Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Other Lotus Models
Old 10-12-2009, 09:13 PM   #1 (permalink)
Seven S-2 Steering Rack Mount
I just bought a 1-owner 1962 Lotus Seven Series 2. It came to me just like it did to the original owner...in a box. Actually there are several boxes. It had been in storage for 30+ years...disassembled!
My initial plan is to revive, not restore. I have ordered some books, as this is my 1st Seven. While I'm waiting for the books I thought I would make it steer and stop.
The steering rack appears to be mounted without bushings, but it looks like it uses two locating pins to keep it clocked in the proper direction. I cannot find the pins in any of my boxes. Does anyone know about these pins? Where can I buy them? That will make steer.
Now to make it stop...it has 4-wheel DRUMS and uses a single 3/4" bore master cylinder. In fact it's the same part number used for the clutch slave. I would like to fit a proper (and safer) dual stage master cylinder. Does anyone know if there is a dual stage master cylinder that will fit? Perhaps one from a "newer" British car? Does it have to be one that has 4-wheel drum brakes too?
Thanks!
gtlars is offline   Reply With Quote
Old 10-13-2009, 06:42 PM   #2 (permalink)
British Car Restoration
goldengatehornet's Avatar
Keep the drum brakes, if you can. Most have converted the fronts to discs, which came later in the S2 production. The steering is from the Triumph Herald/Spitfire, so lots of parts available. Get the Spitfire catalog from Victoria British. If it's stripped to the tube frame, weld the extra tubes that are suggested by Ortenburger, 'Legend of the Super Seven'.
goldengatehornet is offline   Reply With Quote
Old 10-13-2009, 07:44 PM   #3 (permalink)
Keep the Drums
Are the drum brakes known to be from another model as well? I will look for the Spitfire steering parts. The outer panels are attached.
Thanks for the advice!
Old 10-13-2009, 08:46 PM   #4 (permalink)
Head LOONY
tvacc's Avatar
You should really join the lotus cars group on yahoo.com
That is where they talk about the original Lotus 7 and you can get a lot of help from them.
What is the serial number of your car? It should be SB something.
Tony Vaccaro
2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter,
www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus
Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances
tvacc is offline   Reply With Quote
Old 10-14-2009, 09:01 AM   #5 (permalink)
the front drums are Triumph Herald, I believe. The rear axle and it's brakes are from a Triumph Standard 10 sedan, but parts are available. The Ortenburg book is a good starting reference, though not all of his info is correct. I did a lot of research on the seven, as i've restored an S1 and an S2. The first reality is that no two sevens are alike!
Old 10-14-2009, 11:16 AM   #6 (permalink)
[quote=tvacc;1371418]You should really join the lotus cars group on yahoo.com
What is the serial number of your car? It should be SB something.[/QUO
It's SB1233. I have already received all of the original build information from John Watson at the Lotus Registry.
Old 10-14-2009, 11:41 AM   #7 (permalink)
It's good to know that there are parts available. The fact that you have done 2 cars means the first one didn't scare you away. Thanks for your insight.
Old 10-14-2009, 11:51 AM   #8 (permalink)
I forgot to say thanks for the Yahoo Groups information. I have signed up and will start posting soon.
Old 10-20-2009, 08:47 AM   #9 (permalink)
Head LOONY
tvacc's Avatar
Originally Posted by jacob5 View Post
where is yahoo group.
Yahoo! Groups - Join or create groups, clubs, forums & communities or Yahoo! Groups - Join or create groups, clubs, forums & communities
Tony Vaccaro
