, 10:59 AM   #3 (permalink)
G-200 Driver
kestrel74's Avatar
Yup.....what he said.... that's what I do with mine.
Old 01-31-2009, 02:10 PM   #4 (permalink)
GregD's Avatar
Cheers,
Kiyoshi
If you go with the body lift points, make it a good sized block of wood, say at least 6" x 6" that will extend under the vertical part of the body at the wheelwells.
And a 2x4 of the appropriate length works well under the front part of the chassis and under the transmission if your jack is low enough, or you drive the car up on a couple of pieces of wood first to get it high enough to get the jack under it.
Racing Green, Sports, Touring, Hardtop, and Starshield.
GregD is offline   Reply With Quote
Old 01-31-2009, 04:11 PM   #5 (permalink)
#101
Thanks for the advise guys. Hopefully all goes well on Monday.
