Old 02-13-2008, 05:29 PM   #1 (permalink)
道のお父さん
RoadDad's Avatar
2007+ sealed headlight shutter adjustment
My 2007, with its sealed headlamp units, has a level low beam cutoff and does not "flare" up to the right. I haven't yet taken a dig into the headlamp unit to see if the beam shutter can be reached and retracted, like the unsealed units can, to allow the right sided upsweep.
Has anyone with a sealed unit tried to retract the shutter yet? If so, tips for success would be greatly appreciated. If not, I will try to take some pictures and post them (if it is possible) or hang my head in failed shame (I won't take a picture of that -- it would blind too many of you with the amount of glare from the top of my dome ).
"There are two things no man will admit he cannot do well: drive and make love." -- Stirling Moss
Nunquam est ponenda pluralitas sine necessitate.
Pluralitas non est ponenda sine necessitate.
Pluralitas non est ponenda, nisi ubi est necessitas.
Old 02-14-2008, 05:15 PM   #2 (permalink)
No Acceptable Substitutes
apk919's Avatar
I'm curious too... I just put in an HID kit last weekend, and while it's hard to tell definitively, it seems that the Lotus throws more light off-axis than my other (OEM) HID cars.
Searching didn't find anything on aligning/adjusting the '07 style headlights.
2007 AW Lotus Exige S. Opts: Track Pack, Touring Pack, LSD
Mods: Multivex mirrors, JLAudio 525/Stealthbox/Focal 130 spkrs, Alpine PDX-5 Amp, Sector111 F&R Tow Hook, Fire Ext, HID Kit, Bootie and Bling, Lotus leather/alcantara interior, Braille Battery, LED Parking/Dome/License Lights, Bane's stealth bulbs, alex's 1/4 turn kit, Stan's shifter mod, jim-c's spkr rings, codymac's 1/4 turn kit, Lotus Cup roof w/fettled clam, Schroth 6pt harness, RAC's & R888's, ChaseCam
apk919 is online now   Reply With Quote
Old 02-15-2008, 05:13 AM   #3 (permalink)
道のお父さん
RoadDad's Avatar
If I have time, I plan on taking a look at it this weekend.
Old 02-15-2008, 06:20 AM   #4 (permalink)
LOG29 Co-chairman
MickOpalak's Avatar
I posted about this a few weeks ago. Adjusting the low beams verticaly is actually very easy. You can do it without removing the wheel if you have a shorty phillips screw driver.
1. Remove the wheel liner (3 screws)
2. Next to the round, lower weather cover is an exposed silver screw. This adjusts the headlights (high and low) Simple as that.
2007 Exige S265 - Krypton Green - Gotham 265 ECU - Volk TE37s - Toyo R888s - B&M Shifter - QuickSilver exhaust - stripes - harnesses - Pagid pads - Green air filter
LOG29 - http://www.log29.org
President - Lotus Limited Southeast
http://autos.groups.yahoo.com/group/LLSE/
MickOpalak is offline   Reply With Quote
Old 02-15-2008, 07:14 AM   #5 (permalink)
apk919's Avatar
This is a picture of my right side headlight assembly with the high beam bulb cover removed. Do you mean the silver screw next to the label that says "1.2 %" (I guess that's a hint)? Is there a similar one for the low beams (can't see it in the picture), or does that one screw adjust both?
Old 02-16-2008, 12:06 PM   #6 (permalink)
道のお父さん
RoadDad's Avatar
Mick, thanks for the info but my vertical adjustment is fine. I'm talking about the "dip beam cut off pattern" created by the shutter. It makes the low beam pattern a straight horizontal line instead of flaring up on the right side. My low beams are set as in the left side of this picture. Retracting the shutter allows for the upflare pattern seen on the right of the picture. It allow the right side of the road to be lit without blinding on coming drivers.
Photographic Copyright Infringement from Sandsmuseum http://www.sandsmuseum.com/cars/elis...headlamps.html
Old 02-16-2008, 12:09 PM   #7 (permalink)
道のお父さん
RoadDad's Avatar
As of now I have been unsuccessful in finding access to the shutter in the sealed headlamp unit. I will try to bring home a flexible endoscope from work to see if I can "look deeper" into the unit.
Old 02-16-2008, 04:37 PM   #8 (permalink)
GGM ENFORCER
shay2nak's Avatar
where is the low beam height adjustment in the above picture?
'07 GG EXIGE S ** MY CAR ** VIDEO CLIPS!
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 02-17-2008, 08:28 AM   #9 (permalink)
LOG29 Co-chairman
MickOpalak's Avatar
Sorry, I don't know about adjusting the shutter. I was refering to beam angle adjustment. Yes, the one screw mentioned above adjusts both high and low beam at the same time.
Old 02-17-2008, 02:34 PM   #10 (permalink)
道のお父さん
RoadDad's Avatar
Shay,
The alignment relationship between main and dip beam lamps is fixed, but two cross-head adjusters are provided on the back of the headlamp housing by which the whole lamp unit may be adjusted. The outboard screw adjusts vertical alignment, and the inboard screw horizontal.
Old 02-20-2008, 06:43 PM   #11 (permalink)
GGM ENFORCER
shay2nak's Avatar
ah, thank you. CW raises and CCW lowers the aim?
Old 02-23-2008, 07:37 PM   #12 (permalink)
道のお父さん
RoadDad's Avatar
Update
I just ran a flexible endoscope into the dip (low) beam housing. There is no adjustable shutter that would allow an up-flaring of the lighting to the right. Instead there is a solid cut off shroud. If one really wanted to up-flare their dip beam lighting to the right, as can be accomplished in the '05-'06 by adjusting the shutter, one could file off the right side of the shroud. I, personally, will just live with the horizontal beam .
Here is a picture of the shroud taken through the lamp hole. It is a solid piece of metal with no adjustments possible. I ran the endoscope to each end of the piece and underneath. No way to change the position of the shroud. Sorry I couldn't take a picture through the scope. The camera set up to do that is just too big to carry home.
Name:  2007 shutter.jpg
Old 02-24-2008, 11:31 AM   #13 (permalink)
apk919's Avatar
Attachment 74657
Wow, above and beyond, nice work.
Old 02-24-2008, 01:13 PM   #14 (permalink)
道のお父さん
RoadDad's Avatar
Thanks but it was unfortunately all for naught .
Old 02-24-2008, 01:47 PM   #15 (permalink)
short angry bloke
codymac's Avatar
Images: 19
Love it!
Old 02-24-2008, 01:52 PM   #16 (permalink)
道のお父さん
RoadDad's Avatar
Gotta put 18 years of medical education to some kind of good use .
Old 02-24-2008, 08:14 PM   #17 (permalink)
GGM ENFORCER
shay2nak's Avatar
LOL
Old 09-12-2008, 12:26 AM   #18 (permalink)
Sorry to bring this up again....
So, do you mean adjust here? (Red Arrow) CW for higher?
Thanks!!
2007 Elise Phantom Black
Touring Pack
Hard Top
Star Shield
polojcp is offline   Reply With Quote
Old 09-12-2008, 07:52 AM   #19 (permalink)
anyone can confirm it?
Touring Pack
Hard Top
Star Shield
Old 09-12-2008, 11:21 AM   #20 (permalink)
Nerd on wheels
Arno's Avatar
I guess with the '07 onward and the end of some of the exemptions for Lotus in the US (eg. bumpers, etc.) you now have official USA 'DOT' approved headlights instead of having the normal european headlights (with the 'flares' to one side) fitted like the earlier cars.
Here in europe the 07 onward still have the 'flare' as it's part of the road law requirements.
Bye, Arno.
My Elise + K20A2 + TODA bits == Heaven!
Arno is offline   Reply With Quote
HTML code is On
