Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Other Lotus Models
Old 06-10-2009, 06:56 PM   #1 (permalink)
Lotus Elise ???
is the lotus elise drive by wire??? or is it cable driven throttle body???
also does it have a factory security system???
also does any know if the ecu will plug and play in a 2004 toyota celica gts???
turbo-k is offline   Reply With Quote
Old 06-10-2009, 07:21 PM   #2 (permalink)
Denuo Volatilis
...m...'s Avatar
...2005 cars have mechanical throttle cables; 2006 and newer are drive-by-wire...
...all cars have a built-in cobra alarm system with door, boot, and bonnet switches, adjustable cabin microwave sensors, and automatic kill timers...
...i doubt the ECU is plug-and-play compatible with toyota instrument clusters, as it's a custom lotus unit, but i've never heard of anyone trying it out to see...
Old 06-10-2009, 11:04 PM   #3 (permalink)
wow good to know...thanks....
does the lotus have and chip in the key like the nissans, etc or have something like a immobilizer system like hondas, acuras, etc??? i wanna try an put a lotus ecu in my car...not to sure if the cam is the same though.... still need to do more research....
Old 06-10-2009, 11:16 PM   #4 (permalink)
perfututum futūtor
RoadDad's Avatar
Why do you want a Lotus ecu in your Toyota?
Me... I don't need to.
Bite me." -Randy
Old 06-10-2009, 11:23 PM   #5 (permalink)
NOT ßANNED!
Demonized's Avatar
Your factory GT-S ECU will probably respond better to modifications than the Lotus ECU :P
Old 06-10-2009, 11:53 PM   #6 (permalink)
because the lift is lower and i think its only the ecu that make more power...thats what i read....
celica's = 180hp
elise = 190hp
Old 06-10-2009, 11:54 PM   #7 (permalink)
the only mods i have on my celica is injen cold air intake, fidanza flywheel, competiton clutch, test pipe...everything else is all stock
Old 06-11-2009, 12:41 AM   #8 (permalink)
anglophile in exile
Aedo's Avatar
Images: 88
No there isn't a chip in the key - you need to press a button on the fob to disable the immobiliser is entirely separate from the ECU (look up threads by The Viper - lots of info on the alarm/immobiliser system).
Aedo is offline   Reply With Quote
Old 06-11-2009, 05:57 AM   #9 (permalink)
Denuo Volatilis
...m...'s Avatar
...the only reason the elise ECU makes more power is because it revs higher than celica, but the tradeoff is that it's a learning ECU, which means any potential gains from your cold air intake, aftermarket exhausts, or any other bolt-on tuning bits will go away as soon as the ECU has an opportunity to learn and adapt to their effects...
Old 06-11-2009, 06:12 AM   #10 (permalink)
G-200 Driver
kestrel74's Avatar
Holy SEARCH mode !
Old 06-11-2009, 06:14 AM   #11 (permalink)
perfututum futūtor
RoadDad's Avatar
This thread is far better than "I bought a Lotus ECU and I don't know why it isn't doing what I thought it would in my Celica."
Bite me." -Randy
