#23 (permalink) | |
fm78.tv - check it.
EDIT TO ADD: Just found this, From "Theretrofitsource.com": Aftermarket HID producers that make re-based kits for halogen style headlights are the ones responsible for the bad rep HID headlights sometimes get. I’ve got advice - Don’t be a ricer and throw an HID rebased kit into your car. HID kits that are rebased to fit in your 9006, h7, h4 etc. headlights actually worsen the light output in most cases. Sure the lights might be a little brighter lumen wise, but the actual output, (ahem the reason why the headlights exist in the first place ahem..), would suffer. Output would worsen because the focal points (capsule/filament) of the two bulbs wouldn’t match up. Thus when installed into a headlight reflector designed for the halogen bulb specs, the HID bulb throws light in places it shouldn’t. In the end, you just end up blasting light into the air instead of on the ground where it should be, which in turn blinds oncoming drivers. A bit dramatic, but I agree with this:
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior. Last edited by Serebo1 : 09-13-2008 at 03:27 AM. |
#25 (permalink) |
GGM ENFORCER
FYI, you can reach around with your arm to adjust the screw and you'll see whether it moves up or down. Very simple.
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 GG EXIGE S ** MY CAR ** VIDEO CLIPS! ![]() '08 ACURA TSX 6-speed http://www.makeNYNYagain.com |
