I'll let you catch me
Hi, I'm new and not sure what to do
I wasn't sure where to post this. It is a fairly large forum and I tried searching and didn't find any helpful information but I need help with a clear bra.
I tried to remove one area and got exhausted after trying to pull it off. I cut off the piece so now it looks ridiculous and dirty because I can't get the glue off! I have an 05 Elise with I think it is called starshield clear bra and I want to have it removed since it doesn't look good. It has a lot of little wrinkles and fingerprints in the film ( its a yellow car) I would like to have it professionally redone in my area (Medina Ohio or within 25 miles). I wondered if anyone here would know more or someone who does the clear bra installs with great results. Any advice would be certainly appreciated. Thank you, Mrs.Peach |
Not sure I would want to use paint thinner on my paint. I would try and adhesive remover or something like WD-40..
2007 Exige S - Chili Red 2009 Mini Cooper S - Chili Red Gotham 265, Nitron Sport Pro, Moroso oil pan, RTVBrace, Volk CE28N/R888, Cup Wheels/A048, 2Bular Ultra 4", Rapfix II w/ Sparco P300, S111 CF Splitter, Ultradiscs, Pagid RS42, V-Force Harness Bar, Schroth PROFI II, Fire Extinguisher, Folding Tow Hook, Odyssey PC680, re-ENFORCER, LLumar 30% tint, Traqmate, DashDAQ, Chasecam, Alpine IVA-D100 w/ Backup Camera. |
(Formerly PESTODUDE)
contact (brake) cleaner should take off the glue without ruining the paint. Still, try it in one small area as a test.
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune. |
Registered lUser
If you search using the keywords "remove" and "starshield" you'll see several relevant posts or you could try contacting Starshield directly and have them tell you to steam it off.
JohnnyQuik current toys: '05 Elise '72/'79 MGB '06 Z4 |
#7 (permalink) | |
G-200 Driver
#8 (permalink) |
Keep it simple and real
Why not let the installer of your new Starshield perform removal of the existing clear bra?
#9 (permalink) |
I'm a bit nervous about trying solvents on my paint, so I will hold off on doing it myself.
I checked Starshields site and it says I would need to buy a 3m adhesive remover. I'm not going to bother doing that I'm 53 years old. I'm not going to take a full day removing this stuff. The film was on the car when I bought it, in 2005 so it's not new and they will not come here just to remove it. I bought the car in New York, so I can't go back to the dealer. I think I will deal locally for a clear bra that way if I do have any other issues I can have it dealt with swiftly. The warranty work for this, just isn't worth it. I hear venture shield is good, I will research it a bit more. So I think I will call the dealer later today and see if they can remove this film and suggest a replacment. Thanks for your help everyone and wish me luck, ![]() Mrs. peach |
#12 (permalink) | |
Contact Mats "swede".
He had his car done locally, Twinsburg area. It maybe more than 25 miles depending where in Medina you're coming from. Quote:
------------------------------------------------- 05 Elise, Storm Ti, Black Int, Hardtop, Starshield, LSS |
