05 Ardent Red
Lotus airplane
Just stumbled upon this, thought I would share. Look under Scaled - Prop Aircraft in the left hand column first aircraft under Single-Engined is the Lotus Microlight (Model 91 and 97).
STARGAZER - A unique database on Burt Rutan and his projects!
It weighs less then a ton, but you get 190hp. That's like putting a Saturn 5 rocket in a blender. J. Clarkson |
Plain ol' Lotus-nut
We'll never know what could have become of the full potential of the Rutan + Chapman collaboration. The Lotus engine was a marvel, with fewer moving parts and lighter weight. Most ultralight engines of the time required the crank to be geared down to roughly half speed. Chapman realised that by driving the prop off the cam (which turns 1/2 speed) that they could simplify the entire mechanism and shed weight!
Cheers, Kiyoshi
life is better behind the wheel of a Lotus... |
Chapman may have realized it, but TCM built an engine with the prop driven off the cam, (Tiara, O-405, six cylinder, '6-285' '6-320', 285-320 horsepower) nearly 40 years ago. Never found much acceptance in the marketplace, however.
here's a cutaway: http://www.flightglobal.com/airspace...ra-cutaway.jpg |
I admire the innovation of the Lotus attempts with aircraft engines, but after owning a couple Lotus engines and comparing them to the reliable engines in the airplanes I have owned, I am really happy they never made it into production aircraft. It's one thing when your Esprit engine blows up or quits running while you are driving, but another thing altogether when your airplane engine fails as you are flying over the Rocky mountains.
Regurgitated User
...yea - driving the prop of the cam on an avaition engine - will in theory may make weight sense .... is not a good "reliability and durability is #1" idea.
anyways- the elite was built per a boat, then chapman got into planes, true it would have been really fascinating if the lotus personal sport plan had seen the light of day. eventauly liabilty lawsuits would have ruined lotus no doubt - but he, and rutan were/are pure genius! i heard rutan owns an elise?
Driving it around!
On an aircraft engine, with each firing pulse, there is a sort of kick-back, or "snatch" induced back into the crankshaft by the propeller blade. "Designed for aircraft engines" dampen this with movable counter weights on the crank throws. Rudd was a sharp cookie, and would surely have known of this effect, and designed for it, but it makes you wonder why the idea didn't catch on. Maybe it feeds back into the valve train?
#7 (permalink) | |
It was rather humorous watching the drive end of the crankshaft shear off and the 4 bladed club style dyno. prop go cartwheeling around the dyno. room while the test crew dove for cover. ![]() |
#8 (permalink) |
Regurgitated User
not an expert a&p or engine design guy - but it would seem to me that either the valetrain / cam would fail from the load. or you would have to build it so robust that you might as well go with crank redution gearing.
fundamentally, driving anything with load off the cam, is a bad idea
Driving it around!
#9 (permalink) | |
